A
Aerial Fuse MK1
AFM repair NA
Air
con re gas the facts MK1 MK2
Alarms
& immobilisers as standard?
Automatic
gearbox oil level
Air Bag Flash Codes
B
Battery
chargers
Battery, need a new one?
Base
idle- How
to set -MK1/MK2
BHP
figures 1.6 engine MK1
Big ends, replace,
engine in car NA, MK1
Bling
your engine bay
BMW E
36 Clock wiring
Brake
disc Remove a stubborn one NA NB
Brake
Disc/Pad Size Guide
Brake
fluid Change the
Brake fluid explained
Brake
fluid, type and quantity
Brake
fluid-change-MK1 MK2
Brake
pads replace on Mk3 NC
Brake
pads replace--MK1 MK2
Brake hoses replace MK1 MK2
Bulbs--MK1
Bumper removal Mk 2.5
C
Cam
Cover Gasket
Cambelt
change, and other bits part numbers--MK1
Cambelt
removal
CAS O
Ring-Change-MK1
Centre console surround remove/replace--MK1
Chrome fuel filler flap fitting
Clutch
Judder--MK2
Clutch slave cylinder & cure that squeak Mk1
Mk2
Clutch switch
Coil
Overs (definition
Coldside
airfilter kit--MK2.5
Coolant types [Mazda]
Coolant change
Cooling
problems water loss
Crankshafts Identify
short and long nosed with pics of pulleys
Crankshaft
problem--MK2
D
Data link connector
Diagnostic box layout and use of diode to check fault codes
MK1
Diff - Mazda recommended oil
Differences
between Mk 2 and Mk2.5
Dim/dip UK Mk1 with abs
Door
lock spring problem
Door-to-body
weatherseal - a few tips
Download
Forum PDFs
Dr Bobs back catalogue
Drain and fill plug sizes
Drain holes in sills and behind seats
Drain
tube fit without roof removal
E
Electric
Windows - Stuck
Electric window problems
Electrical
Circuit Diagrams 1990 to 2000
Engine
build differences between 115 & 90 bhp-- MK1
Engine, interference or
not?MK1 MK2
Engine
oil change--MK1 MK2
Engine
Start button Fit
Engine stalls
Engine
turns over, but does not fireMK2
EOBD DTC download
Eunos
Roadster's Production DateMK1
F
Fault
codes clear MK1 MK2
Fifth
gear Problems selecting Mk1 Mk2
Flash to Pass mod
Front wing replacement Mk2
Fuses
and relays again Mk1
Fuses
and relays--MK1 MK2
Fuse-change
80 amp-MK1 MK2
G
Gaz
shocks FAQ's
Gear
knob thread--MK1 MK2
Gearbox & differential drain/filler plug sizes inc.
torque figures
Gearbox noise-MK3
Gearbox oil change 5 speed
Gearbox
remove & refit - Some tips
Gearlever
seals/boots
Gearlever
turret 6 speed--MK2
Geometry undressed.. Explanation:- part 2 "chassis
frequency"
Geometry undressed... Explanation:- part 1.....
"Humans"
Geometry undressed....Explanation:- part3
"Geometry"
H
Handbrake Adjust/repair, includes rear calipers
Handbrake
and rear calipers
Hardtop
will Mk1 fit a mk2 and 2.5?--MK1 MK2
Hardtop
fit
Headlamp
units-change-MK1
Heated
Rear Window Switch Wiring
Heated Rear Window Components (fitting of)
Heater
air pipes--MK1
Heater
contols lighting--MK1
Heater matrix removal Mk1 NA
HID lights
High startup idle---one cause Idle Air Control valve--MK1 NB
HLA
clatter, clicking,ticking--MK1
HLA faq
Hood
suppliers
Hydraulic
Lash Adjusters HLAs or Shims--MK1 MK2
I
Idle
speed inspection/adjustment--MK1/MK2
Ignition
timing inspection/adjustment--MK1
Import
& MX5 Friendly Dealers--MK1 MK2
Import
and UK differences--MK1
Install
central locking
Install
central locking 2
Interior upgrade MK1
J
Japanese
provenance - Eunos--MK1 MK2
K
Keys
for Roadsters
L
Lambda
sensors
Leaking rain rail fix
Limited
Edition buying guide--MK1 MK2 NC (MK3
Locate the parts in a MK1 engine bay/where's the VIN Mk1
Locking wheel nuts
Low
fuel warning light?
Low
power '5--MK1
LWSC
Problem the loctite fix--MK1
M
Major
misfire & Running problem
Make a live link
within a post
Mazda
dealer reviews
Mazda
Electronic Parts Catalog
Mis fire at start up and poor running
MOT
Test Mythbusters
MOT test Your
MX-5/Roadster and the exhaust emission test
MOT Emissions and cats, the facts. Also list of council MOT
stations
MOT inspection manual
MX5/Roadster
Buying Guide
My
radio displays "ERR" MK2.5
New
heat shield-MK1
New
TSB-s and a Recall! MK3
N
Non
Start - Cranks normally but will not start--MK2
O
Oil
and other fluids, capacities--MK1 MK2 MK3
Oil
pressure gauge- How
to fit a proper -MK1
Oil pressure gauge conversion from on/off type to variable type on late model NA
Oil,
some basic advice from an Oil Supplier
Oil,
specs and general advice
Original
battery fittings--MK1
Overheats
when idling/cooling fan won't switch on---MK1
P
Paint
code and name
Parts
books--MK1 MK2
Parts lists
Pedal box--MK1
Petrol Super
or ordinary unleaded MK1 MK2
PDF, download from forum
Pop ups popping up with side lights on?MK1
Post a picture on the forum
Pressure in the petrol tan
R
Rattle
noise from engine on start-up-- MK2.5
Rear
fog light rules (Construction & Use)--MK1
Rear
Fog Light Wiring--MK1
Recommended
body shops--MK1 MK2 MK3
Refurbish
your wheels --MK1 MK2
Revs fall when you put the
clutch down, Clutch Switch Faulty--MK1
Ride
Height
Roadster
import documents--MK1 MK2
Roadster
models excuse E&O's--MK1
Roadster production date
Roof drain tubes
Rust proof the sills
S
Seat belt relaxer fuse
Seat belts fix lazy
Service period guides
Shock
boots
Side
Lights Left On warning buzzer mod--MK1
Side mirror.free off stiff ball and socket on MK1
Sidelight
bulbs
Upgraded
Site abbreviation
key
Soft
Top Hardtop How-to downloads
Soft
top latch repair
Spark
plug diameter
Spark
plug leads which order to fit on the coil pack?
Spring
lengths
Springs
& dampers change
Starting
fault---- Earth Strap--MK1 MK2
Steering
wheel change airbag light flashing? fix here
Stick on Number Plates
Stick
on number plates, legal or not, will it pass the MOT test
Sump
plug size inc. torque setting
Supercharger/Turbo
loads of information--MK1 MK2
T
Third
brake light removal UK Mk1
Throttle body, clean to cure persistant idle droop
Ticking
noise, caused by purge valve problem--MK1
Tie down hooks
Timing
14 deg mod--MK1
Timing
belt jumped tooth--MK1 MK2
Timing
Mark find the Location--MK1 MK2
Timing
Mark Location--MK1 MK2
Timing
marks 1.8
Top 20
Things That Go Wrong With the Mx5--MK1 MK2
Torque
figures--MK1 MK2
Towing
and your MX5
Towing hook [track]
Towing
with a Mk2/2.5--MK2 (MK2.5
Transponder
key--MK1 MK2
TSW Stealth Wheels--MK1 MK2
Tuning
companys, parts suppliers etc
Tyre pressures
Tyre sizes? - Tyre Size Calculator
Tyre wear rates
Tyres, new, front or back
U
V
VIN
Numbers Decoded UK
Vin &
LWSC cutoff date MK1
W
Water
leaking in at the front of the hood
Water out of the cabin, boot and from steaming
What's
my Owners Club Region/Area
Wheel Alignment Specifications
Wheel
alignment and geometry centres
Wheel alignment on the 5 Some hints and tips
and a few myths about
Wheel arch liners and corrosion
Wheel fitment..what other vehicle wheels will fit my car
Wheel weights, members findings
Wheelchairs
Where can I experience the thrill of a Forced Induction '5
Which UK MX-5's have I got
Window
seals -- MK1 MK2
Window winder cables replace
Wiring diagrams 1990-2000
X
