Another high idle post - when hot, sits at 1500 rpm for 10 seconds before dropping down to normal
Last post Wed, May 30 2012 20:22 by victormeldrew. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Wed, Sep 21 2011 15:26
    • purps
      Tue, Jun 9 2009
    • Blackwater, Camberley
    • Posts 200
    Hi all, I've read a few posts about high idles, but I wasn't sure if they were relevant to my problem.
    When I come to a halt at a junction or whatever (engine hot) the revs sit at 1,500 rpm for about 10 seconds, sometimes less. The revs then quickly and abruptly drop down to normal. The car feels completely normal to drive, better than ever in fact.
    I had a slightly erratic idle in the past, but I have since cleaned the intakes, changed the ignition leads and sparks, and the coolant and engine oil if that's relevant. This has made everything a lot smoother, definite improvement, but now I have this new problem. The only(?) bone-headed thing that I may have done is adjust the idle without shorting the relevant pins in the diagnostic connector.
    Any pointers very much appeciated as always!
    Cheers, Matt.
    http://projectsofmatt.wordpress.com/
    1991 Mk1 Roadster 1600 cc
    Special Edition (189 of 250)
    British Racing Green with Tan Hood & Interior
  • Thu, Sep 22 2011 12:29 In reply to
    • Taxieunos
      Sun, Aug 21 2011
    • Norfolk
    • Posts 97
    Re: Another high idle post - when hot, sits at 1500 rpm for 10 seconds before dropping down to normal
     Are there any fault codes showing?
    Most high idle problems can be traced to a faulty coolant temperature sensor.
    1991 Eunos 1.6 in my favourite colour.. Red.
  • Mon, Oct 3 2011 21:38 In reply to
    • MikeSmith
      Sat, Jun 6 2009
    • South Central
    • Posts 12
     Hi Matt,
    I have exactly the same problem and haven't found a solution yet.  Would you let me know if you find the answer?  I will do likewise.
    Mike
  • Tue, Oct 4 2011 11:02 In reply to
    • purps
      Tue, Jun 9 2009
    • Posts 200
    Taxieunos, apologies, I really should have checked for fault codes before I posted, I will try to do it this weekend.
    MikeSmith, I will certainly keep you updated. You should do a diagnostic as well :) http://www.mx5oc.co.uk/forum/forums/t/204.aspx I'm going to make a list of things that it COULD be also, based on other posts that report idle problems, purely because I don't have a clue what it could be.
    I'm fairly sure it is affecting the engine during normal operation now as well (or maybe I just didn't notice it before), it feels like there is a slight loss of power when pulling away sometimes, but that could be my imaginiation.
    Cheers, Matt.
  • Tue, Oct 4 2011 11:39 In reply to
    • Taxieunos
      Sun, Aug 21 2011
    • Norfolk
    • Posts 97
    purps:
    Cheers, Matt.
    Have you re-adjusted with the pins shorted?
    If so my money is still on coolant temp sensor.
    If not then i'd give the re-adjustment a go.
  • Tue, Oct 4 2011 14:01 In reply to
    • purps
      Tue, Jun 9 2009
    • Posts 200
    OK, I will clear the fault codes and then re-adjust with the pins shorted, and try that for a few days. I will definitely do a diagnostic though whatever happens.
    Interesting that are putting your money on the coolant temp sensor. I did change the coolant whilst the car was the off the road, which was when the problems started (maybe relevant). It's on the back of the engine isn't it? I don't know where exactly. I'm wondering if I have damaged it or upset it somehow.
  • Tue, Oct 4 2011 14:51 In reply to
    • Taxieunos
      Sun, Aug 21 2011
    • Norfolk
    • Posts 97
     Perhaps you stirred up some crud in the cooling system which has got stuck on the sensor or perhaps it's just one of those things. The sensor is on the back by the bulk head. Coil pack off job to make access easy. Hope it works out.
  • Wed, Oct 5 2011 18:59 In reply to
    • MikeSmith
      Sat, Jun 6 2009
    • South Central
    • Posts 12
    Interesting - I could have damaged the coolant temperature sensor because I was removing the clutch and could have easily bashed it.
    Mike
  • Wed, Oct 5 2011 20:02 In reply to
    • Broadspeed
      Tue, Apr 12 2011
    • Stafford
    • Posts 107
    Hiya we have a lot of problems with this at the garage it`s the thermo resister switch on the back of the cylinder head it feeds info to the ecu change it disconect the battery and it sould be fine.
    Hope this helps [if not ring me 01785 252423]
    Best regards.
    Chris @ Broadspeed.
    1995 MX-5 California 1800 No 52.
    www.broadspeedmx5.co.uk
    Proud to be a yellow peril
  • Thu, Oct 6 2011 22:41 In reply to
    • MikeSmith
      Sat, Jun 6 2009
    • South Central
    • Posts 12
    Thanks Chris, I carried out a diagnostic test but it didn't show up a fault. I'll certainly try the thermo-resister.
    Regards,
    Mike
  • Sat, Oct 15 2011 20:22 In reply to
    • MikeSmith
      Sat, Jun 6 2009
    • South Central
    • Posts 12
    Hi Chris,
    Changed the thermo resistor but no improvement.  I had the exhaust system completely removed during work on the clutch so both the sensors in the manifold and the cat were removed.  Could it be anything to do with these?  I note that anything putting load on the engine increases revs to 1500 rpm for around 10seconds aswell.  Is that a clue?
    Best Regards
    Mike
  • Sun, Oct 16 2011 10:46 In reply to
    • ralphfcooke
    • Southampton
    • Posts 108
    When you cleaned the intake system did you use any solvent cleaner near the the throttle butterfly? If so it's possible that you stripped off the coating near the edge. If you did then you will need to adjust the throttle stop to bring the natural idle back to the 'normal position.
  • Tue, Oct 18 2011 16:48 In reply to
    • purps
      Tue, Jun 9 2009
    • Posts 200
    I shorted the magic pins in the diagnostic connector and re-adjusted my idle back down - whilst I have may have set the idle too low now (it struggles to start sometimes on these cold mornings we've been having recently), it does seem to have solved the high idle problem. I will report back if anything changes, but it seems OK now. I've just bough a hand-held tach, I will set the idle speed properly when it arrives.
    ralphfcooke, correct me if I am wrong, but that wouldn't explain why the high idle is only temporary - it drops back down to normal levels if left for a few secounds.
    Mike, you are describing exactly what I saw - put any load on the engine, and it would jump back up to the high level. If I was in slow moving traffic without my foot on the throttle, it would still sit at the high idle whilst pulling the car along obviously. Apply the brakes, forcing the revs down essentially, then declutch, they would jump back up again. I also tried (in the name of science) letting the clutch out a little with the hand brake on, to "force" the revs down this way, but they would always return to high again. Just to be clear, in every case, the revs would drop back down to normal again after 4 - 10 seconds. Do your revs still return to normal if left long enough?
  • Mon, Oct 24 2011 20:56 In reply to
    • Broadspeed
      Tue, Apr 12 2011
    • Stafford
    • Posts 107
    Hi mike.
    Sorry for late reply how do you check for fault codes, does the vehicle have A/C when you say putting load on the engine ie turning on electrics ?
    Regards Chris.
  • Mon, Oct 24 2011 21:41 In reply to
    • purps
      Tue, Jun 9 2009
    • Posts 200
