coolant loss
Last post Fri, Aug 10 2012 10:14 by Zimmerframe. 10 replies.
Scotland1971
Sat, Jun 2 2012
- yorkshire
- Posts 6
afternoon,
i've recently had a new rad fitted as the old one was blocked and caused the engine to overheat for a couple of miles.
since i've replaced the rad i cannot get the levels right in the expantion tank; its been fitted about a month and have topped up everytime i've been out, but just half a glass full really which is normal for the first week of a new rad; yesterday did about 40miles, checked the levels this morning and the expantion tank was nearly emply!
any thoughts?
mx-5 mk-1 1800 classic 97
Geoff Walton
- Posts 11,134
G'day mate Welcome to the forum--
Just signed in for the first of many visits? Please pop your location in your profile, and the year and model of your MX5 in your sig. This helps enormously when we try to answer questions.....
Forum Technical Index
Are you making sure that the rad is full right to the top [no air gap]? And as was said a new Mazda filler cap should be used, some after market items have known issues.
Richardn
- North Cumbria (north of Hadrians Wall)
- Posts 2,549
Either headgasket failure, or you are filling above min when cold
If you fill above min when cold it will spit out coolant as it expands
National Competitions Coordinator Mk3 2.0 Sport and Mk1 California 217 http://www.mx-5scotland.com/ http://www.mx5england.co.ukHoods supplied and fitted
Scotland1971
Sat, Jun 2 2012
- yorkshire
- Posts 6
rad always filled right up, i also have the coolent in the expantion tank toped up to max, is this wrong?
pressure test tonight so i'll let you know.
kind regards
Scotland1971
Sat, Jun 2 2012
- yorkshire
- Posts 6
did pressure tests last night, no prob when cold, did chemical test, no prob, warmed the car pressure test again and water dripping out from an area below the engine windscreen end, cant locate it at all even with coil pack out.
still drives well and pulls like a train, apart from the loss of water everything feels fine
any thoughts
Page 1 of 1 (11 items)
