North Thames Tech Day 4 - Sunday 25th April
Last post Fri, Apr 30 2010 20:35 by MX-Drew. 110 replies.
Zimmerframe
Tue, Nov 10 2009
- South Woodham Ferrers, Essex
- Posts 425
Re: North Thames Tech Day 4 - Sunday 25th April
Sorry for being a bit dumb. I'm newly joined to the OC, What does this entail? Do we have the use of their facilities, (tools, ramps, lifts etc) to carry out work on our cars? Do we need to have jobs to do, or can we just come along to watch/ask/learn? I want to change out the transmission fluids for instance which would be a piece of cake with the car up in the air, though do-able at home too.
I live near to Maldon, about 20 minutes away
If the World didn't suck, we'd all fall off!
1999 1.8i MK2.
Lightly modded. Some mechanical enhancments and I like red and chrome!
MX5Joy
Wed, Nov 19 2008
- Essex
- Posts 342
Hi ZF,
It is certainly a NOT TO BE MISSED DAY. Yes you can do jobs, if you have tools bring them although we are a friendly lot and as long as you return them a borrow is possible, good to have spare stuff though rather than waiting. Changing fluids I did last time, dead easy on a ramp. There are a few guys on hand who know what they are doing to point us novices in the right direction. If all else fails then come and watch and have a cup of tea. Supertyres do offer special deal for getting your car aligned, you may wish to take advantage of that. Everyone including myself who has been "Supertyred Aligned" agrees there is a big difference in handling.
Don't be shy come along
MX5Joy
MX5 my medicine of choice
eric (et)
Thu, Oct 30 2008
- Maldon, Essex
- Posts 856
Hi ZF. Joy summed the day up nicely. We only ask for an idea of the jobs people want to do so we can schedule ramp access (won't be so important with 4 available) and so we can brush up on the manuals and be ready to help if required.
Eric (ET) - Eric Terry Coordinator - North Thames Region 2007 Mk3 1.8 Icon in Stormy Blue Mica, Splash Guards, Eibach lowering kit. Blue Brigade. http://www.nt-mx5oc.co.uk/
MX-Drew
- Canvey, Essex
- Posts 1,047
eric (et):
Manual, that is where I went wrong with that radiator!
Oh and if you want me to help you I will need to see an up to date membership card (from the MX-5 Owners Club)
As for jobs, Mine is an oil change and possibly a diff change if I find time to replace the bearings and oil seals in my replacment diff. I may also change discs and calipers on the front.
If it's broken, repair and improve it. If it an't broken, just improve it. Mk2.5 1.8 2004 Strato Blue. Coldside MP62 supercharger & Air Con & Eibach Lowering Springs (all fitted myself). bastienw said "Je reste bouche bée par la NB à compresseur !!!!" Translated "I remain stunned by the compressor NB!!"
mx5pmp
- Essex
- Posts 352
I could do with changing my gearbox oil too, I just gotta see if I can afford the Redline oil
I also bought rear 1.8 caliper brackets before Christmas so need to upgrade the rear brakes to match the fronts! Although, I could do with one of our 'experts' to try and diagnose what's wrong with my bloody engine!
And there was me thinking I'd have nothing to do
MX-Drew
- Canvey, Essex
- Posts 1,047
Gary, try and see it there is any movement when you try and wobble the crank pulley. It is not a definitive test but an idea, you probably need a new woodruff key (not expensive) and some liquid metal.
Take a read http://www.mx5oc.co.uk/forum/forums/p/226/387.aspx#387
mx5pmp
- Essex
- Posts 352
Yeah, the pulley is wobbling a bit and I did try to fix it with the help of Sarah's brother (he's a mechanic) but after stripping it all down, we couldn't get the gear thingy off the crank (the one that the cam belt goes around). It didn't want to budge even a little bit, so we think it's already been glued at some point. I think the reason it's started to wobble is that at some point someone (and I'm pretty certain I know who!!) has had the crank pulley (the one that the aux belts go around) off but managed to snap one of the 4 bolts holding it on!!!
We put it all back together but had the inlet cam out by about 1/2 a tooth, which I thought I'd sorted but it's still not running properly. I suppose the easiest way to describe it is that I don't seem to have a choke anymore, it just runs at the same revs hot or cold (actually, if anything the revs are slightly lower when it's cold!) and I can't get the idle right. I've had to set the timing to TDC so that I can get the idle low enough. There's also not much power low down the rev range, but I'm putting that down to the timing being at TDC and not 14 degrees.
bling-king good
Sat, Dec 20 2008
- Basildon Essex.
- Posts 116
Hi Gary
Sounds like your having fun.I can't see how you can get the cam belt 1/2 a tooth out,because thay only do hole one's.
Bling-King good. White MK2 1.8 RS sport. 3rd cool mk2 spring rally 2009 2rd cool mk2 national 15/20 2009 1st Favourite mx5 Ace Cafe 2010 1st mk2 spring rally 2010 Best in show spring rally 2010 1st cool mk2 national rally 2010 Chatsworth 1st modified mk2 spring rally 2011 Hop farm 1st cool mk2 national rally 2011 Billing
5UMO
Tue, Nov 18 2008
- WICKFORD
- Posts 709
Just a few bit's.............. j r m45 sc, emb, boomslang PnP, 2.5 map sensor, o2 clamp, Lc1. with bracket's, tensioners, belts, some pipes, various nut's and bolts and anything else thats in the box.
Sorry almost forgot.....Some very nice and bright bulbs.
5UMO
MK1 1.8is 1997 BRG Member of The Glorious Green Gang MK2.5 sport 2001 Supreme Blue Member of the Blue brigade
MX-Drew
- Canvey, Essex
- Posts 1,047
5UMO:
........... Then over to body shop for dent removal, full respray and polish.
In all should take about half hour I guess
5UMO
Tue, Nov 18 2008
- WICKFORD
- Posts 709
MX-Drew:
5UMO:
Yeh, that sounds about right with a 15min tea break
5UMO
