Turbo or Supercharger?
Last post Fri, May 18 2012 12:45 by Sven. 30 replies.
Page 1 of 3 (31 items) 1 2 3 Next >
  • Fri, Jul 15 2011 17:25
    • oldmanaustin
      Sat, Mar 28 2009
    • Bradford
    • Posts 17
    Can anyone help a simple question Turbo or Supercharger?
    I have a 2003 1.8svt
    And can any recomend anyone in the Bradford area to fit 1?
    Ian
    Bradford
    2003 1.8 SVT
  • Sat, Jul 16 2011 0:37 In reply to
    • Posts 11,139
    Re: Turbo or Supercharger?
    G'day Ian
    That's a bit like asking which type of baked beans you prefer, or Heineken V Fosters. Anyone who has gone the FI route will have done so for different reasons. The best way to find out which suits you is to get a ride in both. Talk to the area coordinator of the local Owners Club [ Neil ] He's got a turbo Mk 1 and I'm pretty shure that there is at least one supercharged car in the Yorkshire ridings
    Here's some details on contacting Neil
      Yorkshire Ridings
    http://YR.mx5oc.co.uk
    The Yorkshire Ridings MX-5 Owners Club: All are welcome - try it - like it - come again!  Our motto says it all, Yorkshire Ridings “We're Having a Laugh!”  In 2008, we will have another full events list but will also be busy preparing to host the 2009 Spring Rally.  We continue to make best use of the roads, countryside and coastline our area is blessed with and occasionally dip into neighbouring areas as a single club or on joint ventures. Drives are normally on a Sunday, once a month in winter and twice in summer, social evenings are on the second Wednesday of the month and we always endeavour to have a club presence at the Nationals. For further details check the links below or go direct to our area website using the link above.
    Co-ordinator(s):
    Neill Harrop
    01535-652231
  • Mon, Jul 18 2011 9:22 In reply to
    Try to get a passenger ride in each kind, then find out how much each installation cost. If you like the experience and can afford the one you prefer then go for it.
    Both types of forced induction work well - there is no right or wrong solution. Geoff has a supercharger, I have a turbo, we're both very happy.
    The budgets for installation for either can run from a few hundred pounds (if you go for secondhand parts and can do a bit of fabrication) to several thousand pounds for off-the-shelf kits. If you aren't handy with spanners it gets expensive.
  • Mon, Jul 18 2011 9:59 In reply to
    • Elvie
      Sat, Jun 11 2011
    • Penrith, Cumbria
    • Posts 394
    I'd ask myself why I would want one at all. Not to diss either you understand - I'm a fan of both - but just because a turbocharger and supercharger have different characteristics in how they develop their power. I've always found turbos more exciting because power comes in later in the revband whereas s/c power delivery is more linear. But having asked this question myself already (because you never stop spending money on these things, do you) I've figured that if its just more power I want, a nice, sweet, tuned, lightweight 5 would be ample.
    Thought about a V8 at all?
    Never, ever have I bloody ever anything!
    1991 MX5 Eunos
    1997 VFR750FV - the last of the 750's
    1967 Royal Enfield Bullet
  • Mon, Jul 18 2011 10:07 In reply to
    Elvie:
    Good point. I had to add power to mine (the championship I was in moved to bigger, faster tracks and my car was already the slowest thing competing). It's faster now but it's not really any more fun to drive on the road.
    Elvie:
    Ha. I've done a V8 swap and fitting a turbo is much easier.
  • Mon, Jul 18 2011 17:36 In reply to
     If you can wait till the National Rally you can try my Mini s/charger powered car
    Very smooth linear power delivery...great noise...good MPG off boost...easy to fit.
    190 BHP ...0-60 in 6.5 0-100 in 17.7
    http://www.youtube.com/watch?v=RN-5GChcYqk
    Max5 Mk3 race car 42 sponsored by
    http://www.brynhilton.co.uk/
    www.masbars.co.uk
  • Fri, Jul 22 2011 13:31 In reply to
    • skir67
      Tue, Nov 25 2008
    • Merseyside
    • Posts 295
     turbo power can be pretty linear if you use the right size turbo, something like a T2554 on a 5 works well. Threshold is about 2krpm so low and from where you need it. A larger turbo may have a treshold of 3k rpm for example which might be a bit less useable for normal road use.
  • Fri, Jul 22 2011 14:43 In reply to
    • Posts 4,479
    for ultimate power go for turbo, for better driveability go supercharger (no lag and hence sudden rear end breakaways coming off roundabouts) you may sacrifice a bit of power overall but its nicer to drive.
    Dr. EunosGeek
  • Sat, Aug 27 2011 22:37 In reply to
    Locke-alike:
    Just watched your vid, sure looks like fun and loving the charger wineBig Smile.
    What setup are you using for the video and telemetry? does it work by gps for the track map?
    Steve.
    Im in the Sunday morning Sideways
    1993 Eunos V-special 1.6 Racing Green
    Miester R coilovers, Larini exhaust,
    FM2 Turbo (to be fitted)
  • Sat, Aug 27 2011 22:54 In reply to
    • Gary Beale
      Tue, Nov 18 2008
    • Preston U.K
    • Posts 3,241
    Geoff Walton:
    shure
    Have you already stopped using the ENGLISH language!...........................LOLBig Smile
    SUPPORT THE TROOPS, DON'T FORGET THEM!
    You're only supposed to blow the bloody doors off!
    Founder Member of the MX5 Blue Brigade.
    Member of the Originals
    1991 Eunos Roadster in Mariner Blue. Rear Spoiler, L.E.D Sidelights, American Dream Headrest Speakers, Lexus Rear Lights, Hard Top, Style Bars, Flash to Pass, Dee[ dish Steering Wheel, K&N Air Filter, Magnacor 8mm HT Leads, LSD, Strut Brace, SS Exhaust, Decat, LED running lights, Front Splitter, Deep Dish MOMO Steering Wheel and hour upon hour spent polishing etc.....
  • Sun, Aug 28 2011 7:55 In reply to
    • 60Rod
      Sat, Sep 4 2010
    • Posts 266
    Hi Ian,
    If you not already found the Forum it might be worth taking a look on http://www.mx5nutz.com
    Rod
    The poodle is the proud owner of a 1990 Mk1 Eunos in Silver Stone, invisibility, paint. I just get to drive it for him as he can not reach the pedals. We live in Prestatyn, North Wales.
    Member of the Old Gits Clan (Me not the Poodle) and the Bunch of Fives.
  • Tue, Aug 30 2011 16:51 In reply to
     Turbos are often more powerful - its easier to turn up boost (within limits!) than swapping pulleys etc. I've standard FM 2 turbo running at stock 12psi and ran fastest 1/4 mile at the OC Spring rally at Elvington. I fluffed second to third gear change (it hit the rev limiter so quickly that I didn't have time to react!) so almost certainly could have been quicker but still turned in 14.2 seconds 1/4 mile and terminal speed of 108mph - my first and only attempt! My car isn't by any means the most powerful out there and a better driver (or driving someone else's car because I had visions of a new clutch or rear end before dumping the clutch) would have been quicker. But still not bad for a 21 year old car!
  • Thu, Sep 22 2011 10:07 In reply to
    stevetkocz@yahoo.co.uk:
    Locke-alike:
    Steve.
     Simple JVC Elverio camera
    Performance box for the data logging
    RacechronoAVI for the digi dash overlay
    and Corel video studio to edit all together...the PB does ideed use a very accurate  (20Hz) gps unit
    I can look at my lines thru every corner with each lap to see if one is quicker than another...but thats more for when im racing
    The racechronoAVI works with a lot of mobile phones fitted with GPS...so you could just strap your phone to the car and record that way.
    www.masbars.co.uk
  • Fri, Dec 2 2011 13:49 In reply to
    • Rob Morgan
      Mon, Sep 28 2009
    • Wrexham
    • Posts 209
    I have been asking myself this question for ages! I have very little knowledge on FI, all i have ever owned are n/a petrol cars.
    I'd like to throw some questions in:
    1. which is better £/bhp or are they similar?
    2. i'm guessing that a SC would offer better reliability? is this true?
    3.what are servicing costs on SC and turbo's? i.e. re-building etc. Please note, i know very little, so i am just going off things i've heard.
    Silver 1991 Eunos 1.6 is now laguna blue ;o)
    White 1991 Eunos 1.6 has gone to the scrapyard in the sky, afetr being written off :o( i am breaking it for parts
  • Fri, Dec 2 2011 14:39 In reply to
    • MrChrome
      Wed, Aug 31 2011
    • Somewhere Peaceful.....
    • Posts 325
    taff eunos:
    Dr. EunosGeek
    I Agree
    Whoever undertakes to set himself up as a judge of Truth and Knowledge is shipwrecked by the laughter of the gods.
    Great spirits have always encountered violent opposition from mediocre minds.
    Logic will get you from A to B. Imagination will take you everywhere..
    I'm a Mazda Mender - www.mazdamenders.net
