LSD
Last post Mon, Apr 16 2012 8:54 by AT. 3 replies.
Page 1 of 1 (4 items)
  • Mon, Apr 16 2012 7:19
    • tom1946
      Fri, Oct 15 2010
    • Guisborough, Cleveland UK.
    • Posts 143
    Not the kind you're thinking of :)
    How can I tell if my 1990 Eunos roadster has a limited slip diff?
    Thanks.
    1990 Mariner Blue Mk1 Eunos 1.6.
    1992 Black Mk1 1.6 SE with tan leather.
  • Mon, Apr 16 2012 7:28 In reply to
    • Mazda-mender
    • Pie land/NW England
    • Posts 7,027
    Re: LSD
    http://www.mazdamenders.net/
    http://www.autolinkuk.co.uk/
  • Mon, Apr 16 2012 7:40 In reply to
    • tom1946
      Fri, Oct 15 2010
    • Posts 143
    Re: LSD
     Thanks MM, I was rather hoping for a simpler way to find out. Mine's still in the car.
  • Mon, Apr 16 2012 8:54 In reply to
    • AT
    • Posts 6,395
    Re: LSD
    http://www.miata.net/garage/vlsd.html
    The shop manual states to test a VLSD you put a torque wrench on the hub (wheel in the air) and turn 90 degrees with 11 ft lbs of torque (car in gear). This should take no less than 4 seconds. If less then you have either an open diff or the VLSD is toast. Another test for a good VLSD is to jack up the rear with both rear wheels in the air. A good VLSD will turn both rear wheels in the same direction when manually turning the drive shaft. The open unit (or toasted VLSD) will turn the wheels in the opposite directions. There is no rebuild kit for the VLSD and the unit is completely sealed so you can't even get inside it short of cutting it
    That test doesn't work for a Torsen, though you ought to be able to spot if someone has fitted your car with a 1.8 rear end.
