Paintwork - Clear coat
Last post Tue, Aug 14 2012 10:04 by Back2Black. 21 replies.
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
I have looked at the FAQ's but have not seen any comments re: bodywork. Can anyone suggest the best compound for
removing swirl marks and medium scratches from clear coat. I have looked at different sites/products but find it a bit
confusing as the best product to buy. I have purchased Meguiars cleaner/polish which is fine for finishing before waxing, i
also have a tin of fine compound which does not appear to do any better than the Meguiars cleaner/polish. I
need a cutting compound that will remove (above) without causing too much damage and bring the finish
back. I realise that wet/dry 2000/3000 is required to remove deeper scratches. (I made the error of using 1200 and had to
work hard to get rid of the marks).
I would be grateful for any suggestions and comments from anyone who has tackled this on clear coat!
2004 1.8i MK 2.5 in Black Mica No artificial colour or flavouring.
dfr
Fri, Jul 17 2009
- Northern Ireland
- Posts 861
Re: Paintwork - Clear coat
farecla g3 is good for getting all but the finest swirl marks out , then use 3m machine / hand glaze to remove the compound swirls / hologramming left
if you have really really bad paint , you could start with g6 then g3 then onto the machine glaze , followed by 3m rosso red polish ;)
you will have a stunning finish using these..... heres my mk2 after a buff using the above method, i started with g3 due to it being full of swirls and a few light scratches
www.mx5roadsters.net
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
dfr:
Many thanks dfr - looks very good. I have to do mine by hand as have no machine, apart from battery powered polisher. Also my garage is very dark which is not much help
in actually seeing what i'm doing! Will check out the gear that you've suggested. Thanks again.
Reg
Nedski
Thu, May 17 2012
- lincolshire
- Posts 431
I'd agree with above . Mine was scratched and the paint was turning white with oxidation, i used G3 and then 3M Finesse-it abrasive polish and then a final hand polish . Without a machine polisher though your in for a hard time, it can take a good half day using a machine if you have to bring old paint back to life. good luck
EX member of the Glorious Green Gang. New Project. 1991 Eunos 1.6 Silver Tubocharged, Koni coil overs, Roll Bar, 1.8 brake upgrade, stainless exhaust no cat. Lots more to do.
If your a wild eyed looser at the gates of oblivion then hitch a ride with us. Cause were riding the last freedom moped out of nowhere!!
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
Nedski:
Thanks Nedski - the finish isn't weather damaged etc, just swirls/scratches and of course the unpreventable paint chips on the front.
I had already done the boot lid and bonnet, but didn't turn out to what i wanted, there was still slight scratch marks that the compound
didn't remove. Will have to start the next attempt on the door panels and see how that goes (i'll try the suggested brand) and then re-do
the other. Yes, it's a nightmare job to do by hand but really have no option. Biggest worry is after getting it right is picking up a bit of
grit on the sponge or whatever next time it's washed or waxed, black is certainly hard to keep imaculate ( or as near to). I guess to remove
the stone chips from the front panel means rubbing down and re-painting, don't know if there's any other method bar touch-up-paint, which is
ok for the odd chip but not when there's a lot of them.
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
dolphinboy400:
don't use a sponge for washing the car you need to use a wash mitt or microfibre cloth or you will put more swirls into the paint each time you wash
Thanks for the tip - out of interest, why is there less chance of having any foreign matter in a wash mitt or fibre cloth than in a sponge?
Also out of interest, which region of the country are you in?
dolphinboy400
Sun, Aug 5 2012
- Dorset
- Posts 94
a microfibre draws the dirt up inside where as a sponge the dirt stays close to the surface. I dont have any scientific evidence to back this up only that every manufacturer says the same thing
I live in the south/south west ( bournemouth)
thanks
Danny
1994 eunos rs-ltd
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
dolphinboy400:
Cheers db400 - makes sense, thinking about it, if a speck of grit was picked up in a sponge then i guess it would probably stay lodged in it.
I shall no longer use a sponge - thanks again.
dolphinboy400
Sun, Aug 5 2012
- Dorset
- Posts 94
no problem , happy to pass on what i've been told :)
thanks
Danny
1994 eunos rs-ltd
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
dolphinboy400:
Would be nice to see photo of your car if possible!
dolphinboy400
Sun, Aug 5 2012
- Dorset
- Posts 94
I have had my car 2 days, and i am a novice my self . I have just done the boot lid so far and have managed to get rid of most of the swirls :) Give me another week and i'll post some more pics up !
The farcella stuff i have heard is good as was said above. I got the meguires system and used the ultimate polish for the boot. One of the things I have heard many times is start off gradually instead of going in balls out as you dont want to damage your paint! Unless your a recent lottery winner you can really spend a bundle on this stuff so you need to be careful. Meguires website does have a load of videos showing you the basics, after that its loads of elbow grease or an expensive mop
thanks
Danny
1994 eunos rs-ltd
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
dolphinboy400:
Quite agree! - the stuff isn't cheap and my problem is choosing what to get as there seems to be loads of stuff to do the job. I just wonder if the G3 is any better than the compound
i already have, if not then it's a waste of money. I did watch a lot of the video clips on the subject, i think i need to get some waffle pads too! Do you use the black carnauba wax?
I have used nothing else up to now as with other waxes tends to leave white marks where there's stone chips.
Back2Black
Sat, Jul 16 2011
- Taunton Somerset
- Posts 1,559
dolphinboy400:
i think it's just the standard carnuba wax. It certainly makes a difference anyway. I would use what you got and go from there. If the swirls are slowly going then maybe you gotta try a few times with the same stuff. Thats kinda where i am now, gonna do the whole car and see how it looks thenn maybe go at it again in a couple of weeks
I started off with the 'Black Box' (by Turtle Wax) last year, it brought up a lovely shine, though it was nicely cleaned when i bought it, but had the
usual hedge scrapes along the n/s panels, which are still mostly there. The kit did not remove the swirl marks as suggested, but the Meguiars cleaner/polish
has got rid of the worst of it. Mostly just scratches to remove now but need to get off my ass and get on with it, and must remember to discard the 'sponge'
before the next wash. Have got quite a bit of the black carnauba wax left but when that runs out will see if i can get just the black wax rather than the kit
again.
