National Rally Chatsworth
Last post Thu, Sep 23 2010 9:32 by martin. 71 replies.
vin rouge
Wed, Nov 5 2008
- Hockley, Essex
- Posts 421
Re: National Rally Chatsworth
A14 and Broads sounds good to us! We use the A14 a lot to go to the Midlands.
Eric, being a late booker yourself are you in the house or Marquee for the Pie and Pea supper? Just thought a man in your position may get certain privileges!!!
'96 Merlot
MX-Drew
- Canvey, Essex
- Posts 1,070
eric (et):
I wouldn't dream of trying to pull rank The rules say tickets up to 300 are in the marquee and the rest are in the building, so I guess that's where I'll be along with the rest of the late bookers. As long as there's a bar, who cares.
Did you book a seat on the coach?
I'm not sure I did, better get my Pa on to it.
Brain, my car is need of a polish by the way
If it's broken, repair and improve it. If it an't broken, just improve it. Mk2.5 1.8 2004 Strato Blue. Coldside MP62 supercharger & Air Con & Eibach Lowering Springs (all fitted myself). bastienw said "Je reste bouche bée par la NB à compresseur !!!!" Translated "I remain stunned by the compressor NB!!"
montymaster
Tue, Jan 26 2010
- billericay essex
- Posts 56
Having ventured that way in July can suggest a route avoiding a lot of busy A roads. Venture over to the A10 via Harlow, follow up to Royston and straight north via Papworth to Godmanchester. Short stretch on A14 come off at Alconbury and drive beside A1M to Norman's Cross. Back on A1 (Stibbington Services has a good greasy spoon - where Monty broke down!) to A47 (Leicester) turn follow towards Duddington - right turn to Collyweston, Ketton and thru to A606 on B roads, go past Rutland water, bypass Oakham, at Melton take A6006 towards Ashfordby amd follow till you reach the A6. (close to East Midlands Airport.) From there you can get on the M1 up to Chesterfield or take A roads around Derby or Nottingham.
Hope this helps
See you Sunday
Allie
5UMO
Tue, Nov 18 2008
- WICKFORD
- Posts 786
Just looking at a route that i came back on last year from Macclesfield.
M11 /A14 to St Ives, B1040 to Ramsey St mary, B1443 to Stamford, A606 to Rutland Water onto Melton Mowbray, A609 to Belper, A6 to Matlock and then onto Chatsworth / Bakewell.....Simples. ???
5UMO
MK1 1.8is 1997 BRG Member of The Glorious Green Gang MK2.5 sport 2001 Supreme Blue Member of the Blue brigade
Izzy
Wed, Sep 1 2010
- Billericay
- Posts 7
Hi Eric,
Alex and I will be setting off on the 18th and booked into the Legacy Chesterfield Hotel. Not sure what time we are starting off as yet. We are also attending the P&P dinner.
Thinking of doing the afternoon drive once we get to Chatsworth.
Regards,
Izzy
Little Calvin (my obsession): So far, front grill, MK1 style rear side reflectors, front strut brace, cabin brace, wind deflector, wooden Nardi steering wheel, gear knob and handbrake sleeve.
MX-Drew
- Canvey, Essex
- Posts 1,070
5UMO:
And he was only going in to Basildon!
MX5Joy
Wed, Nov 19 2008
- Essex
- Posts 356
Add me to the list for Sunday, hopefully I will find you. I am only travelling from Glossop so no Sat Nav needed.
MX5Joy
MX5 my medicine of choice
eric (et)
Thu, Oct 30 2008
- Maldon, Essex
- Posts 884
MX5Joy:
Hi Joy. Suggest you start at the Merchandise tent. Drew, Dee and no doubt some NT helpers will be around there.
Eric (ET) - Eric Terry Coordinator - North Thames Region 2007 Mk3 1.8 Icon in Stormy Blue Mica, Splash Guards, Eibach lowering kit. Blue Brigade. http://www.nt-mx5oc.co.uk/
5UMO
Tue, Nov 18 2008
- WICKFORD
- Posts 786
MX-Drew:
5UMO:
I was trying to find my way home from work ??
5UMO
vin rouge
Wed, Nov 5 2008
- Hockley, Essex
- Posts 421
Paul (10AE),
Are you going to th Pie and Pea supper?
I notice on one of your other posts that you were considering it and were told you would probably not be in the Marquee; well just to let you know that Paula and I were too late in booking so our tickets are numbered over 300 therefore we are in the overflow room and not in the house with the rest of the NT rif raf!
So, did you send off for the tickets in the end and if so have you got high (over 300) number/s???
'96 Merlot
my 10 ae
Thu, May 28 2009
- Rochford, Essex
- Posts 116
Hello Brian,
Yes I did contact Pete about the pie and pea supper and apparently I'm not too late book myself in, so once I've filled in the booking form I'll send it off in the next couple of days. So I'm affraid you're all going to have to put up with me for the evening!! Just hoping the weather improves a bit!!
P.S. Are you (and the family) going on the Hendon run? If so I'll see you at the A127 diner for 9am Sunday.
Paul.
vin rouge
Wed, Nov 5 2008
- Hockley, Essex
- Posts 421
The plan is now that it will be me and one of the 'small annoying people' coming to Hendon.
At least I'll know one person at the pie and pea supper in the overflow room if you're only just sending off for ticket/s now!
Will it be just yourself or will your newly found 'ladyfriend' be joining you for a romantic getaway in your tent?
'96 Merlot
