Clutch Squeak....
Last post Thu, Feb 23 2012 18:04 by Little bob. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Sun, Jan 22 2012 9:54 In reply to
    • Posts 9,956
    Re: Clutch Squeak....
    Rich M:
    Thanks Geoff, you may have been careful to apply it only to the metal parts of the pushrod and piston and none has migrated to the cylinder bore. The thought of someone pulling back the boot and giving it a blast from an aerosol of mineral grease is not good Shock.
    That's why I said in a post above
    "do not use ordinary lube WD40 anything that isn't suitable for use on hydraulic seals.They will perish and the clutch slave will expire."
  • Sun, Jan 22 2012 10:08 In reply to
    • Posts 588
    Geoff Walton:
    Rich M:
    Lithium grease is also mineral oil based and should not be used.
    2005 MX5 Mk3 Launch Edition
    Velocity Red 2 litre Sport 6 speed LSD 30K miles
  • Tue, Jan 24 2012 10:44 In reply to
    • spaniel
      Sat, Sep 3 2011
    • Posts 115
    I have a simple question. It's very confusing reading this thread. I have a squeaking clutch. I want to pull back the rubber boot on the actuator and spray some grease in... Which grease though. I'll be going to halfords... Bit advice on which type? I was going to get white lithium but I'm having doubts now.
    1.8 Mk1 mx5
  • Tue, Jan 24 2012 13:27 In reply to
    • Posts 9,956
    spaniel:
    To avoid any confusion, get some of this:
    Castrol Red Rubber Grease
    A special, rubber compatible grease for use on hydraulic brake and clutch components where hardening or swelling of rubber must be avoided.
    Useful in assembly of rubber components for brake, clutch and suspension units
    Again, do not use any spray lubricants. No WD40, Plus Gas or anything else out of an aerosol
  • Sat, Jan 28 2012 20:48 In reply to
    • Crystalblue
      Sat, Aug 6 2011
    • Berrow, Somerset
    • Posts 29
    Sprayed some silicone grease on mine today. Squeaking now gone.
    2001 Crystal Blue 1.8 Mk 2.5
    Member of the Blue Brigade.
  • Thu, Feb 23 2012 16:33 In reply to
    • Little bob
      Thu, Mar 31 2011
    • Posts 45
    Would this stuff be safe to use with the rubber boot and seals?
    http://www.3inone.com/products/silicone-spray/
    It says it's OK with rubber, but I don't want to take any chances.
    But I do need to get rid of the squeak!
  • Thu, Feb 23 2012 17:45 In reply to
    • Posts 588
     Yep, if you're in the UK Halfords do that one and also their own which I use around the garage for rubber and plastics, http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219033_langId_-1_categoryId_165705#tab1
  • Thu, Feb 23 2012 18:04 In reply to
    • Little bob
      Thu, Mar 31 2011
    • Posts 45
    Thanks Rich - I spotted in Halfords but thought I would double check first.
    Actually, thinking about it I have some silicone sparay lube in the garage already, better check that one befoe I buy another.
