MK3 5th Gear Question
Last post Sun, Jul 1 2012 15:07 by arthur pringlestick. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Jun 29 2012 19:52
    • deflepps
      Mon, Jun 11 2012
    • Posts 34
    Hi Guys,
    Still getting used to my MX-5 MK3 and wondered if anyone finds it more tough to get into 5th gear than the others? There is no clunk or anything you just need to apply more effort than 1st, 2nd, 3rd and 4th gear.
    Thanks in advance
    Ben
    Mazda MK3 1.8
  • Sat, Jun 30 2012 9:40 In reply to
    • watchnut
      Sun, Feb 12 2012
    • New Forest
    • Posts 165
    Re: MK3 5th Gear Question
     I would suggest your not driving it properly.........maybe you should keep it in no gear higher than 3rd to enjoy it more.....and stay off motorways that way you will never need it....or move to Devon/cornwall or Scotland where the roads don't allow 5th gear....I hope this has been some help?
    Mine sometimes feels a little "notchy" going into 5th. but I put that down to lack of miles (23500 over 6 1/2 years) and hope it will free up a little when a few more gear changes have been done.....mine still smells new the last owner used it so little
    Black MK 3, 2006 2.0i, hard top,
    "Get your top off"
  • Sat, Jun 30 2012 12:43 In reply to
    • PMarley
      Sat, Jun 30 2012
    • Hopeman, Moray
    • Posts 5
    watchnut:
    I've only had mine for a few days, 3rd seems to be the gear of choice on the roads around me :)
    Mine has the same thing with 2nd gear until the gear box has warmed up, I would expect this to improve as I get some miles on the clock.
    2012 MK 3.5
    2.0L Sport Tech
    True Red
  • Sat, Jun 30 2012 13:59 In reply to
    • Chrisy Baby
      Wed, Jul 21 2010
    • Scunthorpe
    • Posts 14
    Second gear on mine is little tight when cold too. I used to struggle a bit with fifth, but I think I was pushing the stick too far over to the right to get it; it's almost as if fifth gear is really close alongside third and only takes a little push over to the right from fourth. Maybe that's me, but I don't have any problems doing that.
    MX-5 virgin
    2010 MX-5 1.8 SE
  • Sun, Jul 1 2012 0:33 In reply to
    To answer the original question, yes I find 5th a bit - not difficult but requiring a bit more effort than the other gears on my Mk3.5. It's seems a little more spring loaded than the other gears, I assume it's designed that way to  stop people (who "don't drive them properly" - jeez I can't believe some sanctimonious a/hole actually said that) inadvertantly finding 5th when going for 3rd.
    2010 1.8 Mk3.5 Miyako in glorious Velocity Red
  • Sun, Jul 1 2012 12:50 In reply to
    • deflepps
      Mon, Jun 11 2012
    • Posts 34
     Thank you, this an answer I was looking for.
    Mazda MK3 1.8
  • Sun, Jul 1 2012 15:07 In reply to
    No probs Ben - how are you enjoying the Mk3?  I'm loving my Mk3.5 - only had it a few weeks, although I am booking it in for a 4 wheel alignment check this week. I noticed when I had the wheels off checking the brake pads for wear that the two front tyes are wearing on the inside and the steering wheel isn't quite straight when the wheels are.  There are so many suspension adjustments that can be done on these cars that it makes sense ot make sure everything is perfectly lined up to get the most out them.  This one just seems a bit more skittish over bumpy bends than my old Mk 1 was so I'm sure I'll feel a difference after the alignment has been done.
