Door to glass weather strip
Last post Sun, Jun 3 2012 11:15 by redmazda. 6 replies.
Page 1 of 1 (7 items)
  • Tue, May 29 2012 22:54
    • redmazda
      Fri, Nov 21 2008
    • south wales valleys
    • Posts 546
     Hi all has anybody taken the door to glass weather strips off a painted then up as mine are starting to look tired, also instructions to remove them and if anybody has painted them what paint any advice please thanks
    Previous mk1 eunos 1.6 classic red
    Now own
    Mk1 UK 1.6 1990 classic red with F.S.H
    E90 330 D BMW
    Fiat 500 1.2sport
    Winner of Raleigh Burner BOTY 2012
  • Tue, May 29 2012 23:53 In reply to
    • muppet
      Sat, Dec 12 2009
    • Chandlers Ford
    • Posts 1,100
    Re: Door to glass weather strip
    get hold of either mk2 or 2.5 ones they are smooth, look so much better.....it remove them be very carefull. Use a small flat bladed screwdriver to push the middle tab in  and gently lift each one, go and have a good look you will see what i mean.
    www.solentmx5.com
    Founding member of The Fan-tangos'
    Honorary member of the Buccaneer5
  • Wed, May 30 2012 6:55 In reply to
    • Mazda-mender
    • Pie land/NW England
    • Posts 7,032
     An old credit card etc will work, pushing slowly along under the strip until you hit the clips, as Muppet as said it is a number off plastic clips that hold it in place along the door skin and is kind of spring loaded in the centre and that is what is keeping it in place, there are two plastic lugs that hold them in place also at each end that folds around to the inner edge, these need to be popped first, but the strips are coated in rubber, and it is the rubber that is flaking off now showing the metal that should be hidden, put them in the bin and get some new ones or a good set of S/hand ones ,trust me you will be wasting your time trying to repair the old ones.
    http://www.mazdamenders.net/
    http://www.autolinkuk.co.uk/
  • Wed, May 30 2012 8:50 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 546
     Thanks muppet will look for a set thanks darran
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
  • Wed, May 30 2012 13:38 In reply to
    Mine need replacing soon too, or the door will start to rust. Trouble is at £100 a pair incl postage, it seems pretty pricey for what it is.
    However, mx5parts has 10% off those parts right now if you're doing it anyway...
  • Wed, May 30 2012 14:22 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 546
    That's pricey I'll have a look around first if not I'll rub them down and have them painted and lacquered if they don't turn out any good ill have to buy them then
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
  • Sun, Jun 3 2012 11:15 In reply to
    • redmazda
      Fri, Nov 21 2008
    • Posts 546
      done looking great
    Now own
    E90 330 D BMW
    Fiat 500 1.2sport
