QPS Turbo Kit - Anyone know anything about it?
Last post Wed, May 9 2012 18:59 by skir67. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Apr 23 2012 20:48
    • strugrat
      Wed, Jan 18 2012
    • Swadlincote, Derbyshire
    • Posts 5
     All,
    Spotted this on ebay.  Wondered if anyone knew anything about them.  Search doesnt bring up anything.  Seems a good price maybe? If they do one for a mk2 1.8 I'm sort of interested possibly......
    http://www.ebay.co.uk/itm/Mazda-MX5-Mk1-1-6-Stage-1-Garret-Turbo-Kit-/270952277488?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1603a5f0
    Would be interested in peoples thoughts?
    Ryan
    1998 MK2 RS, Pretty Standard apart from Sportrac Reclining Buckets. Future plans are many.
  • Thu, Apr 26 2012 14:13 In reply to
    • nickbee
      Wed, Dec 21 2011
    • Chelmsford, Essex
    • Posts 92
    Re: QPS Turbo Kit - Anyone know anything about it?
    £1500 will pretty much get you a tried-and-tested turbo setup.  I wouldn't spend the same amount on something at which is at development stage from a firm I've never heard of.
    1994 1.8 Eunos S-Special. Gaz Gold Pros, Rota Slipstreams & Yoko Parada Spec 2, Mazdaspeed cat-back, TR Lane GP Bar
  • Thu, Apr 26 2012 21:57 In reply to
    • strugrat
      Wed, Jan 18 2012
    • Posts 5
     Assume you mean the base non intercooled kit from FM or BEGI? Or do you mean cobbling a kit together myself?
  • Thu, Apr 26 2012 23:57 In reply to
    • nickbee
      Wed, Dec 21 2011
    • Chelmsford, Essex
    • Posts 92
    Only a base kit, but one which is known to work. £1500 is a lot to spend on something which you know nothing about.
    But on the other hand it might turn out to be a total bargain, I guess it all depends on your philosophy!
  • Fri, Apr 27 2012 10:50 In reply to
    • Mike Gleaves
      Sat, Feb 7 2009
    • Cornwall
    • Posts 48
    I note they say they have no ECU solution which i find strange since if you are putting more air in the cylinders you need more fuel too? A good ECU like Megasquirt can cost £1000
  • Wed, May 9 2012 18:51 In reply to
    • skir67
      Tue, Nov 25 2008
    • Merseyside
    • Posts 295
    For a megasquirt, more like 4-500 and someone on the nutz forum will build you one to suit your exact requirements and provide forum/e-mail support to help get it running. Search for 'reverant' he is very good from what I've seen.
  • Wed, May 9 2012 18:59 In reply to
    • skir67
      Tue, Nov 25 2008
    • Merseyside
    • Posts 295
    This QPS kit actually looks the best of the ebay ones I've seen. The biggie is the quality of the manifold build, if it's rubbish and cracks it will be a waste of money. For not a lot more you can have a begi/fm base kit which is a given known i.e it will work! The QPS could become an option but you might not want to be one of the first guinea pigs to use it!
