stick on number plate
Last post Wed, May 23 2012 12:36 by leemarb. 24 replies.
Page 1 of 2 (25 items) 1 2 Next >
  • Sat, May 5 2012 11:06
    • Bodie
      Sun, Apr 24 2011
    • Cambs
    • Posts 81
    A few photos of my MX5 now with a stick on front number plate and square rear number plate.
    Lee
    2002 MX5 1.8 Arizona Blaze Yellow
    PI 30mm Springs
    K&N Typhoon Induction Kit
    LED Side Markers & Side Lights
    Zunsport Grille
    LED Angel Eye Fog Lights
    Stainless Exhaust
  • Sat, May 5 2012 19:06 In reply to
    • leemarb
      Mon, Nov 17 2008
    • hertford east herts
    • Posts 564
    Re: stick on number plate
    hi bodie, looks very nice, was there much to do, getting rid of the original no plate fixing holes, or did you just stick over them, also was it hard to stretch your new number over the curves, and still keep an even straight line.
    regards  leemarb
    ,,, I NOW KNOW THE MEANING OF SMILES PER MILE ,,,
    a member since 2005, with 400 + posts in a past life
    05, 2-5 titanium icon, 1.8i , 100mm dual oval larinis, matching hardtop (sometimes),
    6 c/d changer, all clear lights, some chrome, well quite a bit actualy,, i like it.
    P/s proud to be an " OLD GIT ",, and a "Grey",, "Grey Brigade Member".
  • Mon, May 7 2012 11:40 In reply to
    • Bodie
      Sun, Apr 24 2011
    • Cambs
    • Posts 81
     Hi Leemarb,
    I stuck it over the original holes, can't even tell they were there. Going over the curves of the bumper is a nightmare, will need to order another one at some point to have another go but for the minute it's not bad! I think it makes the front end look fresher
    Bodie
    PI 30mm Springs
    Zunsport Grille
    Stainless Exhaust
  • Mon, May 7 2012 11:48 In reply to
    • zpat
      Fri, Dec 31 2010
    • Posts 714
    Is the front one road legal?
    2001 mk2.5 1.8
  • Mon, May 7 2012 13:33 In reply to
    • Posts 4,479
    Technically no they are not legal, but ought to be really unlike plastic plates and plinths which break and fall off very easily these are a lot more `permanent`. I have stick-ons on both our Eunos Roadster and Mk1 and both are fine as far as two separate MOT stations are concerned. Police all over the country dont seem too bothered either.....
    Am going to add that I firmly believe the main reason for making people have upright BSAU approved front plates is to make it easier for `speeding tax` sneaky camera vans to read them at longer distances, so good enough reason on its own to have a stick-on.
    I have also noticed with a few `speed limit reminder` electronic boards around here that they notice Mk1s a lot easier and sooner if the headlamps are up (radar reflection again....)
    Dr. EunosGeek
  • Mon, May 7 2012 14:34 In reply to
    • zpat
      Fri, Dec 31 2010
    • Posts 714
    Yes, definitely a market for a radar absorbing paint finish and a low radar signature shape nose!
    2001 mk2.5 1.8
  • Mon, May 7 2012 14:42 In reply to
    • rogerzilla
      Sat, Dec 13 2008
    • Swindon, Wiltshire
    • Posts 582
    They're sort of legal on pre-2001 cars.  Technically I don't think you're supposed to fit a sticky plate now, but a pre-existing sticky plate - and no-one can tell when it was first put there -was "tolerated" under the law.
    On a post-2001 car it's definitely wrong as the plate must meet British Standard, and it won't.  You'd probably never get pulled up on it though, as the MoT only checks spacing and condition, not the type of plate.
    Mk3.5 Venture 1.8i in Meteor Grey, Wiltshire
    Formerly Mk1 1.8i in BRG
  • Mon, May 7 2012 14:58 In reply to
    • Posts 4,479
    rogerzilla:
    Both my MOT men have said, as long as they can read it from the MOT bay when its outside waiting to come in then its a passWink
  • Mon, May 7 2012 15:31 In reply to
    • Posts 4,479
    zpat:
    Just for you, have a giggle at this old chesnut Wink
  • Mon, May 7 2012 15:41 In reply to
     I did mine a little differently  (if the picture appears  ! )
    Don't wait for retirement, you may never get there !
    British Racing Green Mk 2.5 1.8 Sport.
    125,000miles but drives like a new 'un.
  • Mon, May 7 2012 15:52 In reply to
            Try again ! !
  • Wed, May 9 2012 17:26 In reply to
    • Bodie
      Sun, Apr 24 2011
    • Cambs
    • Posts 81
    I like where you've put your plateThumbs up, was thinking about mine there but went for lower down in the end (What a pain to fit)
    Bodie
    PI 30mm Springs
    Zunsport Grille
    Stainless Exhaust
  • Wed, May 9 2012 19:31 In reply to
     I know what you mean about trying to stick it around the curves. Thats why I went for moving the badge up onto the bonnet and re sticking it on with silicon sealant. My plate went on without any issues using water and a bit of baby shampoo to allow it to slip into position. I think the plate position gives it a more classic look without drawing too much attention from law enforcers.
  • Wed, May 9 2012 20:03 In reply to
    • Steve_C
      Sun, Oct 30 2011
    • Nottingham
    • Posts 332
    I've got a stick on and not had any issues from plod or the MOT.  I just like the E-type look!
    Mk1 RS Ltd - track car
    http://www.mx5oc.co.uk/forum/forums/t/39384.aspx
  • Wed, May 9 2012 22:18 In reply to
    • Posts 4,479
    Heres an `E-Type` look I prepared earlier.....
    Just spent most of the day converting the USA spec E-Type V12 5.3 to right-hand drive, a task not for the faint-heartedShock
    Dr. EunosGeek
