Cut out and wont restart
Last post Thu, May 3 2012 23:57 by Fuelhead666. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Mon, Apr 30 2012 19:03
    • Fuelhead666
      Sun, Apr 29 2012
    • Cardiff
    • Posts 25
    Hi i have a 1990 eunos 1.6 just got home on back of recovery truck -((( went for a drive and about 2
    Mile from my house it cut out and wont restart, the rac man said the crank wasnt turning ( he was looking through oil filer cap)
    Please help only had car 6 weeks spent loads already ie hood chrome etc
    Damo
  • Mon, Apr 30 2012 19:13 In reply to
    Re: Cut out and wont restart
     If he's looking through the oil filler cap/hole it's the camshaft thats not turning, Snapped cam belt!!!!!!
    Marble White icon S/S Exhaust, Lowered, 17 RS alloy wheels K+N filter and a few shiny bits........ BLYTON stickered....i'm a record breaker!
    GPS tracker fitted.
  • Mon, Apr 30 2012 19:27 In reply to
    • Fuelhead666
      Sun, Apr 29 2012
    • Cardiff
    • Posts 25
    No belt is fine thats what i dont understand sensor?? Maybe
    Damo
  • Mon, Apr 30 2012 19:33 In reply to
     Sorry you've got me confused, more symptoms please.
    GPS tracker fitted.
  • Mon, Apr 30 2012 19:52 In reply to
    • Fuelhead666
      Sun, Apr 29 2012
    • Cardiff
    • Posts 25
    It just cut out all belts are  still intact from what i can see, it was like it ran out of fuel, the rac bloke said that cam wasnt turning when i was trying to fire her up, as he was looking through oil filer  cap, thats all i know no warning lights are on all fuses are ok
    Damo
  • Mon, Apr 30 2012 20:01 In reply to
     Ok, Your cam belt has failed, it might be still in place but the teeth on the belt have stripped, you are looking at the belt under the domed cam cover and not the alternator belt are you, don't worry though it's an easy fix.
    GPS tracker fitted.
  • Mon, Apr 30 2012 20:08 In reply to
    • Fuelhead666
      Sun, Apr 29 2012
    • Cardiff
    • Posts 25
    Thank you
    Damo
     If you post the general area where you live somebody will point you to a decent local MX5 garage.
    GPS tracker fitted.
  • Mon, Apr 30 2012 20:50 In reply to
    • Fuelhead666
      Sun, Apr 29 2012
    • Cardiff
    • Posts 25
    Cardiff south wales
    Damo
  • Mon, Apr 30 2012 21:21 In reply to
     Taff eunos is probably your man, he is usually on line and may just pick this thread up.
    GPS tracker fitted.
  • Mon, Apr 30 2012 22:01 In reply to
    • Mazda-mender
    • Pie land/NW England
    • Posts 7,011
     Check for flash codes/fault codes before you do or take her anywhere, but i would Check the CAS ,
    http://www.mazdamenders.net/
    http://www.autolinkuk.co.uk/
  • Mon, Apr 30 2012 22:20 In reply to
    • Fuelhead666
      Sun, Apr 29 2012
    • Cardiff
    • Posts 25
    Any ideas how i can get in contact with him
    Damo
  • Mon, Apr 30 2012 22:24 In reply to
    • Mazda-mender
    • Posts 7,011
    Mazda-mender:
    • vidov0
      Sat, Jan 30 2010
    • Teignmouth,Devon
    • Posts 71
    Ian & Kim Oakey
    MX5 1998 1.8 mk2
    Bronze Mica Metallic
  • Mon, Apr 30 2012 22:40 In reply to
    • Posts 4,379
    Fuelhead666:
    Relax, he found you Wink PM (personal message) sentThumbs up
    Dr. EunosGeek
