Immobiliser/Alarm is faulty (Finishline system?)
Last post Fri, Jul 27 2012 17:59 by DanB91. 2 replies.
Page 1 of 1 (3 items)
  • Fri, Jul 27 2012 12:37
    • DanB91
      Thu, Jul 5 2012
    • Tonbridge, Kent.
    • Posts 28
    Hey guys, when I bought my 1.6 mk1 the previous owner told me about the immobilser which had been fitted by another P/O, but that he had never used it himself. Edit: Turns out it's a Finishline system, I think from a nwer model but put into this '91?
    Since I've had the car I've never used it properly, basically because I didn't know how it worked. Can anyone tell me how it is meant to work properly?
    After some digging around I found the connection to the button under the steering column was dodgy, traced the wire back to the black 'MAZDA 2096' box and disconnected it thinking it may help - didn't.
    By touching the ends of this wire though the system still worked, that's how it is currently, though it is a pain since it doesn't always work. How do I repair the system properly and tidily?
    Or is it possible/recommended to remove the system entirely? At the moment the battery is getting drained a lot by playing around with it, so need a solution ASAP.
    All replies welcome, thanks for reading I know it was long winded.
    Dan.
    22/06/12 - Red 1991 1.6 - Terrible paintwork - Two way adjustable HSD coilovers - mx5parts stainless exhaust - Not too pretty but she's mine.
  • Fri, Jul 27 2012 12:38 In reply to
    • DanB91
      Thu, Jul 5 2012
    • Tonbridge, Kent.
    • Posts 28
    Re: Non standard immobiliser is faulty.
    Can upload photos if needed, ta!
  • Fri, Jul 27 2012 17:59 In reply to
    • DanB91
      Thu, Jul 5 2012
    • Tonbridge, Kent.
    • Posts 28
    Some photos, hopefully better explained:
    This brown wire originally went to a red push button under the steering column. The other end goes to the BLACK (Not light) Mazda box on the right hand side.
    This button had also perplexed me since I got the car:
    The wires, pink and grey, from the button lead under the centre console and also to the black Mazda box:
