Diff Broken
Last post Mon, Apr 9 2012 21:08 by homebuild. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Mar 9 2012 21:41
    • homebuild
      Fri, Mar 9 2012
    • Posts 7
    Diff Broken
    Firstly hello this is my first post so be gentle, i have a L reg'd 1.8 engine in a kit car, thought the diff had shot so took it down to my local Mazda and the confirmed it had.
    The Question is, is the process of replacing it with a LSD  a straight foreward one or is there a lot more to think about apart from cost, Also where do you guys buy all your bits from as i have seen a few on Ebay.
    Thanks.
  • Fri, Mar 9 2012 22:49 In reply to
    • AT
    • Posts 6,404
    Re: Diff Broken
    All you need to know about MX5 diffs:
    http://www.miata.net/garage/diff_rr.html
    http://www.miata.net/garage/diffguide/index.html
    90-93 manual 1.6 Eunos Roadsters were fitted with viscous limited slip diffs; Mazda never called this a LSD, but a sports diff.
    Most, but not all, 93+ 1.8 Eunos Roadsters were fitted with Torsen differentials (4.300 final drive T2 from 1996).
    Diff upgrades are very common.
    The usual places to source a used diff is any of the MX5 specialist breakers; MX5heaven, Autolinkuk, PJ Sportscars (Shardlow) etc. Most Mk2 UK 1.8 MX5s will have a Torsen diff fitted. From 2002, a weak Fuji SuperLSD was used on Sport models.
  • Sat, Mar 10 2012 19:21 In reply to
    • homebuild
      Fri, Mar 9 2012
    • Posts 7
    Re: Diff Broken
     Thanks for your help.
  • Tue, Apr 3 2012 20:02 In reply to
    • homebuild
      Fri, Mar 9 2012
    • Posts 7
    Re: Diff Broken
     Are any of you familiar with how the MX5 diff fits onto a SR2 Roadrunner kit car? We have removed all the bolts we can see and it looks like the diff is now sat on/over a tube that appears to be part of the chassis.  This tube goes up into the rear of the 2 front monuting holes.We have tried lifting the diff off with an engine crane with some "persuassion" but no joy! Are there just 4 bolts in total? The 2 in the "wings" and the 2 at the front or are we missing something?
  • Sun, Apr 8 2012 17:13 In reply to
    • homebuild
      Fri, Mar 9 2012
    • Posts 7
    Re: Diff Broken
     Done now got it out with a little help from my new mate (5ft crowbar) just got to look for anothr LSD.
  • Mon, Apr 9 2012 21:08 In reply to
    • homebuild
      Fri, Mar 9 2012
    • Posts 7
    Re: Diff Broken
     Ok spotted a Torsen type 2 LSD diff 3.9 ratio apparentley fitted to JDM RS models, any one tell me a little bit more on these diffs? Thought i'd go for a 3.9 ratio over the 4.1 that i already have as its quick enough 0-60 with a little turbo on the side.
