Car feels unbalanced
Last post Thu, May 17 2012 21:23 by taff eunos. 11 replies.
Page 1 of 1 (12 items)
  • Wed, May 16 2012 22:32
    • Rael
      Tue, May 18 2010
    • Gatwick
    • Posts 487
    So I'm moved from having a set of 16's to a set of 15's but for some reason this seems to have upset the balance of the car. When coming off the throttle, the car noticeably jerks to the right and under hard throttle, only noticeable really at motorway speeds, when it would jerk to the left.
    My initial thought was that this was due to tyre pressures so I have checked that they are all identical, and they are all 30 psi.
    Any thoughts? I am going to whack my old wheels back on tomorrow and drive down the same roads just to make sure it's not the car itself. Need to sort thsi ASAP as I'm off to the Ring next week!
    Cheers Cool
    1995 White Eunos Roadster 1.8 - Magz - lightly fettled
    2003 Jaguar S-Type-R
  • Wed, May 16 2012 22:55 In reply to
    • big.bry51
      Mon, May 25 2009
    • Scarborough
    • Posts 76
    Re: Car feels unbalanced
     Interesting, as far as I am aware the change in wheel sizes shouldnt have that kind of effect, so I am keen to know the outcome of the run on the older wheels. Sounds more like a brake in balance than anything else but what do I know, according to the wife every thing and nothing
    Bry n Chris
    1991 1.6 Eunos in real Red. All standard apart from a bit of cabin bling and stainless cat back.
    2003 1.8 S-VT Sport in BRG. As the Eunos slightly blinged up and a stainless cat back.
  • Wed, May 16 2012 23:12 In reply to
    • flying flea
      Sun, Oct 4 2009
    • medway towns (SE)
    • Posts 5,671
    Just a thought. But are all the tyres the right way round if they are directional ones
  • Wed, May 16 2012 23:26 In reply to
    • Rael
      Tue, May 18 2010
    • Gatwick
    • Posts 487
    I recently had coilovers fitted but with the old wheels on I am sure it did not feel like this. So, I will put the old wheels back on and test that so I can rule the suspension out.
    Thanks Mr Flea, I checked that and they are all directional tyres and all all facing forwards.
  • Wed, May 16 2012 23:30 In reply to
    • flying flea
      Sun, Oct 4 2009
    • medway towns (SE)
    • Posts 5,671
    Thats a good idea. To try that first Thumbs up
  • Thu, May 17 2012 5:49 In reply to
    • DavesBRG5
      Sat, Nov 15 2008
    • Bedfordshire
    • Posts 2,396
     Out of interest why 30 psi? I`ve always run mine 5s at 26 psi whatever tyre size i`ve had.
    Assuming they are all balanced up ok maybe time for a WIM alignment?
    1992 ROADSTER 1.6 Tanabe Sustec suspension, Cusco bracing, BBS Alloys, Momo Prototipo steering wheel, Mike Satur TT Hoops & Jass Performance interior bling.
  • Thu, May 17 2012 6:14 In reply to
    • Posts 4,404
    Morning Rael, are the 15" rims still fitted with the Barum tyres? If so I think thats where the problem may lay Thinking
    Since fitting the Yokohama Parada2`s and the 4.3:1 Torsen diff, I just cant get the back end of `Lightning`  to un-stick at all, they are simply awesomeBig Smile
  • Thu, May 17 2012 10:02 In reply to
    • Rael
      Tue, May 18 2010
    • Gatwick
    • Posts 487
    Dave - I can't really answer that with anything that would make a lot of sense - it's just a nice round number I suppose. They were at 36 before.
    John - yes indeedio they are indeed those wheels/tyres. Are they not that great then?
    I think what I will do is put my old ones on tonight, go out for a blast, and at least then I will know I have something to drive comfortably with. Thing is, they ideally need 2 new tyres and I am seriously running out of time before next week! I could also try swapping the current wheels/tyres front to rear to see if that makes any difference? It might just swap the jerking round to the opposite of what it currently is though.
  • Thu, May 17 2012 19:20 In reply to
    • Rael
      Tue, May 18 2010
    • Gatwick
    • Posts 487
    OK so test complete...I have put the 16's back on and....the problem has gone away. So, what the bugger is it? I have a very limited amount of time to sort this situation before embarking on a trip to the Nurburgring and I absolutely cannot deal with a car that's wobbling all over the place.
    I think my only option is to put 2 new tyres on my old wheels (2 are OK but 2 are unmatched and have seen better days) and use them for the journey. Annoying as I spent quite a bit of dosh on the little 15's!
  • Thu, May 17 2012 19:28 In reply to
    • Posts 4,404
    Hi Rael, I do think it might be those Barum tyres on the 15" Wheels, thing is you can have 4 Toyo T1R`s from Camskill for the price of 2 of 16" tyres so I know what I would do.....Don't know
  • Thu, May 17 2012 20:17 In reply to
    • Rael
      Tue, May 18 2010
    • Gatwick
    • Posts 487
    Yeah but I got no time to get that sorted now really, Camskill "might" be able to deliver them for Saturday but if not, then it's Monday and I'm at work all day during the day.
    What a pain in the backside. Fancy the wheels John?!
  • Thu, May 17 2012 21:23 In reply to
    • Posts 4,404
    I would take the wheels to a friendly local tyre fitter, have the new tyres delivered there, get them fitted and balanced for re-bolting to the car for Monday/Tuesday (maybe even have them delivered to a tyre fitter near to where you work)?
    I do `fancy` the 15"s but have just ended up keeping the ones off my V-Spec II as the new owner was trying to keep the costs down, the I.L Motorsport style bar, Jackson Racing exhaust, front lip spoiler (now fitted to Lightning) and up-rated rear adjustable ARB (soon to be fitted to Lightning) were all `deleted` options.
