Self inflicted electrical problem
Last post Tue, Apr 10 2012 20:51 by Designforlife. 7 replies.
Page 1 of 1 (8 items)
  • Tue, Apr 10 2012 19:55
    Done a bit of a boo-boo...went to take out my OEM head unit after work and was struggling with the removal tools a bit, so gave up after half an hour...I hadn't disconnected the battery as I hadn't got as far as unplugging anything.
    I went to lock car after messing about and my remote fob has stopped working completely, also when I started the car the check engine light is now on...what have I managed to break in messing about with the HU?
    The car still starts and runs, and headlights are OK....heaters seem to be working. Pretty annoyed with myself, any ideas?
    Mk2.5 Phoenix 1.6i
  • Tue, Apr 10 2012 19:57 In reply to
    Re: Self inflicted electrical problem
    oh and to add, head unit doesn't work now either!
    Mk2.5 Phoenix 1.6i
  • Tue, Apr 10 2012 19:58 In reply to
    • zpat
      Fri, Dec 31 2010
    • Posts 696
    Check the "room" fuse.
    2001 mk2.5 1.8
  • Tue, Apr 10 2012 20:10 In reply to
    am i safe to just pull it out and check?
    I know zip about auto electrics and fuses lol...don't want to make matters worse.
    Interior lights not working either
    Mk2.5 Phoenix 1.6i
  • Tue, Apr 10 2012 20:13 In reply to
    • zpat
      Fri, Dec 31 2010
    • Posts 696
    Turn the ignition off and then just pull that fuse out to check. Pair of small nose pliers can help.
    It's about the sum total of my knowledge - but I did a very similar thing myself. You can get spare fuses at Halfrauds etc.
    2001 mk2.5 1.8
  • Tue, Apr 10 2012 20:20 In reply to
    right, room fuse has blown, so mustve shorted something with the HU removal tool?
    Is it safe to drive the car without it? just need to get a couple miles down road to halfords
    Mk2.5 Phoenix 1.6i
  • Tue, Apr 10 2012 20:36 In reply to
    • zpat
      Fri, Dec 31 2010
    • Posts 696
    I think it's fine to drive it. I certainly did.
    2001 mk2.5 1.8
  • Tue, Apr 10 2012 20:51 In reply to
    petrol station on the corner came up trumps, got a pack of fuses and its all sorted...bar the bloody OEM headunit still being firmly in place.
    Before my next bout with it i'll disconnect the battery first, cheers for the help :)
    Mk2.5 Phoenix 1.6i
