Both mk3 remote keyfobs intermittently working
Last post Sun, Jul 8 2012 19:13 by bk65. 3 replies.
Page 1 of 1 (4 items)
  • Sat, Jul 7 2012 23:06
    • VROOM
      Sun, Jun 17 2012
    • Posts 11
    Hi all,
    I've just bought 55 reg mk3 and am having trouble with the remote locking. Both key fobs work sometimes when locking/unlocking the car. They can work one minute, but not the next. Often I have to resort to the key. I've changed both batteries and the keys start the car fine. Any ideas? Cheers.
  • Sat, Jul 7 2012 23:48 In reply to
    Re: Both mk3 remote keyfobs intermittently working
    Try carefully bending the contacts of the battery contact terminals so they make better contact with the battery. There was a Mazda technical bulletin for that issue saying "The negative terminal in the transmitter is deformed, causing a poor contact to the battery.". The mass production change at VIN 115416 was to change the shape of the negative battery terminal in the transmitter. If the last 6 digits of your VIN are less the the 115416 then you probably have an early type transmitter.
  • Sun, Jul 8 2012 18:50 In reply to
    • VROOM
      Sun, Jun 17 2012
    • Posts 11
    Thanks for that Thumbs up - I think it's worked. Will see how it goes. Now I just need to dry out the carpets from the blocked drain tube and the car should be sorted Big Smile
  • Sun, Jul 8 2012 19:13 In reply to
    • bk65
      Thu, Jun 16 2011
    • Rainham, Kent
    • Posts 641
     Thanks Robbie....stopped using one of mine about a year ago because of this problem....i'd just put it down to wear & tear
    BK(Big Kev)...Member of the Grey Brigade and the Buccaneer5
    2006 galaxy grey mica mk-3 2.0i sport..BBR-Cosworth supercharged..eibached..s/steel c/back exhaust..ebc t/groove discs..y/stuff pads..subtle bodykit...CW alloys shod with T1-R's
    Currently re-living my youth in Rainham, Kent
