MX5 Mk 1 alarm
Last post Sat, Nov 10 2012 20:09 by huwtitanic. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Apr 7 2012 13:48
    MX5 Mk 1 alarm
    Hello All MX5 Owners,
    This is my first post.  Having been banned by wife of returning to motor cycles I obtained a 1991 MK1 from a family friend ten years ago and it has now only just run up 26k miles from new.  It has been a perfect summer 'toy' though having passed my three score years and ten it is getting more difficult to climb out of the car.  As a long retired Chartered Engineer who did all the maintenance work on my vehicles I have now had to cut back on these activities.  My MX5 has been totally reliable over its 21yr life until now when a fault has developed with the Mazda fitted optional alarm. It took a while for me to locate the alarm control unit.  All I need now is the circuit diagram for the installation so that I can return it to the standard configuration without the alarm in circuit and any other available data on this Mazda sytem marked 2096 on the control unit.  The actual fault is only that the hazard warning indicator lights now remain ON and I have to disconnect the battery, but can not drive it in that state.  Obviously one of the PC mounted switches which activates the alarm warning flashes has stuck closed but all the other functions are OK. (I am not impressed by workmanship which went in to the fitting by Mazda UK of this alarm system .)
    If anyone can give advice or provide a copy of the wiring in and circuit diagrams it would be much appreciated and I could share my experience for the benefit of other drivers.  I would of course pay for any help that can be provide
    Waiting in eager hope for some response when I can provide contact details.
  • Sat, Apr 7 2012 14:30 In reply to
    • Posts 11,082
    Re: MX5 Mk 1 alarm
    G'day mate Welcome to the forum--
    Just signed in for the first of many visits? I'm sure that you will pop your location in your profile, and the year and model of your MX5 in your sig. This helps enormously when we try to answer questions.....
    Forum Technical Index
  • Wed, Apr 11 2012 17:42 In reply to
    Re: MX5 Mk 1 alarm
    I don't know about the optional alarm, but the workshop manual has the standard wiring diagrams.
    It can be found here: http://www.roadsterclub.be/index.php/downloads/werkplaatshandleiding
    Beware this is for the US version, so there may be some differences here and there.
  • Thu, Apr 12 2012 1:21 In reply to
    Re: MX5 Mk 1 alarm
    Unless the car is a Green Limited Edition, the alarm would have been fitted at the dealership. It sounds like a Finishline system. There were no wiring diagrams as such just fitting instructions. It was just a plug and play affair so you should be able to follow all the wires back and disconnect it. If it had the immobiliser you'll have to re-join the vehicle wires for that. The full spec system had about 3 or 4 separate control modules.
  • Thu, Apr 12 2012 6:50 In reply to
    • Mazda-mender
    • Pie land/NW England
    • Posts 7,032
    Re: MX5 Mk 1 alarm
     Where are you? a local owner maybe close by that can offer help.
    http://www.mazdamenders.net/
    http://www.autolinkuk.co.uk/
  • Sat, Nov 10 2012 20:09 In reply to
    • huwtitanic
      Wed, Feb 4 2009
    • Posts 1
    Re: MX5 Mk 1 alarm
    Hi did you get the the alarm out and is working now i have the same thing on 1991 mx5 hope to hear from you thx Huw
