Induction Kit Question for Crispy
Last post Sat, Feb 6 2010 16:33 by Zimmerframe. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Mon, Jan 4 2010 19:38
    • MX5Joy
      Wed, Nov 19 2008
    • Essex
    • Posts 342
     chris,
    If I remember it was an induction kit we fitted on your car at the Tech Day. Did you also change the hoses, I cannot remember. Also have you noticed any difference to the engine power, or smoothness.
    A friend is about to order an induction kit for his MK 2
    MX5Joy
    MX5 my medicine of choice
  • Tue, Jan 5 2010 9:21 In reply to
    • crispy
      Thu, Oct 1 2009
    • Barkingside, Essex
    • Posts 67
    Re: Induction Kit Question for Crispy
     Hello Hello!
    Sorry, have been out of the office until today. Happy New Year to all!
    We fitted a K+N filter charger so there was no need to change the hoses. We were going to put the cold air pipe in too however couldn't find space for it anywhere.
    In terms of performace the car does noticeably feel to pull more especially past 3,000rpm and makes a lovely growl. At present i am waiting for Alan to finish fitting my decat pipe and new parts exhaust, plus i am running higher octane fuel which will hopefully bring a combined gain. Will update when i pick the car up.
    IMO, the cost of the filter is definitely worth it and in talking to anyone who tries to get the best performance out of their engine is the first thing they change.
    CT
    1.6 93 Eunos Roadster, K+N Filter Charger, ARC Super Intake Chamber, Decat pipe and MX5 parts exhaust...and she sounds sweeeeeeet!
  • Tue, Jan 5 2010 10:19 In reply to
    • MX5Joy
      Wed, Nov 19 2008
    • Essex
    • Posts 342
    Perfect reply Chris
    Thank you
    J
    MX5Joy
  • Tue, Jan 5 2010 11:38 In reply to
    • DavesBRG5
      Sat, Nov 15 2008
    • Bedfordshire
    • Posts 2,045
     Hi,
    I too can vouch for the K&N induction kits having recently fitted the Typhoon to my mk2.5
    Not cheap at around £170 from MX5parts (slightly cheaper on Ebay) .but i got lucky getting one half price from an OC member.
    They look good  & sound great without being OTT in my humble opinion & as to whether it adds more zip i can`t be sure but it sure sounds like it !!
    Picture of mine here if you are interested
    http://www.mx5oc.co.uk/forum/forums/t/10019.aspx
    HTH
    1992 ROADSTER 1.6 Tanabe Sustec suspension, Cusco bracing, Enzo Alloys, Momo Prototipo steering wheel, Mike Satur TT Hoops
  • Tue, Jan 12 2010 12:48 In reply to
    • Zimmerframe
      Tue, Nov 10 2009
    • South Woodham Ferrers, Essex
    • Posts 425
     I've been thinking of fitting one of these to my 1999 Mk2 .  Its down the list a bit but is on the list.  I've also read eleswhere that they slightly enhance performance and fuel economy, but the main reason for fitting is the sound :-)
    I rang my insurer, (Direct Line) this morning to ask if fitting this mod would make any difference.  It does! A 0-10% performance enhancing mod adds £4/month, so thats something else to consider too.
    If the World didn't suck, we'd all fall off!
    1999 1.8i MK2.
    Lightly modded. Some mechanical enhancments and I like red and chrome!
  • Tue, Jan 12 2010 13:25 In reply to
    • crispy
      Thu, Oct 1 2009
    • Posts 67
     i fully recommend fitting the K+N filter, alot of people say it is the first thing to start with on any engine as it is techincally the mouth of the engine allowing it to breathe.
    The sound is satisfying with the filter alone and i definitely felt that the free reving through 2nd and 3rd gear was increased. Having had most of the work done to mine though i'd go further and say decat the car and add a decent exhuast, some people may disagree but i have noticed a difference. Having said that a certian member of this site who worked on the car said he was surprised at how responsive my car was (1.6) compared to some of the 1.8's he's worked on.
    As for the insurance, i'd take the £4 per month....or just don't say anything! :p
    CT
  • Thu, Jan 21 2010 22:41 In reply to
    • Zimmerframe
      Tue, Nov 10 2009
    • Posts 425
     One final question.  I was chatting to a work colleague today whose brother had a 1.6 Mk1 fiitted with a K&N kit.  He said that after a time, the MAF could well be affected.  Is this rumour or true?
    1999 1.8i MK2.
  • Thu, Jan 21 2010 23:49 In reply to
    don't think anyone knows for sure: the MAF gets screwed if oil contaminates it.  whether in your car, with that filter, the oil catching the dust on the filter gets sucked through into the MAF, is a hard one to answer.  in the VAG forums a lot of people use Green Cotton filters as they *apparently* don't do this - but it's all a bit vague and full of hearsay.  You'll probably be fine.
  • Fri, Jan 22 2010 8:39 In reply to
    • crispy
      Thu, Oct 1 2009
    • Posts 67
     quite a few of the guys i know with 5's have filters fitted and this problem has never been mentioned. These are a mix of experienced owners and people who work in the motor trade so i would say not to worry.
  • Fri, Jan 22 2010 10:10 In reply to
    • MX-Drew
    • Canvey, Essex
    • Posts 1,047
     It is not a problem if you stick to using the recomended K&N oil and only a small amount as directed by K&N.
    If it was a problem I would stick my neck out and say K&N would have gone out of business years ago. Big Smile
    If it's broken, repair and improve it. If it an't broken, just improve it.
    Mk2.5 1.8 2004 Strato Blue.
    Coldside MP62 supercharger & Air Con & Eibach Lowering Springs (all fitted myself).
    bastienw said "Je reste bouche bée par la NB à compresseur !!!!" Translated "I remain stunned by the compressor NB!!"
  • Mon, Jan 25 2010 19:08 In reply to
    • Zimmerframe
      Tue, Nov 10 2009
    • Posts 425
     One final question folks honestWink  then I might finally buy one of the damn things...
    I've seen pictures of some fitted that have a metal heat sheild in place on the engine side of the filter.  Is this necessary?  I would have thought that the existing exhaust manifold HS was sufficient.  I guess though that you would be drawing in hotter air from the engine bay as opposed to the standard air box with an intake near to the front.  Once moving forward however, I cant see this as a problem.  Whats your experience?
    1999 1.8i MK2.
  • Mon, Jan 25 2010 19:33 In reply to
    • DavesBRG5
      Sat, Nov 15 2008
    • Bedfordshire
    • Posts 2,045
     My heatsheild is actualy plastic..........shhhhhhh............ Only bought it because it`s shiney & only cost me £7.50 on Fleabay.
    Doubt they make too much differance but every little helps & stainless steel ones are only about £11
    http://cgi.ebay.co.uk/Air-Induction-Filter-Stainless-Steel-HEAT-SHIELD_W0QQitemZ200412874748QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2ea989c7fc
  • Thu, Jan 28 2010 12:25 In reply to
    • Zimmerframe
      Tue, Nov 10 2009
    • Posts 425
     MX5parts have just reduced the Typhoon from £185 down to £158 so I will be ordering one tomorrow :-)
    1999 1.8i MK2.
  • Sat, Jan 30 2010 9:29 In reply to
    • DavesBRG5
      Sat, Nov 15 2008
    • Bedfordshire
    • Posts 2,045
    Zimmerframe:
    Good decision Thumbs up
    Fitting instructions & tools required here if you want to read up in advance, although all very simple really.
    http://www.partsgeek.com/assets/perf/full/8544-03018917-1036434.pdf
    No need to disconnect battery & the MAS wire in my opinion, just swing the MAS out the way leaving the wires attached.
    Here`s what i found useful.... Socket set with extension bars & a svivel joint. Allen Keys to tighten the K&N hose clamps. Couple of cable ties to tidy the wires afterwards. Screwdrivers, Longnose pliers to detach the wiring clips from the old airbox. Think that`s about it.
     Although knowing MX5parts you have already recieved it & probably fitted it by now.
  • Tue, Feb 2 2010 19:57 In reply to
    • DavesBRG5
      Sat, Nov 15 2008
    • Bedfordshire
    • Posts 2,045
    Zimmerframe:
    If you havn`t bought one yet there is one just gone on Ebay, £80 starting price.
    http://cgi.ebay.co.uk/Mazda-MX5-K-N-Typhoon-induction-kit_W0QQitemZ110489435601QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item19b9aefdd1
