Mk1 best new springs?
Last post Tue, Oct 9 2012 21:04 by marlin. 34 replies.
Page 1 of 3 (35 items) 1 2 3 Next >
  • Fri, Nov 11 2011 0:30
    • marlin
      Thu, Oct 27 2011
    • Teignmouth, Devon
    • Posts 17
    Just bought a Roadster V-spec 'B' (whatever that is) and it's slightly down at the rear, esp on the driver's side (without me in it!). Damping's not bad but it does hit the bump-rubbers too easily on B-roads. Ideally I'd simply replace the springs but what chance of getting some which will give me close to 340mm height? And where from please? Or will I need to get adjustable coil-overs to ensure I can achieve the right height? If so, is there a recognised favourite make/supplier please? Many thanks
    Colin
    Marie and Colin
    96 Eunos 1.8 VR-Limited (B) in green mica
  • Fri, Nov 11 2011 7:03 In reply to
    • Mazda-mender
    • Pie land/NW England
    • Posts 7,035
    Re: Mk1 best new springs?
     Morning Colin
    Is she just for road use? if so just get a full set of Mk 2 dampers,springs and top mounts,the full set up, straight swap, i would have a full G done also which will do wonders to how she will feel ,she will ride the bumps bettter (more travel)without losing anything on the corners.
    Give Andrew at Autolink a bell,see if he as a full set,as i know he as a couple of Mk 2's arrived from Japan that he is breakingThumbs up
    If she is for road and a bit of track time,then a set of meister r's is the route to go, you'll get best of both worlds with them.
    http://www.meisterr.com/
    http://www.meisterr.com/Site/Clearance.html
    Dont get the cheap Sh*t nasty coil overs  off e-bay, you'll pay for what you get.
    If you need any help,just give us a shoutThumbs up
    http://www.mazdamenders.net/
    http://www.autolinkuk.co.uk/
  • Fri, Nov 11 2011 15:48 In reply to
    • marlin
      Thu, Oct 27 2011
    • Teignmouth, Devon
    • Posts 17
     Many thanks M-m (and ditto for your engine-spec reply).
    The straight swap sounds simple but 2 probs: First I only have a single spring problem so maybe to replace all 4 plus dampers is OTT? Second, I was told my model (with Bilsteins, low-ratio LSD, etc, as standard) should sit a little lower than the 'normal' models, so swapping to a 'normal' setup would be a bit of a backward step methinks.
    Thanks for the Meister link too. They do look great and maybe I might be forced to go that route in the end, even for mostly road use, just so I can get exactly the right height.
    Do you know if there was an equivalent UK model to the VR-Limited, and would I be able to get springs for that from Mazda??
    Marie and Colin
  • Fri, Nov 11 2011 16:05 In reply to
    • AT
    • Posts 6,400
    No, there was no equivalent model to the VR-Limited Combination B.
    The VR was based on a S-Special;this is mechanically identical to the US R-package (except for steering; R-packages were power steering delete), so if you have a US contact, you may be able to source the correct springs from there.
    Alternatively, find a Mazda dealer with access to Roadster parts lists; they can order parts based on your Roadster VIN. I know Milcars Mazda in Watford can do this. Perhaps Bourne Road Mazda, who operate an internet mail order business, can as well.Parts I think come from Japan, and are a similar (slightly more) than the equivalent UK part.
  • Fri, Nov 11 2011 20:16 In reply to
    • marlin
      Thu, Oct 27 2011
    • Teignmouth, Devon
    • Posts 17
    Thanks AT, that's really helpful. Next stop Kentucky (brother)!
    Colin
    Marie and Colin
  • Fri, Nov 11 2011 20:30 In reply to
    • Mazda-mender
    • Posts 7,035
     You could also try Andrew at Autolink, he is always bringing in fresh imports for breakingThumbs up
  • Fri, Nov 11 2011 21:03 In reply to
    • muppet
      Sat, Dec 12 2009
    • Chandlers Ford
    • Posts 1,100
    Mazda-mender:
    the sport springs he sells are very good! Plus at a very good price as well. Big Smile
    www.solentmx5.com
    Founding member of The Fan-tangos'
    Honorary member of the Buccaneer5
  • Fri, Nov 11 2011 21:33 In reply to
    • AT
    • Posts 6,400
    You can find the parts numbers for 95-96 model cars with Bilsteins here:
    http://www.miata.net/garage/90-99Parts/95-96/MX5%2095%201%20OF%203%20CHASSIS.pdf
    1997 part numbers are listed here:
    http://www.miata.net/garage/90-99Parts/97/MX5%2097%202%20OF%202%20BODY.pdf
    I think they will be the same, but then, I was surprised to see two different front Bilstein shocks listed in the 95-96 catalogue, depending if the car is a MY95 or MY96. The VR Limited is a Series 2 1.8, which in the US might be referred to as a 1997 MY car.
  • Sat, Nov 12 2011 0:17 In reply to
    • marlin
      Thu, Oct 27 2011
    • Teignmouth, Devon
    • Posts 17
     Unbelievably helpful AT - now an even bigger fan of the OC. 2 q's:
    1 Will they be able to use my VIN to sort out 95MY vs 96MY, do you think?
    2 How long do these great posts remain in place for me to access again later?
    Marie and Colin
  • Sat, Nov 12 2011 5:04 In reply to
    • Posts 11,082
    Maybe a helpful mod will pop this as a stickey.Wink I'll extract all the relevant data later for an FAQ
  • Sat, Nov 19 2011 20:26 In reply to
    • marlin
      Thu, Oct 27 2011
    • Teignmouth, Devon
    • Posts 17
    More data needed please anyone!
    I've followed up the excellent earlier postings on this, plus a few alternative suppliers of springs and dampers (of which there are many!) and I'm now much more clued up. This is what I've found so far, in case others might be interested...
    Bourne Road Garage were excellent (so's their website) and could easily supply factory spares from Japan for my VR-Ltd, using the same parts catalogue linked to earlier. BUT these are expensive at nearly £500 just for the rear springs, dampers and bump rubbers AND received wisdom is that the VR-Ltd/Miata R-package set up isn't brilliant even when new (any 'R' owners want to argue otherwise?).
    The Autolink sport springs are cheap BUT may be too soft, at 3kg/mm Front and 2kg/mm Rear, especially as mine is already hitting the bump-stops too easily.
    The Meisters look good BUT seem too hard for road use, at 7F and 6R. And they guy I spoke to wasn't very communicative.
    Tein have a big range BUT the only product significantly softer than the Meisters is non-adjustable so you'd be a hostage to fortune - if you don't like the ride/handling compromise or the height, it's too late, you've bought 'em.
    Phil Dixon of Performance 5 is clearly knowledgeable and helpful BUT his springs are nearly as hard as the Meisters, at 6.25F and 4.5R, plus that's a big differential front to rear.
    I looked at others, eg Flyin Miata, but you're probably getting bored by now. SOoooooo...
    Can anyone give me the spring-rates for the standard Mk1's and, ideally, the VR-Ltd/R-packagemodels?
    Thanks all
    Colin
    Marie and Colin
  • Fri, Dec 9 2011 23:41 In reply to
    • longdog_cymru
      Sat, Oct 29 2011
    • Swansea, South Wales
    • Posts 278
    Got Trim springs from MX5 Parts (http://www.mx5parts.co.uk/product_info.php/products_id/353) on my Mk1 and I'm pretty happy with them.
    '96 Mk1 Merlot
  • Sat, Dec 10 2011 0:18 In reply to
    • AT
    • Posts 6,400
    marlin:
    Thanks all
    Colin
    Have a look at:
    http://j3cht.webs.com/miata_spring_rates.xls
    Its a collection of various spring rates
    Spring Fitment/Years Front lowered Rear Lowered Front Springrate Rear Springrate
    OEM 1.6 Manual Trans N/A N/A 164.17 96.94
    OEM 1.6 Auto Trans N/A N/A 153.52 93.53
    OEM 1.8 Manual Trans N/A N/A 153.52 96.94
    OEM 1.8 Auto Trans N/A N/A 153.52 93.53
    OEM R Package 1997 N/A N/A 153 105
    You want to shoot for rear springs being about 60-70% of the rate of the fronts. P5s spring bias is just about bang on. With the S-Special/R-Package, having a stiffer rear, Mazda has dialled in a little more oversteer than the stock car. If you go for a much softer spring; more understeer during slow turns, but increased high speed stability.
    I have P5's old Puredrive kit, with its very stiff springs, but the ride is very smooth.
  • Thu, Dec 15 2011 14:37 In reply to
    • Dee Pee
      Mon, Apr 4 2011
    • Croydon
    • Posts 100
    Hi there, are these the latest spec 2011 springs, and did they have properly shaved flat ends ? (oooher missus !) Wink
  • Fri, Dec 16 2011 18:15 In reply to
    • marlin
      Thu, Oct 27 2011
    • Teignmouth, Devon
    • Posts 17
    AT:
    Great data and advice AT, thanks again. Phil D of P5 says the current Sportdrive springs are the same as yours but he's changed the dampers to 'in-house' units to get better tuning and quality control.
    I'm not quite sure what 'very smooth' means so how comfortable would you say yours is on a weekend B-road, for example? Is your car used for track as well as road?
    On another recent post, you wisely suggested people shouldn't get too carried away with new kits. The new P5 kit is about to become available at a £70 discount but, given that he's taking on the damper production, do you reckon I'd be wise to hang on and see what others think of them? The only report (very positive) I've seen was in Pistonheads.
    Marie and Colin
