8" door speakers for mk2.5?
Last post Mon, Dec 19 2011 10:10 by Wrongun. 37 replies.
Page 3 of 3 (38 items) < Previous 1 2 3
  • Tue, May 11 2010 22:50 In reply to
    • Benj
      Thu, Feb 25 2010
    • Southampton
    • Posts 12
    Re: 8" door speakers for mk2?
    Spoonyboy:
     Now that is one nice big looking speaker!!!
    Would be grateful if you could let me know (and the rest of us) what the speaker model number is? and if you had any difficulties installing? Did you have to drill any holes or cut away any metal?
    Of course. The speakers are JBL GT5-803 and I got mine from Car Audio Direct. To fit them I didn't cut away any metal, but the speakers don't fit completely snug in the existing holes, but they do fit well enough not to rattle or buzz. I did also have to drill new holes as the tabs sat better where I drilled the holes. They sound great and fit very well behind the door cards though so I am very happy with the results.
    I hope this helps.
    Benj
    1998 UK MK2 1.8i in Black.
  • Tue, May 11 2010 23:32 In reply to
    • Mackers
      Tue, Nov 18 2008
    • Sunny Bangor N.Wales.
    • Posts 343
    Re: 8" door speakers for mk2.5?
     i made a "spacer" out of some 6mm MDF and put a 6x9" speaker in my doors instead, as i alredy had the infinity 6x9 speakers already and loved the sound,
    Mk 2 1.8is In Black.
  • Wed, Jun 2 2010 16:12 In reply to
    • neilmong
    • Posts 81
     Hello,
    Well I finally got round to installing my 8inch pioneer speakers in my Mk2.5.  Very straight forward, I just drilled small pilot holes and screwed them in.  I dynomated between the speaker/metal as well as behind the speaker.  These are being run directl from a 4 channel amp (behind the passenger seat), with the powered sub behind my seat there is some fantastic sounds.  All I need now is to install the speakers on the rear deck.
    http://i12.photobucket.com/albums/a228/neilmong/CIMG0908.jpg
    http://i12.photobucket.com/albums/a228/neilmong/CIMG0907.jpg
    http://i12.photobucket.com/albums/a228/neilmong/CIMG0415.jpg
    Neil
    P.S the speakers as sold on mx-5parts that just screw into the fittings are on ebay.
  • Wed, Jun 2 2010 16:13 In reply to
    • neilmong
    • Posts 81
     Sorry forgot to say the gold pic was a previouse Mk2 install.  The top two pics are the new ones.
    Neil
  • Mon, Dec 5 2011 14:10 In reply to
    • Wrongun
      Tue, Oct 18 2011
    • Posts 8
     Neilmong.
    Thanks for the info/posts.  I am about to upgrade with a JVC XR811 head unit and Pioneer 2003i 20cm speakers (no amp tho).
    Could you repost your photos of the doors, as they are no longer available and would be pretty helpful to me.  Did you fit the door speakers using pilot holes and self tappers?
    Also  - did you leave the OEM tweeters connected, or will it all sound better if they are disconnected? (I guess they are pretty cheap ones, and the Pioneers have tweeters)
    cheers
  • Mon, Dec 5 2011 14:46 In reply to
    • neilmong
    • Posts 81
     Hello Wrongun, I'm afraid I have lost the pics.  When you take the door card off you will see that the OEM speakers have a surround to hold them in place.  When the whole lot is removed you will be able to put the speaker direct into the hole.  I used self tapping screws and not the original holes.  I also put dynamat on the surface of the door and around the hole to absord rattles etc.  As you say you don't need the tweeters, I sold mine on ebay.  The sound difference is amazing.  Good luck and enjoy.
  • Mon, Dec 5 2011 14:53 In reply to
    • Wrongun
      Tue, Oct 18 2011
    • Posts 8
    No worries about the pictures..  I think I know what I have to do.   I am gunna hold onto the OEM stereo and speakers incase I sell the car and wanna keep the new stuff.  I dont have any dynamat, but if I have a vibration issue I will get some.
    cheers
  • Mon, Dec 19 2011 10:10 In reply to
    • Wrongun
      Tue, Oct 18 2011
    • Posts 8
     Hi,
    ICE upgrade upadate
    I fitted these at the weekend.   I ended up with the Pioneer 2013i 20cm (8") units.  These have a 4-hole pattern, so no drilling of the door was was required.  However, the speakers' Chassis (supporting the magnet), was too fat to fit the hole in the door.  I did get them in, but had to use spacers to mount the speakers about 5mm proud of the metalwork of the door.  Happily, the trim went back on ok, and they sound awesome, with no rattles etc.  The bass is very strong and tight, and the midrange clear.  Interestingly, my doors had no OEM tweeters in them, or even holes in which to mount them.  Is this normal for a Mk2.5?  Overall, very pleased with my JVC 811 XR and Pioneer 2013i combo.   Total cost was ~£260 including loom adaptor (all from Caraudiodirect).   I am planning to keep the old head unit and speakers and refit them if I sell/write off the car.
