Air vent balls Mk1
Last post Sat, Sep 4 2010 13:31 by hotjazz.co.uk. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Sep 2 2010 12:26
    Air vent balls Mk1
     My air vent balls have become so lose that on 2 or more blow they keep just facing down, can anyone suggest how they can be tighted?
    thanks
    SR Limited 1997
    Eunos Roadster Mk1
    Sparkle Green
    Eunos Roadster
    SU Red 1991
    Eunos Roadster
    1995 VR LTD comb A
    art Vin Rouge
    WATCH THIS SPACE !!
  • Thu, Sep 2 2010 12:39 In reply to
    • Proby
      Wed, Mar 10 2010
    • Fleet, Hampshire, UK
    • Posts 23
    Re: Air vent balls Mk1
     I have the exact same problem but mine are slightly worse.  Hope someon has the answer!
    Car:- Mk1 1995 1.8i s BRG
  • Thu, Sep 2 2010 12:48 In reply to
    • niggle
      Fri, May 29 2009
    • Posts 2,652
    • Moderator
    The Forum Search tool is your friend. Wink
    http://www.mx5oc.co.uk/forum/forums/t/19762.aspx
     Try This
    http://www.miata.net/garage/AirVent.html
    I would not use this method to remove them though, i would loop a piece of wire of rope through the middle and pull gently first, they can be very tight and you may need a combination of the two methods two release them, be careful!
    Well i'm not the kind to kiss and tell, but i've been seen in a mk2......
  • Thu, Sep 2 2010 23:14 In reply to
    Pretty easy - get a long cable tie, put a bend in the end and post the folded-back tie down one of the inside holes of the vent, with the cabletie held so that as it goes through the hole and expands, the short end is facing the outside edge.  Pull it back and you should have a cable tie wrapped around the vent.  Click it together to make a convenient handle, then repeat the process so you have 2 evenly spaced cable tie loops on the vent.  Jerk it hard towards you.  Central vents can be a bugger to get out so worth bracing the center console with your hand to prevent flexing.
    Once out, file the metal clips on the inside of the holes with emery paper and give them a shot of silicone spray lube to make it easier next time.
    When you've got them out, you can carefully split the balls from the surrounding tube and you'll notice the foam pads have gone flat.  You can pad with small strips of electrical tape.
    If you can't separate ball from tube, then just rotate ball as far as it can go in one direction and apply a small strip (about 5mmx20mm) to the side of it to achieve the same effect.
  • Fri, Sep 3 2010 6:50 In reply to
     They just need taking apart and cleaning,to bring the pile back to life on the felt.
    The Disclaimer:-...This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects, the articles/answers/comments are provided for information purposes and they are not intended to substitute informed professional advice, I /or the Mx5 owners club can not personally be held responsible for any damage occurred from following this procedure or any injuries from it. Proceed at your own risk.
    http://www.mazda-mender.co.uk/
  • Sat, Sep 4 2010 13:31 In reply to
     Thanks for all the advice on my vent balls, must remember to check forum notes also in future.
    SR Limited 1997
    Eunos Roadster Mk1
    Sparkle Green
    Eunos Roadster
    SU Red 1991
    Eunos Roadster
    1995 VR LTD comb A
    art Vin Rouge
    WATCH THIS SPACE !!
