cant get in gear!!!!
Last post Fri, Jul 3 2009 23:11 by mimicuk. 15 replies.
Page 1 of 2 (16 items) 1 2 Next >
  • Sun, Jun 28 2009 16:03
    • mimicuk
      Fri, Nov 28 2008
    • Posts 9
     Hi was wondering if anyone can give me any advice on my gear change problem, i have an MX5 Mk1 1994, the problem is when i set of in the car in 1st gear everything is fine but when i need to change gear i have to press the clutch pedal straight to the bottom to change, if not it just wont go into any gear at all, i have to put it in nutral then foot to the floor with the clutch.
     I have topped up the fluid but it still does the same thing. I have been told it might need a new slave cylinder! do you think this might be the problem? This is doin my head in :(, please can someone help me
    Regards Mimic
  • Sun, Jun 28 2009 16:47 In reply to
    • goochie
      Sat, Jan 24 2009
    • cambridge
    • Posts 99
    Re: cant get in gear!!!!
     hi mimic, was the resevoir low when u topped it up?........if so the most logical conclusion would b slave cylinder, havin to replace mine as soon as mx5 parts deliver
    snow fun when u meet a kerb!
    mk1 1.6 1993 eunos roadster
    twin exit diy nexus exhaust
    induction kit, 16inch wheels
    flash to pass
    drilled n grooved discs x4
    style bar,
    v8 fuel economy 17(ish) mpg
  • Sun, Jun 28 2009 16:53 In reply to
    • mimicuk
      Fri, Nov 28 2008
    • Posts 9
     No it was just a fraction below max
  • Sun, Jun 28 2009 17:04 In reply to
    • goochie
      Sat, Jan 24 2009
    • cambridge
    • Posts 99
     ho hum, so can only change gear when pedal fully depressed?...........difficult to engage gear (notchy) when changing? reverse selection grating?
    flash to pass
    style bar,
  • Sun, Jun 28 2009 17:28 In reply to
    • mimicuk
      Fri, Nov 28 2008
    • Posts 9
     I think you hit the nail on the head there buddy :)
  • Sun, Jun 28 2009 17:35 In reply to
    • goochie
      Sat, Jan 24 2009
    • cambridge
    • Posts 99
     mimic hav to get it checked, but sounds like maybe clutch/pressure plate fault, because even with a weepin slave cylinder it would still operate untill there was no fluid left, as u say resevoir still full........... or possibly bent actuating arm?, if u find clutch is the problem get new slave cylinder too (£19 mx5 parts delivered)
    flash to pass
    style bar,
  • Sun, Jun 28 2009 17:52 In reply to
    • mimicuk
      Fri, Nov 28 2008
    • Posts 9
     Cheers buddy you've been a great help :) poppin over to mx5parts now
  • Sun, Jun 28 2009 18:45 In reply to
    • alan-mx5
      Tue, Sep 30 2008
    • South Devon
    • Posts 373
    Or it could be the clutch master cyl.  They can leak internally, so no fluid lose, but faulty non-the-less.
    goochie:
    1800cc Mk2 MX-5 Sport 1999 South Devon
  • Sun, Jun 28 2009 23:18 In reply to
    • Posts 9,393
    I would do the slave first. Cheap and easy to do and the cause of most clutch problems with a '5---
  • Mon, Jun 29 2009 16:23 In reply to
    • alan yates
      Sat, Dec 13 2008
    • thornton
    • Posts 822
     Mimic Does your car have a gear selection boot just under the carpet early mx5 had a problem with the boot failing and giving problems selecting gears just a thought it maybe worth a look.There is a paragrapgh on how to change this boot on www.maita.net
    宮古市. 2010 3.5 mx5 1.8 Miyako Velocity Red Mica #39;I've got one.宮古市.
    2003 Mk2.5 sport in splash green gone but not forgotten. Thornton Nr Blackpool Lancs.
    You have the right to remain silent. Anything you say will be misqouted, then used against you.
  • Mon, Jun 29 2009 20:04 In reply to
    • mimicuk
      Fri, Nov 28 2008
    • Posts 9
     Cant seem to find the article on the website you mentioned?
    Sorry for being a pain
  • Mon, Jun 29 2009 20:35 In reply to
    • alan yates
      Sat, Dec 13 2008
    • thornton
    • Posts 822
    miniicuk go into www.miata.net locate garage on the left open that go into engine and drivetrain, drivetrain then onto Shift boot replacement don't forget its from the usa so things may be on the other side if you now what I mean.It only script no pikkies sorry found smoe pickkies for you just above the shift boot replacement look at Transmission, g/box & shifter oil changes picture No 18 onwards you would have to do this to replace the rubber boot. good hunting.
  • Mon, Jun 29 2009 21:10 In reply to
    • Alex1988
      Thu, May 14 2009
    • Somerset
    • Posts 84
    Perished shift boots might make gear changing notchy, but it won't give the problems you descibed. I would do the slave cylinder first, then maybe consider looking at other options if there is no improvement (pressure plate and master cylinder as above).
  • Mon, Jun 29 2009 21:24 In reply to
    • Alex1988
      Thu, May 14 2009
    • Somerset
    • Posts 84
    Although having thought about it some more, I'd been inclined to agree with goochie about the weaping slave cylinder... Hmm...
  • Tue, Jun 30 2009 0:34 In reply to
    • Posts 9,393
    alan yates:
    Far simpler to go to the FAQ index on our own forumWink---
