Renault Laguna Front Splitter
Last post Mon, Jun 11 2012 17:39 by Itsbirdietime. 17 replies.
Page 1 of 2 (18 items) 1 2 Next >
  • Mon, Dec 15 2008 20:41
    • redmazda
      Fri, Nov 21 2008
    • south wales valleys
    • Posts 550
    HI ANY POSTS ON FITTING A RENAULT LAGUNNA FRONT SPLITTER TO YOUR MX5 IVE READ IT A FEW MONTHS AGO BUT CANT FIND IT NOW ANY PHOTOS OR LINKS THANKS
    Previous mk1 eunos 1.6 classic red
    Now own
    Mk1 UK 1.6 1990 classic red with F.S.H
    E90 330 D BMW
    Fiat 500 1.2sport
    Winner of Raleigh Burner BOTY 2012
  • Mon, Dec 15 2008 23:07 In reply to
    • -halli-.
      Thu, Oct 23 2008
    • Posts 137
    Re: Renault Laguna Front Splitter
    My linguine splitter fitting thread on the old forum is here
    or, here it is in full:
    I bought a Laguna splitter off eBay last week. It was listed as muddy but in very good condition, however it was deeply scratched so needed some prep work. I sanded it with wet and dry and I might still fill the deeper gouges with filler.
    Before:
    Fitting it was a PITA. I made cuts around the corner parts, but it still bent and wasn't a perfect fit (anyone would think it had been made for a different car!) Plenty of self tappers later and a few screws repositioned later and this is the result (sorry about the quality of the pics, the camera was on the wrong setting and I didn't realise
    Lots of screws so it follows the contour of the bodywork
    A bit bendy on the bottom before the slits were cut on the underside and before the screws were tightened up properly.
    Done
    I need to cut a little bit more onto one side as I cut it 1/4 inch too short )
    I painted it with plastic primer and then satin black spray cans shortly after.
    And here is a more recent "arty" shot
    -halli- THIS IS MY GUEST ACCOUNT - I WON'T BE USING THE OC ACCOUNT UNTIL THE PRIVACY ISSUE IS RESOLVED ON THIS FORUM
    '90 Eunos Roadster 1.6 - SilverStone (The daily commute)
  • Tue, Dec 16 2008 14:28 In reply to
    • danielsdad
      Mon, Nov 17 2008
    • South Wales
    • Posts 110
    Hi do you know what year Laguna it was or if it was a Mk 1 or Mk 2
    IanCool
    1991 1.6 MX-5
    1999 10th Anniversary
    2002 BMW 320d
  • Tue, Dec 16 2008 22:02 In reply to
    • -halli-.
      Thu, Oct 23 2008
    • Posts 137
    Ian Forrester:
    I don't have a clue. I got it from eBay.
  • Tue, Dec 16 2008 22:28 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 550
    i just fitted renault laguna front splitter looks like it was made for the car ill get some photos next week posted it was the vented type off a 98 model recomend this mod
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
  • Tue, Dec 16 2008 22:30 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 550
    mk 1 vented off 98 model i just finished fitting mine looks great like it was made for the car get some photos on next week
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
  • Sat, Dec 20 2008 20:58 In reply to
    • HighLift
      Tue, Nov 18 2008
    • Portsmouth
    • Posts 122
     Just did this to mine.
    Top ghetto mod. Thumbs up for this threadYes
    splitter
    I know it's filthy, but dirty ones go faster.
    dirty BRG '95 1.8. Absolutely Shocks Gaz kit, BRP M45 coldside, MS diyPNP, 320cc's
  • Mon, Dec 22 2008 16:49 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 550
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
  • Mon, Dec 22 2008 16:53 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 550
    Click to view full size image  just fitted mine Click to view full size image
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
  • Mon, Dec 22 2008 22:04 In reply to
    • -halli-.
      Thu, Oct 23 2008
    • Posts 137
     Looks good, you just need to lift the bonnet, grab the headlight lids and pull them upwards until they are proud of the bonnet when it is closed, then push them back down again until flush Wink
  • Mon, Dec 22 2008 22:51 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 550
    Click to view full size image DOES THIS LOOK BETTER I PULLED LIGHT COVERS FROM BACK UP THEN CLOSED BONNET THERES NO BOLTS TO LOSEN IS IT THANKS
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
  • Tue, Dec 23 2008 23:23 In reply to
    • -halli-.
      Thu, Oct 23 2008
    • Posts 137
     Perfect Yes
  • Wed, Jan 13 2010 13:05 In reply to
    • nick_sub
      Wed, Jan 14 2009
    • Posts 35
     Just bought one of these (previously cut to size for the MX5) and am after some advice on how to fit it. Do you just use self tapping screws straight into the bumper or do you drill holes in the bumper and screw into some blocks of wood?
  • Wed, Jan 13 2010 17:37 In reply to
    • -halli-
      Thu, Oct 23 2008
    • Alnwick, Northumberland
    • Posts 595
    nick_sub:
    I drilled the bumper and the splitter and then used loads of hefty self tappers through the holes.
  • Wed, Jan 13 2010 17:50 In reply to
    • nick_sub
      Wed, Jan 14 2009
    • Posts 35
    Excellent, thanks.  Just got to go screw shopping and I have a nice job for the weekend...
