Cam Box Hotside Breather - M45 Supercharger
Last post Sun, Dec 18 2011 15:59 by Keith W. 2 replies.
Page 1 of 1 (3 items)
  • Tue, Nov 29 2011 16:23
    • Keith W
      Fri, Oct 8 2010
    • Hornby Lancashire
    • Posts 140
    Some advice please.
    Having fitted an Eaton M45 to my 2002 MK2.5 1.8 I am unsure as to what is the "correct" way to apply a breathing system to the hotside of the cam box.
    Use a "mini" filter & vent into the atmosphere?
    Use a rubber hose & attach to the air intake hose after the MAF?
    I have seen examples of both systems.
    Which is the best system & why?
    Thank you for looking
    Keith
  • Sun, Dec 11 2011 9:10 In reply to
    • Only MX5ives
    • Solihull
    • Posts 72
    Re: Cam Box Hotside Breather - M45 Supercharger
    Simple choice.
    Do you want oily crap in your engine or in the atmosphere ?
    The only positive is if you feed it pre charger then in theory it will coat the blades and make a better seal (over time)
    Mark
    Only MX5ives - MX5 Specialist in Solihull.
    Supplying cars, hoods, parts, servicing - in fact anything to do with MX5s
    My car : Mk1 1.8, M45 COLDSIDE, 9.5 psi. You can check it out here: http://www.cardomain.com/ride/3080932
  • Sun, Dec 18 2011 15:59 In reply to
    • Keith W
      Fri, Oct 8 2010
    • Hornby Lancashire
    • Posts 140
    Good Day Mark
    Thank you for the reply, I've chosen the the pre charger route.
    Keith
