what polisher to use
Last post Tue, Feb 10 2009 11:14 by Madboy. 8 replies.
Pollyanna
- Northallerton, North Yorkshire
- Posts 3,207
Gary Beale
Tue, Nov 18 2008
- Preston U.K
- Posts 3,218
I have borrowed one of these and spent ages trying to get the glass finish without the same results as hand polishing ( I have clayed the car). I must be doing something wrong! are there any posts on how to use these polishers in the correct manner?
SUPPORT THE TROOPS, DON'T FORGET THEM!You're only supposed to blow the bloody doors off!Founder Member of the MX5 Blue Brigade.Member of the Originals1991 Eunos Roadster in Mariner Blue. Rear Spoiler, L.E.D Sidelights, American Dream Headrest Speakers, Lexus Rear Lights, Hard Top, Style Bars, Flash to Pass, Dee[ dish Steering Wheel, K&N Air Filter, Magnacor 8mm HT Leads, LSD, Strut Brace, SS Exhaust, Decat, LED running lights, Front Splitter, Deep Dish MOMO Steering Wheel and hour upon hour spent polishing etc.....
Pollyanna
- Posts 3,207
I would be be careful when "polishing" your car if you have no experience of polishers. The main reason being that the thickness of paint is not that much and you could easily cut right through it.
When I resprayed my car, Classic Red, I used a two part paint and it got four coats of paint. This paint is very good paint and one spray coat covers any thing that is on the body for instance, primer showing thro the top coat and other shades of paint due to the flatting of the original paint, unlike cellulose paint. As a result I had plenty of paint thickness to work with. There are different grades of polishing heads with different grades of compounds you can use with these polishers. Suffice to say that a good glass finish requires finer and finer grades of head and compounds, and then you can use an orbital sander with very, very, very fine abrasive pads that will get the finish even better before the final polishing and waxing etc.
b0builder
Fri, Nov 7 2008
- Rossendale
- Posts 113
so what you are telling me is surely for polishing out the imperfection in a new paint job i am only looking to get rid of swirl mark and give the car a good wax and polish.
Should i them not be using a polisher at all and only doing it by hand??
I understand that the paint is not the thickest on the car and i understand the dangers in using a polisher and i will be careful this is why i asked what polisher should i get.
If it is the case i need to pay the price of a good one i will do so but i was asking is their is one that did the same job for less money.
mk1 60,000 uk car puedrive shocks mspnp ecu lc1 new bushes all-round rota gt3's prada spec 2 tyre 1.8 upgraded brakes with greenstuff pads mx5 dual exhaust braided brake pipes begi-s turbo with intercooler 550cc injectors 3.6 lsd and a empty wallet but a big smile on my face
Pollyanna
- Posts 3,207
b0builder:
I bought my variable speed polisher for £40.00 from a Kit Car show two years ago and when using it with the correct pads and compounds it does the job.
A friend of mine has come across the very smooth abrasive pads that are used on a good quality Orbital sander. They are "stuck" on with Velcro.
They are not cheap to buy but I can find out the price and where he bought them from, but you will need the Orbital Sander to use them. These are very fine abrasive, Eqivalent to P2000 I think, and I am sure will remove swirl rings as he has done part of his own Jaguar car with them. I will find out about them them if you would like me to. When the fine weather comes I am going to re-buff my car with these pads and then polish the car with Softer pads and polishes etc.
Stockna
Mon, Jan 26 2009
- Posts 37
By hand is the best method. I use brasso. Nothing else achieves that depth of shine. Machines are time-saving devices for the pro-valeter. When you've Brasso'd your car I can honestly say I'm sure you'll never go back to any other method.
Pete
Nice But
Sat, Nov 15 2008
- Solihull - to be Brixham Devon mid 09 Wohoo!
- Posts 196
A G220 and the correct process of polishes/glazes and waxes will shift all but the most stubborn imperfections in the paint, as Pollyana says though an orbital polisher will burn through the paint in seconds.........
I'm a novice detailer and have had some superb results correcting paint swirls/holograms etc with it on various cars. I've bought pink cars back to red as well.
What would be one of the best things fpr you to use is a non machine glaze with fiillers i.e. Autoglym super resin polish this has minor fillers in it so if you polish it hard by hand so that it goes clear then it should fill some of the swirls...... then use a good Carnuba wax based polish and put on several coats letting it harden in between them, then your car should drip gloss..... hope that helps. Halfords sell a Mequires carnuba based wax IIRC alternatively have a look at the various Detailing websites...... a word of warning though..... it's addictive and ends up costing a fortune.
Tim Mk3 Launch Edition 2.0 with Eibach springs, Racing Beat exhaust and some more shiney bits No.221/300 UK - 1218/3500 Worldwide Mk1 1.6 MX-5 1990 Classic Red - SOLD and missed2into.co.uk
Madboy
Tue, Nov 18 2008
- Coatbridge, Scotland
- Posts 232
Stockna:
Pete
Sorry for slightly off topic but Brasso????? Tell me more please
Without the bitter, the sweet just aint as sweet
Page 1 of 1 (9 items)
