Cut out and wont restart
Last post Thu, May 3 2012 23:57 by Fuelhead666. 19 replies.
Fuelhead666
Sun, Apr 29 2012
- Cardiff
- Posts 25
Hi i have a 1990 eunos 1.6 just got home on back of recovery truck -((( went for a drive and about 2
Mile from my house it cut out and wont restart, the rac man said the crank wasnt turning ( he was looking through oil filer cap)
Please help only had car 6 weeks spent loads already ie hood chrome etc
Damo
safetymatch
Sun, Jun 27 2010
- WIGAN
- Posts 173
Re: Cut out and wont restart
If he's looking through the oil filler cap/hole it's the camshaft thats not turning, Snapped cam belt!!!!!!
Marble White icon S/S Exhaust, Lowered, 17 RS alloy wheels K+N filter and a few shiny bits........ BLYTON stickered....i'm a record breaker! GPS tracker fitted.
Fuelhead666
Sun, Apr 29 2012
- Cardiff
- Posts 25
No belt is fine thats what i dont understand sensor?? Maybe
Damo
safetymatch
Sun, Jun 27 2010
- WIGAN
- Posts 173
Sorry you've got me confused, more symptoms please.
Fuelhead666
Sun, Apr 29 2012
- Cardiff
- Posts 25
It just cut out all belts are still intact from what i can see, it was like it ran out of fuel, the rac bloke said that cam wasnt turning when i was trying to fire her up, as he was looking through oil filer cap, thats all i know no warning lights are on all fuses are ok
Damo
safetymatch
Sun, Jun 27 2010
- WIGAN
- Posts 173
Ok, Your cam belt has failed, it might be still in place but the teeth on the belt have stripped, you are looking at the belt under the domed cam cover and not the alternator belt are you, don't worry though it's an easy fix.
safetymatch
Sun, Jun 27 2010
- WIGAN
- Posts 173
If you post the general area where you live somebody will point you to a decent local MX5 garage.
safetymatch
Sun, Jun 27 2010
- WIGAN
- Posts 173
Taff eunos is probably your man, he is usually on line and may just pick this thread up.
Mazda-mender
- Pie land/NW England
- Posts 7,011
Check for flash codes/fault codes before you do or take her anywhere, but i would Check the CAS ,
Please feel free to P.M me with any problems or questions. http://www.mx5oc.co.uk/forum/members/Mazda_2D00_mender.aspx http://www.mazdamenders.net/ http://www.autolinkuk.co.uk/ MADE BY MAZDA, MAINTAINED BY MAZDA MENDERS The online garage for those owners that like to play with spanners and different coloured grease. Mk 1.5 Eunos Roadster 1.6 1992 silverstone......Being fettled Mk 1 V.S II EUNOS 1.8 1993 black...fettled Mk 2.1/4 V.S ROADSTER 1.8 1999 black....fettled Mk 2 V.S ROADSTER 1.8 1999 white....being fettled for shows only
Fuelhead666
Sun, Apr 29 2012
- Cardiff
- Posts 25
Any ideas how i can get in contact with him
Damo
Mazda-mender
- Posts 7,011
Mazda-mender:
taff eunos
- Riviera, South Wales
- Posts 4,381
Fuelhead666:
Relax, he found you PM (personal message) sent
Dr. Eunos
