'93 Eunos Vspec - my online workbook *UPDATED*
Last post Tue, Oct 12 2010 22:45 by matticus. 30 replies.
Page 2 of 3 (31 items) < Previous 1 2 3 Next >
  • Mon, Mar 15 2010 0:51 In reply to
    • V6Jules
      Thu, Nov 12 2009
    • Dunstable
    • Posts 87
    Re: '93 Eunos Vspec - my online workbook
    Well you have proven a bit more air flow makes a big difference to the temperature then! wonder how much a "pretty" naca style scoop would improve it. if it does the job then it will be fine for the track im sure! think id remove it for day to day though as it looks a bit random to say the least Wink
    Also on the quest for ultimate streamline or just good looks if you pop your bonnet up and give the rear lip of your offside headlight cover a gentle tug it will raise up and meet the bonnet better Thumbs up
  • Mon, Mar 15 2010 8:21 In reply to
     Erm.... looks a bit silly!
    The intake headlight covers from mx5parts are quite expensive but would look much better... {#emotions_dlg.bigsmile}
    VW Polo Bluemotion 1 - Partners car / work horse
    Honda S2000 - My toy
    Mk1 1.6 MX5 - Now for sale :(
  • Sat, Sep 18 2010 17:34 In reply to
    • 60Rod
      Sat, Sep 4 2010
    • Posts 177
     Hi Mattics - Just in the process of putting on a "Sticky" plate. From your pictures it looks like you could have left the Badge in place. Am I right as I am really having a job to remove mine and will end up breaking something so would rather leave alone?
    Rod
    The poodle is the proud owner of a 1990 Mk1 Eunos in Silver. I just get to drive it for him as he can not reach the pedals. We live in Prestatyn, North Wales.
    Member of the Old Gits Clan (Me not the Poodle) and the Bunch of Fives.
  • Sun, Sep 19 2010 0:02 In reply to
    • matticus
      Thu, Jan 28 2010
    • south manchester
    • Posts 40
    Where i have the plate its about 2mm inside where the badge could have sat but no reason you couldn't keep both i just preffered it without. on this one i just pressed from underneath withthe bonnet open and using the flat side of a kitchen knife, but on my previous '5 there was a little more sticky stuff on the underside of the badge but a bit of dental foss took care of that!
    matticus
    1996. UK mazda mx5, silverstone metallic
    2003. Mini cooper, British Racing Green / White
    1993. Eunos Roadster Vspec, British Racing Green
  • Sun, Sep 19 2010 7:35 In reply to
    • 60Rod
      Sat, Sep 4 2010
    • Posts 177
     Thanks. Will leave my badge on and see what it looks like.
    Great series you are doing with some fab photo's. Am on my first MX and am finding it a great help.
    Rod
  • Mon, Sep 27 2010 19:00 In reply to
    • MikeyB
      Tue, Sep 7 2010
    • Kent
    • Posts 82
    Not a bad idea with the air scoop.
    I did a similar mod on my old Ford Probe. (horrid 16v version though!)
    I bought some tumble dryer ducting and a right angle section which had a round part at the top for the ducting to clamp onto, and a rectangular 'scoop' on the other from Focus.
    I poked the 'scoop' out the bottom of the under tray, and had the ducting to right up into the airbox through a drilled hole.
    It worked really well, especially when at speed, classic bit of Ram-Air effect collecting that cold air from under the car.
    The only drawback would have been if I went through any deep puddles, and it would have scooped up the water a treat, but I doubt it would have the force to go up the whole length of ducting and into the airbox.
    1991 Eunos Roadster V-Spec
    Front strut brace
    Cabin brace
    Jackson Racing panel filter
    De-Cat pipe
    Magnacor HT leads
  • Mon, Sep 27 2010 23:40 In reply to
    • 60Rod
      Sat, Sep 4 2010
    • Posts 177
     Hi - I keep leaving the Side Lights on! How do you fix up a warning buzer?
    Rod
  • Tue, Sep 28 2010 8:23 In reply to
    60Rod:
    Rod
    Rod, you need to get yourself one of these from ebay. Cheap and dead simple to fit, just wrap the wires around 2 fuses.
    http://cgi.ebay.co.uk/Mazda-MX5-Eunos-LIGHTS-ON-warning-buzzer-mod-/280556388574?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415276c0de
    Its not a mid life crisis - just a whole load of fun.... Captain of The BUCCANEER5 www.buccaneer5motorsport.co.uk
    MKI V Spec Eunos Roadster in BRG. Daphne
    MKII VS Roadster Import in Black. Anni - aka The Black Pearl
    MKII Special Edition Red Sport. Kit
    Part share in Mariner Blue Eunos track car AKA Belle
  • Tue, Sep 28 2010 9:01 In reply to
    • 60Rod
      Sat, Sep 4 2010
    • Posts 177
     Thanks. Have gone ahead and ordered one.
    Rod
    Smile
  • Tue, Sep 28 2010 9:10 In reply to
    You need to be a contortionist to get to the fuses, but boy it does save the battery going flat.
  • Tue, Sep 28 2010 20:01 In reply to
    • chazley
      Tue, Sep 22 2009
    • Great wakering, essex
    • Posts 403
    i couldent manage to get the flash to pass mod to work i dont think the diode was touching the spade terminals correctly :S
    charlie
    1995 1.8 v-spec II eunos
  • Tue, Sep 28 2010 21:41 In reply to
    • 60Rod
      Sat, Sep 4 2010
    • Posts 177
     Hi Charlie - You do need to push each arm of the Diode firmly down into the respective terminals as far as it can go and it should then make a good contact. Once you get it working put a bit of tape across it just to keep it in place but it should be firmly held anyway.
    Rod
  • Wed, Sep 29 2010 15:57 In reply to
    • chazley
      Tue, Sep 22 2009
    • Posts 403
    i did this but kept bending the connectors lol :D
    charlie
  • Wed, Sep 29 2010 16:26 In reply to
    • 60Rod
      Sat, Sep 4 2010
    • Posts 177
     Hi Charlie - Maybe pushing too hard??? It should just slide in.
    RodThinking
  • Wed, Oct 6 2010 15:52 In reply to
    • chazley
      Tue, Sep 22 2009
    • Posts 403
    got it working finally, was the wrong connector :D lol
    charlie
