cant get in gear!!!!
Last post Fri, Jul 3 2009 23:11 by mimicuk. 15 replies.
mimicuk
Fri, Nov 28 2008
- Posts 9
Hi was wondering if anyone can give me any advice on my gear change problem, i have an MX5 Mk1 1994, the problem is when i set of in the car in 1st gear everything is fine but when i need to change gear i have to press the clutch pedal straight to the bottom to change, if not it just wont go into any gear at all, i have to put it in nutral then foot to the floor with the clutch.
I have topped up the fluid but it still does the same thing. I have been told it might need a new slave cylinder! do you think this might be the problem? This is doin my head in :(, please can someone help me
Regards Mimic
goochie
Sat, Jan 24 2009
- cambridge
- Posts 99
hi mimic, was the resevoir low when u topped it up?........if so the most logical conclusion would b slave cylinder, havin to replace mine as soon as mx5 parts deliver
snow fun when u meet a kerb! mk1 1.6 1993 eunos roadster twin exit diy nexus exhaust induction kit, 16inch wheels flash to pass drilled n grooved discs x4 style bar, v8 fuel economy 17(ish) mpg
goochie
Sat, Jan 24 2009
- cambridge
- Posts 99
ho hum, so can only change gear when pedal fully depressed?...........difficult to engage gear (notchy) when changing? reverse selection grating?
goochie
Sat, Jan 24 2009
- cambridge
- Posts 99
mimic hav to get it checked, but sounds like maybe clutch/pressure plate fault, because even with a weepin slave cylinder it would still operate untill there was no fluid left, as u say resevoir still full........... or possibly bent actuating arm?, if u find clutch is the problem get new slave cylinder too (£19 mx5 parts delivered)
alan-mx5
Tue, Sep 30 2008
- South Devon
- Posts 372
Or it could be the clutch master cyl. They can leak internally, so no fluid lose, but faulty non-the-less.
goochie:
1800cc Mk2 MX-5 Sport 1999 South Devon
Geoff Walton
- Posts 9,390
I would do the slave first. Cheap and easy to do and the cause of most clutch problems with a '5---
mimicuk
Fri, Nov 28 2008
- Posts 9
Cant seem to find the article on the website you mentioned?
Sorry for being a pain
Geoff Walton
- Posts 9,390
alan yates:
miniicuk go into www.miata.net locate garage on the left open that go into engine and drivetrain, drivetrain then onto Shift boot replacement don't forget its from the usa so things may be on the other side if you now what I mean.It only script no pikkies sorry found smoe pickkies for you just above the shift boot replacement look at Transmission, g/box & shifter oil changes picture No 18 onwards you would have to do this to replace the rubber boot. good hunting.
Far simpler to go to the FAQ index on our own forum ---
