Car Won't Lock
Last post Wed, Jul 11 2012 18:22 by Geoff Peace. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Jul 8 2012 22:40
    • bassman57
      Sun, Jul 8 2012
    • Holmfirth, West Yorks
    • Posts 7
    Car Won't Lock
    My MX5 Phoenix SE (2002)  - is refusing to lock with either remote fob or key. Any suggestions/advice would be appreciated
    When I attempt to lock the vehicle you can hear the lock mechanism operate then a quieter noise which sounds like the lock returning
    Just prior to this problem becoming apparent the alarm went off when I had locked the car so I unlocked the car and the central locking  hasnt really worked since
    In the short term I am intending to disable the central locking by removing the fuse and possibly the immobiliser fuse if its possible.
    Thanks for reading
    Ian
    2002 MX5 Mk2.5 Phoenix, Silver
  • Tue, Jul 10 2012 0:32 In reply to
    Re: Car Won't Lock
    I'd guess at a faulty drivers side door lock mechanism, I've known of it before. You can remove the door lock fuse but not the immobiliser fuse.
  • Tue, Jul 10 2012 9:34 In reply to
    • bassman57
      Sun, Jul 8 2012
    • Posts 7
    Re: Car Won't Lock
    Yea silly me what sort of Alarm system could be disabled in this way!!!
    I will investigate the lock when I get chance, already removed the fuse and this has stopped the problem, now the keys work only, bit of an incovenience but I had wondered how this effects the immobiliser? How is it set etc.
    Having only had previous experience of Mini's, MGs and other easy to understand cars I am finding the modern electrics a bit daunting, coded keys, computers etc.  I have sent off for the Paul Hardiman MX5 Renovation Manual, hope this will include some guidance on electrics
    Ian
  • Tue, Jul 10 2012 11:13 In reply to
    Re: Car Won't Lock
    If the doors can't lock properly for some reason, it unlocks again to make it obvious to you that it isn't secure.
    Possibly some lubing will help, or maybe a new solenoid is required.
  • Wed, Jul 11 2012 16:27 In reply to
    • bassman57
      Sun, Jul 8 2012
    • Posts 7
    Re: Car Won't Lock
    A good dose of WD 40 has done it, seems to be working ok now
    cheers
    Ian
  • Wed, Jul 11 2012 18:22 In reply to
    • Geoff Peace
    • Ashton-in-Makerfield Lancs.
    • Posts 907
    Re: Car Won't Lock
     I advocate regular oiling of door locks, say once a month. A good spray will disperse water and any accumulated dirt.  Minimises wear and tear and troubles such as the above.  This used to be part of a service along with door, bonnet and boot hinges.  Nobody seems to bother now!  Until a hinge binds, then snaps!
         Regards  Geoff Peace.
    2004. Mk.2.5 1600c.c. in radiant ebony
    location Ashton-in Makerfield, Lancs.
    Tantum faciendum parum dactum
