Drain and filler plugs, sizes and torques---NA (MK1) NB (MK2)
Last post Tue, Mar 23 2010 7:17 by Geoff Walton. 0 replies.
Page 1 of 1 (1 items)
  • Tue, Mar 23 2010 7:17
    • Posts 11,082
    The washers are Mazda part number 9956-41-800, they come in packs of 5. They measure
    18.25mm id
    24mm od
    1.43mm thick [new thickness, the washer is aluminium and is designed to crush when the correct torque is applied].
    Torque should be:
    22-30ft/lb for the engine sump
    29-43 lb/ft for the gearbox drain, 18-29ft/lb for the filler
    29-40ft/lb  for the diff drain and filler/level plug
    Spanner sizes needed
    Engine sump 19mm
    Gearbox drain 24mm, fill/level 14mm open ended spanner, or 16mm bi-hexagonal ring spanner
    6 speed transmissions have a 24mm filler plug.
    It is advisable to crack off the filler plug before draining the oil as the plugs can be tight. Doing so avoids the danger of having drained the oil only to find you are unable replace it.
    You will need 24mm socket/spanner for the drain plug on the gear box & the differential, the filler plug on the differential is a 23mm. The filler plug on 5 speed transmissions is a square head plug which can removed using a 14mm open ended spanner or a 16mm bi-hexaganal ring spanner or socket. 6 speed transmissions have a 24mm filler plug.
