Home Forums Downloads
Can one of you guys help me out?
Last post Sat, Jan 30 2010 19:48 by bling-king good. 7 replies.
Page 1 of 1 (8 items)
  • Sat, Jan 30 2010 15:29
    • mx5pmp
    • Essex
    • Posts 259
    Does anyone local know how to get wires through the doors into the cabin? I've tried today (fitting central locking to Mum's car) but it's just impossible!!
  • Sat, Jan 30 2010 16:24 In reply to
    Re: Can one of you guys help me out?
     Mk 1 or Mk 2?
    Wayne
    One Stop Mx-5 Roadsters,The Northern agent for http://www.autolinkmx5.com/
    v-- FAQ's--v
    http://www.mx5oc.co.uk/forum/forums/t/7340.aspx
    1993 black V.S II 1800cc, mazdaspeed,Extras
    1999 black V.S 1800cc mazdaspeed.Extras
    .....It's not a modification, it's an improvement.....
    The Disclaimer:-
    This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects,the articles/answers/comments are provided for information purposes and they are not intended to substitute informed professional advice, I can not personally be held responsible for any damage occurred from following this procedure or any injuries from it. Proceed at your own risk.
  • Sat, Jan 30 2010 17:10 In reply to
    • paul
      Thu, Apr 23 2009
    • tilbury
    • Posts 69
     use a single wire as a draw wire and then tap the others to the single wire you should go through then ok.
    if this does not work i will see if i can help you
    paul
    mk 3 2.0 sport electric hard top , Black
    K&N filter
    Diamond raider wheels
    Stainless steel ILmotorsport exhaust special end pipes
    Lots of chrome bits ( BLING )
  • Sat, Jan 30 2010 17:59 In reply to
    • mx5pmp
    • Essex
    • Posts 259
    It's a mk1.
    paul:
    paul
    I tried this, I managed to get a draw wire through but it was really hard and once I'd taped the wires to it, it was far too big to fit back through the grommit.
  • Sat, Jan 30 2010 18:37 In reply to
     When i have done this in the past i have pulled the rubber boot back away from the car and the door,undone the tape that holds the rubber boot to the loom and popped the plastic ovel ring(if i remember right they should split in half,so you can move them out of the way) off the car and the door also just to make life easier.
    Just refit in the same order when you have the wires all through,the drivers side will or should have 5 wires to pull through,and 2 on the passenger side,depending on the kit?
    But all in all,it is a fiddly job to do.
    Wayne
    v-- FAQ's--v
    The Disclaimer:-
  • Sat, Jan 30 2010 18:44 In reply to
    mx5pmp:
     Hi Gary
    The best way is to get someone else to do it.Big Smile
    Bling-King good.
    White MK2 1.8i RS sport.
    3rd cool mk2 spring rally 2009
    2rd cool mk2 national 15/20 2009
    1st Favourite mx5 Ace Cafe 2010
    1st mk2 spring rally 2010 Best in show spring rally 2010
  • Sat, Jan 30 2010 19:25 In reply to
    • 5UMO
      Tue, Nov 18 2008
    • WICKFORD
    • Posts 361
    bling-king good:
    mx5pmp:
     Hi Gary
    Thats sound advice comming from one of our senior technical advisors Thumbs up
    5UMO
    MK1 1.8is 1997 BRG
  • Sat, Jan 30 2010 19:48 In reply to
     Less of the senior thank you.Wink
    Bling-King good.
