'91 Eunos Mirror fallen off
Last post Wed, Nov 17 2010 11:30 by lizhosken. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Fri, Oct 16 2009 19:25
    • suecurrie
      Fri, Oct 16 2009
    • Salisbury
    • Posts 42
     Hi All
    Nightmare trying to find the bit where you can write a post.  Anyway hopefully there now.  Drivers wing mirror knocked off today leaving the arm attached to the car.  Do I need to get complete new mirror or is there some way of reattaching.  Inside mirror casing is a lot of rattling so obviously some rusty bits inside.  Also if new mirror required no visible external screws so presumably have to fix via inside of drivers door?
    Sue
    J reg Eunos - red
    Love my graphics
  • Fri, Oct 16 2009 20:52 In reply to
    • Mr Reman
      Sun, Nov 30 2008
    • Bristol
    • Posts 2,719
    Re: 1991 Eunos roadster
    This has been asked SOOOOOOOOO many times before, So I've just cut and pasted what I wrote last time........ (Call me lazy If you want !) Big Smile
    They say a picture speaks a thousand words........ I hope thats true 'cos my wing mirror just fell off and I'm in no mood for posting a 6000 word essay Smile
    Right then to get the shell and bezel apart I used a small flat screw driver on the outside, breaking the dots of glue as I went.
    http://www.fileden.com/files/2007/4/16/989771/Wing%20mirror%20shell.JPG
    See the little white dots around the edge? Thats where it's glued too the bezel.
    http://www.fileden.com/files/2007/4/16/989771/Mirror%20rim.JPG
    Close up of the edge of the bezel.
    http://www.fileden.com/files/2007/4/16/989771/Mirror%20rim%20closeup.JPG
    Next is the spring, A replacement bolt (A coach bolt I found in one of my tool boxes) and the ball joint.
    http://www.fileden.com/files/2007/4/16/989771/Ball%20joint%20and%20bolt.JPG
    My original bolt had rusted to the point that it split the ball joint in two, So I had to epoxy the ball joint back together, While I was at it I epoxied the bolt to the top of the spring (As its a coach bolt it has a square on the shank under the head thats meant to pulled into the wood to stop it from turning)
    I couldn't get the bottom of the "cup" part of the ball joint off the car (Screws are too tight and I don't want to snap one of 'um off), This made it a pig too get a spanner on the nuts underneath, If I had thought it through first I would have possibly dremeled out a square on the ball parts hole to put the coach bolt in the other way up.
    http://www.fileden.com/files/2007/4/16/989771/Shell%20back%20on%20the%20car.JPG
    I then glued the bezel back on, I only put 15 or so little dots of super glue on the edge of the shell as I figure if I ever have to change the glass in it I don't want to destroy the body trying to split it again.
    http://www.fileden.com/files/2007/4/16/989771/Glass%20back%20in.JPG
    I also smeared the glass with liquid hand soap before putting it back together, I seem to remember that super glue vapour can stick to glass and make it look etched.
    Hope it helps,
    Scotty B.
    I'm all for spontaneity,
    But please, Can everyone give me one weeks written notice that it's going to happen?
  • Fri, Oct 16 2009 21:54 In reply to
    • Earl Grey
      Thu, Oct 23 2008
    • Stratford-upon-Avon
    • Posts 182
    1996 MX5 Mk1 1.8iS
    BRG, BBS alloys, Blitz Induction,Twin Exhaust,
    The Glorious Green Gang
  • Sat, Oct 17 2009 9:43 In reply to
    • suecurrie
      Fri, Oct 16 2009
    • Salisbury
    • Posts 42
     Hi Scotty
    What a wonderful person you are - many many thanks.  Have a great weekend.
    Sue
    J reg Eunos - red
    Love my graphics
  • Sat, Oct 17 2009 11:02 In reply to
    • Posts 11,082
    Mr Reman:
    Scotty I'll make this a stickey and do something with it for the FAQs
  • Sat, Oct 17 2009 11:33 In reply to
    • Mr Reman
      Sun, Nov 30 2008
    • Bristol
    • Posts 2,719
    Look out sue !!!!
    Geoff's about to make this sticky ! Quite impressive that he can do this all the way from Australia. Big Smile
    ......... (OK, My sense of humour may be a little bit on the smutty side, But at least it made me chuckle.Big Smile)
  • Sat, Oct 17 2009 15:17 In reply to
    • Posts 11,082
    Mr Reman:
    Look out sue !!!!
    Geoff's about to make this sticky ! Quite impressive that he can do this all the way from Australia. Big Smile......... (OK, My sense of humour may be a little bit on the smutty side, But at least it made me chuckle.Big Smile)
    No problem for us down here mateWink---
  • Sat, Oct 17 2009 15:51 In reply to
    • niggle
      Fri, May 29 2009
    • Posts 2,672
    Thanks. Mr Reman. I had always wondered how to remove the mirrors without breaking anything. This gives me the confidence to remove my mirrors for refinishing.
  • Sat, Oct 17 2009 16:33 In reply to
    • Mr Reman
      Sun, Nov 30 2008
    • Bristol
    • Posts 2,719
    niggle:
    Glad to hear it mate !
  • Sat, Oct 17 2009 16:41 In reply to
    • lizhosken
      Sun, Oct 23 2011
    • Bristol
    • Posts 2,655
    Mr Reman:
    Look out sue !!!!
    Hi Scotty
    youre at it again I see!!! {#emotions_dlg.wink}
    At least I know you're quite 'armless really ...................these naughty humours will get us into trouble, but a chuckle is always good  {#emotions_dlg.tongue}
    liz
    J2 Ltd........now called Lola
    Member of the ‘Yellow Perils’
    Member Of 'The Old Gits Clan'
  • Mon, Nov 2 2009 21:50 In reply to
    • rogerzilla
      Sat, Dec 13 2008
    • Swindon, Wiltshire
    • Posts 482
    For what it's worth, light rubbing with nail polish remover (acetone) shifts superglue film very easily.
    Mk3.5 Venture 1.8i in Meteor Grey (when it arrives)
  • Mon, Nov 2 2009 23:31 In reply to
    • Mr Reman
      Sun, Nov 30 2008
    • Bristol
    • Posts 2,719
    rogerzilla:
    I didn't know that (Every days a school day !),
    That's handy to know as the proper "De-bonding" solvents I used to use to clean up repairs are bloody expensive !!!
    Scotty B.
  • Tue, Nov 10 2009 14:53 In reply to
    • ivan
      Sun, Sep 20 2009
    • Cavehill, Belfast
    • Posts 45
     Funny enough, my mirror fell off on Saturday. So this post was very well-timed. Also really informative. I've now put the mirror back in place at a cost of 23 pence - I decided to push the boat out and pay for 2 washers. Great post. many thanks.
    Ivan
    Northern Ireland
    Ivan
  • Tue, Nov 10 2009 16:53 In reply to
    • suecurrie
      Fri, Oct 16 2009
    • Salisbury
    • Posts 42
     Hi Ivan
    Glad it helped.  As well as the small cost for the screw/washers etc. it cost me £10.   I found it very fiddly and not having a socket set didn't help.  However, two lovely men came to fit new immobiliser and I did the helpless female bit and they very kindly attached the mirror for me and I consequently  rewarded them with a £10 note.
    Sue
    J reg Eunos - red
    Love my graphics
  • Mon, Feb 8 2010 10:57 In reply to
    Re: '91 Eunos Mirror fallen off
    Hi Sue I had/have the same problem. I managed to get a replacement bolt that fits inside the mirror from, www.autolinkmx5.com  . The only problem is taking the coach-work from the door to get at the inside. Maybe you might need to take it to a garage to get them to fit it. It'll at least be cheaper than a new mirror. If you've already solved the problem perhaps you could tell me how you fixed it!!
    Good luck    Richard
