Clunk Engaging Gear from Neutral
Last post Fri, Aug 3 2012 23:00 by Rich M. 25 replies.
deflepps
Mon, Jun 11 2012
- Posts 34
Re: Clunk Engaging Gear from Neutral
Thank you all, I will have this properly diagnosed and let you know, if you wish.
Mazda MK3 1.8
woodsie
Tue, Nov 25 2008
- Milton Keynes
- Posts 44
Don't know what year or mileage your MX is/has done.Could be the clutch pedal needs adjusting/you need a longer left leg!!!!,or it's a rear brake pad sticking---quite common if you've had the handbrake on,but could also be the case if the foot brake has been on.
If you want to compare drives give me a ring on 07973633281 and meet up here or half way.
Haven't tried them myself yet but Sulston Hills(indy MX repairers/servicers) at Wing seem to be getting some good reports from peeps here.
MK3 2005 2.0i sport 58k miles approx
MK 3 2005 2.0i sport Bose(all black)
deflepps
Mon, Jun 11 2012
- Posts 34
Great - appreciate the offer!! I will have the car looked at this week to see if there is a specific reason to what I am hearing (perhaps I am being paranoid a little).
I head you way fairly often so for you to provide me with some expert suggestions/opinions would be much appreciated
Propbably going to try the MX repairers/servicers in Sulston Hills if needed, as you say the reviews look pretty good.
Just to confirm I have a MK3 2006 1.8, mileage at 41,000. Does this help you at all?
Mazda MK3 1.8
deflepps
Mon, Jun 11 2012
- Posts 34
Hi Guys, just a quick update, I have narrowed the noise down to the following:
1) I fully disengage the clutch, then
2) Push the clutch completely down , then
3) Move gearstick towards first and literally just before I engage first gear there is a clunk. Following this the gear will engage as normal.
Does this sound familiar to anyone? I am having this expertly reviewed this weekend but would be nice to have any further ideas so I don't get sold down the incorrect route.
Thanks in advance
Mazda MK3 1.8
victormeldrew
Wed, Feb 29 2012
- Wiltshire
- Posts 2,040
deflepps:Does this sound familiar to anyone?
Yes...it sounds rather like it did the first time you described it. There should not be any drivetrain shunt when engaging a gear with the clutch depressed...it means that drive is getting past the clutch when it is depressed, which is what happens when a clutch is not disengaging properly, i.e. is dragging.
However, I would also say that it is hardly the end of the world so, if you can live with it, save your cash until it gets worse.
Jon from Wiltshire - UK Mk1 1.6 Classic Red-ish Mods and Gadgets for your Five!Fault Code Readers, Warning Light Mods and More...Check out: http://www.binarypunk.co.ukWin binarypunk products! See my home page for details.Popup Wink Mod - Coming Soon!: http://youtu.be/xAquD1rJgYY
deflepps
Mon, Jun 11 2012
- Posts 34
Thanks do you know how much we are talking as a rough estimate and what needs to be replaced/adjusted?
Mazda MK3 1.8
Rich M
- Notts
- Posts 1,500
Hi, this is clutch drag. The first part of the gear lever movement engages the synchro which allows the gear to be selected on further movement but, because drive is being transmitted via the dragging clutch, you get the clunk as it engages. If the clutch wasn't dragging (the gearbox first motion shaft was stationary) you would get no clunk with that first movement of the gearlever. If the noise was due to slack in a uj or diff joint further back of the gearbox you would get no clunk on engagement but may get the clunk on releasing the clutch and taking up drive.
It could be for several reasons. First check how low the action is from the floor. If it is very low it may simply be the system has air in and needs bleeding or there may be another hydraulic fault such as master, slave, or pushrod adjustment. There are other causes though such as a tight spigot bearing, tight clutch plate splines or a clutch cover that's not lifting correctly. A hydraulic problem is by far the easiest and cheapest problem so do be sure this is investigated properly before letting anyone suggest (much) more expensive cures.
deflepps
Mon, Jun 11 2012
- Posts 34
Thanks, again sorry guys - how much will this cost to rectify worst case scenario?
Clutch drag sounds a little premature on a car that has done 41k? I guess this may relate to the former drivers.
Mazda MK3 1.8
Rich M
- Notts
- Posts 1,500
Hi, not really, you can have clutch drag with a brand new clutch or you can have it with a totally knackered one for any of my previous reasons. Cost could be anything from £40 to bleed it (if that's all it is) to £400+ for a new clutch so ask them to take a look and take it from there. Perhaps start at the dealer first for what should be a reliable diagnosis.
deflepps
Mon, Jun 11 2012
- Posts 34
Thanks Rich, I took my car to Mazda and they thought it could be clutch drag as you mention but haven't really come across it. They did however put my car up and test it - when the car made the noise the rear wheels would turn slightly, is this the clutch drag you referred to? What was interesting is they put a brand new MX up to compare and it did the same but to a smaller degree and maybe not as frequently which backs up your theory that it can exist on a new clutch. Mazda said it is unlikely to get worse and may have been existing from new, to save money they suggested maybe leaving it until or if it gets worse. Do you agree?
Your thoughts would be much appreciated
Thanks in advance
Ben
Mazda MK3 1.8
Rich M
- Notts
- Posts 1,500
deflepps:
Thanks in advance
Ben
Hi Ben,
Yes, that's clutch drag.
I'd return the car to Mazda, remind them about the diagnosis session and ask if they would,
1) bleed the clutch for you and 2) adjust out any excess free play in the clutch master cylinder pushrod (there is a 12mm nut on the clevis at the pedal).
That should not be expensive and if the brake fluid change is due (not been changed for a year or two) you might want them to do it as well as it is the same fluid and reservoir for clutch and brakes.
The clutch disengagement point of MX5 is very low near the floor and any air in the hydraulics or slack in the pushrod will lessen the amount of movement available to give clutch clearance when the lever is pressed down.
Clutch release point will usually get higher, giving more clearance, as the clutch wears and if it works well otherwise I'd agree with them and live with it a while and see if it gets better. Sometimes too it can help, when selecting 1st from stationary, to move the stick back towards 2nd first, not all the way into 2nd, just out of neutral towards it, then into 1st. This has the action of using 2nd synchro to stop the main shaft and so 1st usually then slots straight in.
