Eezi bleed
Last post Sun, May 27 2012 16:20 by sebna. 47 replies.
Page 1 of 4 (48 items) 1 2 3 4 Next >
  • Thu, Apr 26 2012 10:20
    • rg1642
      Sun, Jan 2 2011
    • East Harling
    • Posts 296
    Eezi bleed
     Hi all,
    Just wondering if anyone has used the Gunson eezi bleed on the clutch? Wanted to know if one of the adaptor caps provide fitted the clutch master cylinder?
    ta
    Mk1 1.6 Uk MX5
    I miss my '78 Triumph Tiger, my CB750FA and my XJR1300 Doh!
  • Thu, Apr 26 2012 10:50 In reply to
    Re: Eezi bleed
     You need a special large cap for the MX5 brake master cylinder not included in the kit. I think the clutch master cylinder which is much smaller should use one of the supplied caps. I will check for you tonight.
    eddie
    eddie
    08 Mk3 2.0 Sport RC, Drumtochty Glen, Auchenblae,
  • Thu, Apr 26 2012 12:02 In reply to
    • rg1642
      Sun, Jan 2 2011
    • East Harling
    • Posts 296
    Re: Eezi bleed
     Thanks mate, just didnt want to buy one if the caps didnt fit.
    Russ Big Smile
    Mk1 1.6 Uk MX5
  • Thu, Apr 26 2012 18:48 In reply to
    • Geoff Peace
    • Ashton-in-Makerfield Lancs.
    • Posts 899
    Re: Eezi bleed
     My advice would be not to take this infernal contraption anywhere near a car.  They run from the tyre pressure which needs to be deflated to around 10 p.s.i. it is far too high, the caps leak, brake fluid everywhere, the pressure can blow the reservoir off the cylinder, ( they are only push fit seals) I have known one extreme case where the master cylinder seals were reversed.  Much better to pump the fluid through with the clutch pedal or use a vacuum bleeding tool.
       Regards  Geoff Peace.
    2004. Mk.2.5 1600c.c. in radiant ebony
    location Ashton-in Makerfield, Lancs.
    Tantum faciendum parum dactum
  • Thu, Apr 26 2012 19:31 In reply to
    Re: Eezi bleed
    First I agree with Geoff as I was not amazed at mine.
    Second the kit has a 45mm internal diameter cap and the MX5 clutch is approx 42mm. Gunson do not do one that fits even as an extra.
    They also do not do a big cap for the the MX5 brake master cylinder.
    Gunson sell a multipurpose one and is on ebay here
    http://www.ebay.co.uk/itm/GUNSON-MULTI-PURPOSE-CAP-EEZIBLEED-EEZI-BLEED-77042-/400071147269
    I have a vacuum bleeder and that is excellent. I bought it last year.
    eddie
    eddie
  • Fri, Apr 27 2012 7:51 In reply to
    • rg1642
      Sun, Jan 2 2011
    • East Harling
    • Posts 296
    Re: Eezi bleed
     I thought they would have improved from the one I had in the early 80's, but obviously not! That was just about useable. Oh well I'll go with pumpin the pedal. Smile
    Thanks for the advice.
    Russ
    Mk1 1.6 Uk MX5
  • Fri, Apr 27 2012 19:57 In reply to
    • Posts 1,500
    Re: Eezi bleed
     Too complicated even if it did work just for occasional use imho.
    The Vizi Bleed (clear pipe with valve on the end) for a fiver from Halfords is the one to get. Used one for years and just done 2 complete car brake fluid changes single handed with no problem at all; fit pipe, open nipple once, pump a few times, top up, few more pumps, close and onto next wheel, that quick.
    Should be fine for single handed use on the clutch too though trapped air can be a problem. Try getting the car jacked or on a slope so the nipple is at the highest point on the slave.
  • Fri, Apr 27 2012 20:06 In reply to
    • harryhedgehog
      Thu, Mar 22 2012
    • A14 Junction 13 Thrapston, Northamptonshire
    • Posts 19
    Re: Eezi bleed
    I don't use mine any more after getting brake fluid over my Land Rover wingAngry
    Try a ViziBleed  simple to use and cheap Cool
    HHH
    09 2.0 litre sport tech roadster
    1983 88" 2.25 Petrol Leaf Sprung Land Rover
  • Fri, Apr 27 2012 20:12 In reply to
    • Posts 1,500
    Re: Eezi bleed
     Just had a look in Haynes for you and they suggest another way for the clutch if you have a helper.
    Get helper to press and hold the pedal to floor, open bleed nipple until flow stops, close bleed nipple, then release clutch pedal,
    repeat cycle until no more air through bleed pipe.
    I can see the reason for this would be to allow fluid to only be pumped one way, the mastercyl then being closed by the pedal being held down. Opening the bleed nipple would allow the spring return of the clutch to drive trapped fluid and air back out the nipple and not back up the pipe to the master.
  • Fri, Apr 27 2012 21:30 In reply to
    • harryhedgehog
      Thu, Mar 22 2012
    • Posts 19
    Re: Eezi bleed
    ViziBleed has a non-return valve built in
    HHH
  • Sat, Apr 28 2012 5:16 In reply to
    • rg1642
      Sun, Jan 2 2011
    • East Harling
    • Posts 296
    Re: Eezi bleed
    This is all good stuff, thanks. I think I'll try the visibleed. Seems a lot easier.
    Russ
    Mk1 1.6 Uk MX5
  • Sat, Apr 28 2012 11:48 In reply to
    • harryhedgehog
      Thu, Mar 22 2012
    • Posts 19
    Re: Eezi bleed
    I didn't get the "deluxe" kit with the plastic bottle because a) it costs more and b) I have plenty of suitable jars n blocks of wood / bricks and c) most importanly you can see any bubbles present with a jar
    HHH
  • Sat, Apr 28 2012 18:08 In reply to
    • Geoff Peace
    • Posts 899
    Re: Eezi bleed
     The technique of closing the bleed nipple every time the clutch pedal is depressed is the best way to avoid air being drawn into the system.  Even with the 'one way valve' bleed tubes it is still possible for air to be drawn in around the threads of the bleed nipple.  This can also be a problem when using a vacuum brake bleeding tool.   A little grease or waxoyl round the nipple helps and also prevents the nipple seizing.
  • Sat, Apr 28 2012 18:22 In reply to
    • harryhedgehog
      Thu, Mar 22 2012
    • Posts 19
    Re: Eezi bleed
    Grease around nipple, now that is a good ideaCool
    HHH
  • Sat, Apr 28 2012 18:48 In reply to
    • Posts 1,500
    Re: Eezi bleed
    harryhedgehog:
    HHH
    Yes but I'd only use red rubber grease in case it is drawn into the cylinder.
    I've not done MX5 but have done MGB/C many times and they are known for same air problem as the slave lies horizontal and you can end up drawing an air bubble back and forth up the line.
    Mostly they were ok but one just stayed soggy then cleared the next day by itself so I guess a bit of use and time let the bubble float up to the m/cyl. Tap the slave gently, try not to introduce air when topping up the master, and periodically side step your foot off the depress pedal to let it come back with a bang and rattle the air are ideas I used too.
    I know the Vizi bleed has a valve and is fantastic on brakes but haven't used it on the clutch so would tend to go the way of a plain pipe and close the nipple each stroke as Haynes and Geoff advocate.
