Differential assembly mystery
Last post Sun, Nov 13 2011 8:59 by Geoff Walton. 12 replies.
Page 1 of 1 (13 items)
  • Sun, Feb 28 2010 12:50
    • ni-smith
      Thu, Jun 11 2009
    • Posts 4
    Locked Reply Contact
    A 54,000 mile service Diff Assembly oil change revealed 2 metal 'tags' (see photo). Has anyone taken a diff assembly to bits and/or might be able to suggest what they might be or be the remains of?
    mystery bitshttp://s954.photobucket.com/albums/ae23/ni-smith/
    No idea how long they've been in there but there's no excessive noise from the assembly and all seems fine on driving.
    The garage have suggested replacing the whole assembly - mega ouch!
    Any ideas?
    Nige + Iz
  • Sun, Feb 28 2010 13:08 In reply to
    • dfr
      Fri, Jul 17 2009
    • Northern Ireland
    • Posts 678
    Re: Differential assembly mystery
     look like part of a clutch plate
    not good
    www.mx5roadsters.net
  • Sun, Feb 28 2010 21:39 In reply to
    They are 2 of the tags of the side washers from the limited slip part of the diff. I've seen them come out with the diff oil a few times. I'd just keep driving it until the diff gives up. It'll probably go on for ever!
  • Mon, Mar 1 2010 21:41 In reply to
    • ni-smith
      Thu, Jun 11 2009
    • Posts 4
    Thanks Robbie,
    We've looked at various 'exploded' diagrams of the diff assembly but failed to see what the 'bits' might be.
    We'd decided to carry on driving since the 'bits' may have been in there for ages with no apparent ill effects.
    Your being able to id the tags and your advice makes us feel a lot happier with that decision!
    Thanks,
    Nige + Iz Smith
  • Thu, Mar 4 2010 1:14 In reply to
    The washers are inside the diff cage which apparently can't be disassembled so are not available separately. Therefore they are not shown on the parts catalogue.
  • Sat, Mar 13 2010 12:32 In reply to
    • ni-smith
      Thu, Jun 11 2009
    • Posts 4
     Done a bit more research and found some pics on a Dodge site (!) of a dismantled diff and the 'bit's look like the tabs on the clutch plates! Presume if tabs have sheared off then the clutch plates will just be spinning?.
    diff clutch plates
  • Mon, Mar 15 2010 20:15 In reply to
    Your diff doesn't have clutch plates like those in the photo. The plates in your diff fit between the sun gears and the diff cage. There are 4 tags per side.
  • Mon, Mar 15 2010 22:03 In reply to
    • Andy
      Thu, Nov 13 2008
    • Cambridge
    • Posts 205
    Mine is one of the ones Robbie has seen where a similar piece of metal came out on the magnetic drain plug when the diff oil was changed. He gave me the same advice :-) That was about 18 months and 12k miles ago and I haven't had any sign of further problems.
    Andy
    1996 Mk1 Eunos 1.8 S-Special Type II, Montego Blue
  • Tue, Aug 10 2010 13:07 In reply to
    • oldbloke
      Wed, Nov 26 2008
    • Hemel Hempstead, Herts. UK
    • Posts 60
    We have had the same frightening appearance of these self same bits when the diff oil was changed.
    Ours also shows no signs of noise or worrying sounds from the diff, so I guess we will just roll-on {#emotions_dlg.indif}
    The MX-5 has done some 36500 miles.
    Martin & Wendy
    One Of The Chiltern Chalkies
    2004 Mk2 facelift 1.8i Sport. Strato Blue
    Bog-standard; well apart from the shiny bits!
    Feeling Alive In A Five
  • Fri, Aug 13 2010 16:34 In reply to
    • ni-smith
      Thu, Jun 11 2009
    • Posts 4
     Well we've done 6k since, coming up to 57k miles with no difference in handling, noise
    Rolling on,
    Iz
    Cool
  • Tue, Mar 8 2011 8:11 In reply to
    Smile
    Well i'm not the kind to kiss and tell, but i've been seen in a mk2......
  • Sun, Nov 13 2011 8:35 In reply to
    • Porthcawl, South Wales
    • Posts 2,867
    Mk 1 Eunos V Special 1.8 1994 with all the right things done to make it go and stop and go around corners better than most.
    Organiser of annual `Nurburgring on a Budget` trip for MX5/Eunos only. Also `Lightning McQueen` replica just for a giggle :) http://www.mx5oc.co.uk/forum/forums/t/37709.aspx
  • Sun, Nov 13 2011 8:59 In reply to
    • Posts 9,383
    Guys this topic is getting a good airing here  http://www.mx5oc.co.uk/forum/forums/t/19726.aspx  .
    So I'll lock this one down
