Issues following upgrade?
Last post Sat, Feb 14 2009 23:49 by Geoff Walton. 55 replies.
Page 4 of 4 (56 items) < Previous 1 2 3 4
  • Thu, Jan 29 2009 22:55 In reply to
    • 01mx5
      Thu, Jan 8 2009
    • Central Scotland
    • Posts 3,053
    • Committee
      System Developer
    Re: Issues following upgrade?
    I just meant that they seemed to sneak in under the forum's "not read" radar Smile
    Ramsay Ashby - Website & Forum Administrator
    Green 1991 Limited Edition BBR Turbo
  • Fri, Feb 13 2009 15:55 In reply to
    • miss montana
      Mon, Jan 19 2009
    • east sussex
    • Posts 9
    hi martin - have tried everything you suggest - history deleting cookies etc -
    but can only log in as a forum member only and not as an
    oc member - message tells me my forum
    account is not activated and can only view forums.
    solutions on a postcard please!!!!!!!!!!
    tania
    mine is the one on the right!!
  • Fri, Feb 13 2009 16:52 In reply to
    • 01mx5
      Thu, Jan 8 2009
    • Central Scotland
    • Posts 3,053
    • Committee
      System Developer
    I've sent you a PM Tania
    If anybody else has this issue, please let me know and we can sort it Yes
  • Sat, Feb 14 2009 0:12 In reply to
    • Goof
    • Leicestershire
    • Posts 1,048
     Still having to "Sign In" on every visit - same on 3very different PCs.
    No MX5 - waiting for the right S2000
  • Sat, Feb 14 2009 3:18 In reply to
    • Posts 11,081
    Goof:
    This is the same for me since changing to Fire Fox, however it does it with all the forums I use
  • Sat, Feb 14 2009 11:57 In reply to
    • Goof
    • Leicestershire
    • Posts 1,048
     Same for me in I.E.
  • Sat, Feb 14 2009 12:49 In reply to
    • miss montana
      Mon, Jan 19 2009
    • east sussex
    • Posts 9
    i have done everything suggested.
     when i tried to sign in today it would not accept
    my password so had to request a new one.
     ok - i am putting my hands up (in extreme exasperation)
    i give in!!!!
  • Sat, Feb 14 2009 16:15 In reply to
    • 01mx5
      Thu, Jan 8 2009
    • Central Scotland
    • Posts 3,053
    • Committee
      System Developer
    I think the password thing was my fault from trying to sort it Embarrassed
    Were you able to change it back OK though?
  • Sat, Feb 14 2009 17:00 In reply to
    • fraserj
      Mon, Nov 17 2008
    • Posts 61
    Any chance we can re-visit "Mark all Forums Read"? I find that I am using this forum less since this facility was lost.
    His:|2002 1.8i Sport Sunlight Silver|Body Kit|Lots of Chrome bits|
    Hers:|2003 1.8i Sport Mica Green|Lots of Chrome bits|
  • Sat, Feb 14 2009 21:20 In reply to
    • 01mx5
      Thu, Jan 8 2009
    • Central Scotland
    • Posts 3,053
    • Committee
      System Developer
    fraserj:
    It might get released in our next update - but I'm not too hopeful to be honest. It should be reasonably simple, but there is possibly a glitch in the forum's code that will do the opposite. You would think it would be a simple fix, but it surprisingly isn't - however, it might not impact our version of the software - fingers crossed.
    Right now you have 4 options;
    1) Live with loads of unread posts, and take advantage of it when there are no posts of interest to you
    2) There is a dropdown box at the top of the 'not read' page, that allows you to specify a timescale, or since you last logged in
    3) Use this short term solution
    4) Go in to each forum in turn, and click the 'mark all posts read' button at the bottom. It will take an age, but you will feel an enormous sense of achievement at the end!
    EDIT:
    5) Read up and learn more about the MX5 than you ever thought possible Big Smile
  • Sat, Feb 14 2009 23:49 In reply to
    • Posts 11,081
    fraserj:
    Change your browser to Firefox. I hesitated for a couple of years, til the issues with this forum forced my hand. I wish I hadn't lost two years of easy browsing. There are a couple of workrounds published by a forum member, one gives you all posts read and the other gets rid of the broad wasted bands on each forum page. The only issue I have with FF is a log in problem on some the forums I use. I think that the login problem on this forum is common to others using the same engine.
