Floflex polybushes - concerns about fitting
Last post Thu, Jun 28 2012 17:52 by CarrotCakeIsYum. 7 replies.
Page 1 of 1 (8 items)
  • Mon, Jun 25 2012 7:49
    I'm in the process of fitting floflex polybushes and am having issues with the fit. Some of the bushes just seem too big, i thought I'd check on here that I'm not missing something/doing it wrong before getting in touch with floflex.
    The roll bar and upper wishbone bushes are fine, it's the rear lower wishbone giving me problems. The bushes stick out by a couple of mm (see pic of lower wishbone below), has anyone else had this problem?
    Compared to the upper wishbone:
    upper wishbone bush
    The bushes cannot be compressed in any further - the two halves are completely flush in the centre.
    Even the upper wishbone where the bushes don't protrude it's a much tighter fit when fitting the wishbone to the subframe. So tight I'm worried that the wishbone will struggle to pivot like it should do, surely the extra stress won't do the ride/suspension any favours?
    Compared to other bushes this kit was cheap - a sale price of around £90 for both front and rear wishbones and anti-roll bars. A case of you get what you pay for??
    Mk 1 1.8, 1998, completely standard
  • Mon, Jun 25 2012 15:04 In reply to
    • simplyred
      Wed, Jul 6 2011
    • Wainfleet, Lincolnshire
    • Posts 34
    Re: Floflex polybushes - concerns about fitting
    Yep! I think you've hit the nail right on the head.
    I'm in the middle of a referb myself and have been quoted £400 plus, by Mx5parts, for a full set of original rubber bushes, quit a difference in price I think you will agree.
    I know its of little consolation to you now, but it really pays to sound these products out first. I've been weeks gathering info and I was, at one time, considering poly but have decided against, simply because of the problems both you and other members seem to be experiencing, in both fit and or ride. So it looks like I may have to bite the bullit on price this time, even if it means doing the job in two halves over the winter months when the car is off the road.
    Having said that . . . What's the possibility of the Club organising a group buy on bushes? There must be a supplier out there who would jump at the chance of a half a dozen orders hit!
    Phil
    1991 Mk1 1.6 Classic red
  • Mon, Jun 25 2012 17:23 In reply to
    Yes I'd be interested in a group buy of (good quality) bushes.
    I've been reading up on these today, it looks like there are plenty of people with fitting issues, both on here and various other car forums. When I compared prices I thought along the lines of 'surely polybushes are going to be all the same, they're just lumps of plastic', clearly not! Confused
    Would it be a bad idea to trim the bush down so that it fits? At least this would allow me to finish the rear suspension and get back on the road.
  • Tue, Jun 26 2012 8:32 In reply to
    • simplyred
      Wed, Jul 6 2011
    • Posts 34
    Not sure if this helps, but if you go into the MX5nutz Club site, there is a guy with a similar problem. The heading is as follows ''My Experience Fitting Superpro Bushings'' It's on page two in the suspension section.
    Good luck.
    Phil
  • Tue, Jun 26 2012 8:34 In reply to
    • peleton72
      Fri, Jan 16 2009
    • Caernarfon, Wales
    • Posts 3,378
    • Committee
    I found the same problem three+ years ago when I fitted mine but they slotted in without too much fuss and made for a good, tight fit.
    No issues 3+ years on...and they're still very orange!
    MX-5 Owner's Club Motorsport Co-ordinator / Mission Motorsport Development Manager: jon dot earp at mx5oc.co.uk
    '95 Mk 1 1800cc, plus a few minor, subtle changes...
    The only one at the Blyton weekend who didn't break a record!
  • Tue, Jun 26 2012 10:13 In reply to
    • simplyred
      Wed, Jul 6 2011
    • Posts 34
    It does seem like can of worms this poly business, and why so many of us have problems with fitting. I suppose in the end it's down to us as customers to research and root out the good from the bad. Even so they shouldn't be allowed to get into the system. It's costly and a total waste of time, especially if the job has to be done again!Hitting head on wall
  • Wed, Jun 27 2012 13:00 In reply to
    Down the supermarket today were 4x chicken pies, Tesco Value brand...for the grand total of 25p per pie. You fancy a chicken pie that can sell for 25p and still make a profit?
    Sometimes things can be just too cheap for comfort.
  • Thu, Jun 28 2012 17:52 In reply to
    victormeldrew:
    Yes! Sounds like good after-pub grub to me!
    simplyred:
    Good luck.
    Phil
    Thanks for that. I'm going to do what he did and trim them or use a belt sander to take a mm or two off each bush. Will see how it goes this weekend.
