Raindrops keep falling on my lap, they keep falling [Fixed]
Last post Fri, Jul 13 2012 16:12 by Vincent. 7 replies.
Page 1 of 1 (8 items)
  • Fri, Jun 8 2012 13:02
    • Vincent
      Fri, Jun 8 2012
    • Solent
    • Posts 44
    Hi all
    I'm  very much enjoying my Mk2 MX5, which I've had for coming up to 2 months now. What I'm not so keen on it the little spray of water I get across my lap coming from the window  when cornering after a heavy rainfall.
    Let me explain the problem in a little more detail.  Water sits in the orange section (see photo below), the  water will then shoot out from the joint between orange and blue sections. If the rain is heavy and persistent the water can also drip from the joint between orange and green. To deal with this I've taken to keeping a kitchen towel in the glove box and peeling  the orange section back so I can catch the water in the towel before it manages to find its way to my lap.
    I'm not sure if this can be sorted without replacing the hood, I saw something about foam fillers on this forum, but I couldn't follow where it went and I'm totally unsure where I'd source some.
    Any advice would be great, thanks in advance.
    Interior photo
    exterior photo
    "Midnight" blue 2000 1.8i Mark 2
  • Fri, Jun 8 2012 18:39 In reply to
    • Geoff Peace
    • Ashton-in-Makerfield Lancs.
    • Posts 907
    Re: Raindrops keep falling on my lap, they keep falling
     If you look above the pillar of the quarter light on the car body, you should see a small catch tray.  There is a drainhole for this which runs through the centre of the door seal.  Check this is not blocked by carefully threading a curtain wire through it.  Then check by pouring some water down, it should emerge at the bottom of the seal.
        Regards  Geoff Peace.
    2004. Mk.2.5 1600c.c. in radiant ebony
    location Ashton-in Makerfield, Lancs.
    Tantum faciendum parum dactum
  • Fri, Jun 8 2012 20:16 In reply to
    The problem would be considerably less bad if the roof wasn't split right there...but yes, it should drain away.
  • Mon, Jun 11 2012 16:44 In reply to
    • Vincent
      Fri, Jun 8 2012
    • Solent
    • Posts 44
    Thanks both, when you talk about drainage holes, do you mean these?  I cleard them no too long ago, and it stopped water in my boot, but not from sitting in the rubber seals.
  • Mon, Jun 11 2012 17:03 In reply to
    • Passell
      Fri, Nov 14 2008
    • Chesterfield
    • Posts 1,362
     Pop the front latches on the windscreen top rail. There are forward drain holes there that run right down the screen pillars.
    Doug Passell - Chesterfield
    Classic Red '89 Roadster
    Brilliant Black '91 Le Mans - 'Black Betty'
    Vin Rouge '95 VR A Limited - a real beauty. Thanks to the previous owner, Steve Clarke
  • Mon, Jun 11 2012 17:29 In reply to
    • Vincent
      Fri, Jun 8 2012
    • Solent
    • Posts 44
    Passell:
    Like this?
  • Thu, Jul 12 2012 22:17 In reply to
    • Vincent
      Fri, Jun 8 2012
    • Solent
    • Posts 44
    Hi Again, after playing with the hood seal retainers I've eliviated the problem ever so slightly. I'm still to try filling the seals with foam, but it's looking more and more like I'll need to stump up for a new hood.
    Is there a good supplier/fitter of hoods near Portsmouth? I've looked at MX5-Parts, but even factoring in £60 worth of petrol to get to swansea Jack Smiths still looks like a far better option.
  • Fri, Jul 13 2012 16:12 In reply to
    • Vincent
      Fri, Jun 8 2012
    • Solent
    • Posts 44
    I seem to have fixed the leak! following a suggestion I glazed all the seals with Vaseline. I was testing my tweaks with a 1L bottle, currently even with a bucket of water none is getting in.
