stick on number plate
Last post Wed, May 23 2012 12:36 by leemarb. 24 replies.
Bodie
Sun, Apr 24 2011
- Cambs
- Posts 81
A few photos of my MX5 now with a stick on front number plate and square rear number plate.
Lee
2002 MX5 1.8 Arizona Blaze Yellow PI 30mm Springs K&N Typhoon Induction Kit LED Side Markers & Side Lights Zunsport Grille LED Angel Eye Fog Lights Stainless Exhaust
leemarb
Mon, Nov 17 2008
- hertford east herts
- Posts 562
Re: stick on number plate
hi bodie, looks very nice, was there much to do, getting rid of the original no plate fixing holes, or did you just stick over them, also was it hard to stretch your new number over the curves, and still keep an even straight line.
regards leemarb
,,, I NOW KNOW THE MEANING OF SMILES PER MILE ,,, a member since 2005, with 400 + posts in a past life 05, 2-5 titanium icon, 1.8i , 100mm dual oval larinis, matching hardtop (sometimes), 6 c/d changer, all clear lights, some chrome, well quite a bit actualy,, i like it. P/s proud to be an " OLD GIT ",, and a "Grey",, "Grey Brigade Member".
Bodie
Sun, Apr 24 2011
- Cambs
- Posts 81
Hi Leemarb,
I stuck it over the original holes, can't even tell they were there. Going over the curves of the bumper is a nightmare, will need to order another one at some point to have another go but for the minute it's not bad! I think it makes the front end look fresher
Bodie
zpat
Fri, Dec 31 2010
- Posts 695
Is the front one road legal?
2001 mk2.5 1.8
taff eunos
- Riviera, South Wales
- Posts 4,401
Technically no they are not legal, but ought to be really unlike plastic plates and plinths which break and fall off very easily these are a lot more `permanent`. I have stick-ons on both our Eunos Roadster and Mk1 and both are fine as far as two separate MOT stations are concerned. Police all over the country dont seem too bothered either.....
Am going to add that I firmly believe the main reason for making people have upright BSAU approved front plates is to make it easier for `speeding tax` sneaky camera vans to read them at longer distances, so good enough reason on its own to have a stick-on.
I have also noticed with a few `speed limit reminder` electronic boards around here that they notice Mk1s a lot easier and sooner if the headlamps are up (radar reflection again....)
Dr. Eunos
zpat
Fri, Dec 31 2010
- Posts 695
Yes, definitely a market for a radar absorbing paint finish and a low radar signature shape nose!
2001 mk2.5 1.8
rogerzilla
Sat, Dec 13 2008
- Swindon, Wiltshire
- Posts 483
They're sort of legal on pre-2001 cars. Technically I don't think you're supposed to fit a sticky plate now, but a pre-existing sticky plate - and no-one can tell when it was first put there -was "tolerated" under the law.
On a post-2001 car it's definitely wrong as the plate must meet British Standard, and it won't. You'd probably never get pulled up on it though, as the MoT only checks spacing and condition, not the type of plate.
Mk3.5 Venture 1.8i in Meteor Grey (when it arrives)
taff eunos
- Posts 4,401
rogerzilla:
Both my MOT men have said, as long as they can read it from the MOT bay when its outside waiting to come in then its a pass
taff eunos
- Posts 4,401
zpat:
Just for you, have a giggle at this old chesnut
yorkshire pud
Tue, Jan 26 2010
- Doncaster
- Posts 97
I did mine a little differently (if the picture appears ! )
Don't wait for retirement, you may never get there ! British Racing Green Mk 2.5 1.8 Sport. 125,000miles but drives like a new 'un.
yorkshire pud
Tue, Jan 26 2010
- Doncaster
- Posts 97
Try again ! !
Bodie
Sun, Apr 24 2011
- Cambs
- Posts 81
I like where you've put your plate , was thinking about mine there but went for lower down in the end (What a pain to fit)
Bodie
yorkshire pud
Tue, Jan 26 2010
- Doncaster
- Posts 97
I know what you mean about trying to stick it around the curves. Thats why I went for moving the badge up onto the bonnet and re sticking it on with silicon sealant. My plate went on without any issues using water and a bit of baby shampoo to allow it to slip into position. I think the plate position gives it a more classic look without drawing too much attention from law enforcers.
Steve_C
Sun, Oct 30 2011
- Nottingham
- Posts 332
I've got a stick on and not had any issues from plod or the MOT. I just like the E-type look!
Mk1 RS Ltd - track car http://www.mx5oc.co.uk/forum/forums/t/39384.aspx
taff eunos
- Posts 4,401
Heres an `E-Type` look I prepared earlier.....
Just spent most of the day converting the USA spec E-Type V12 5.3 to right-hand drive, a task not for the faint-hearted
Dr. Eunos
