Hi everyone.
The wifes car is a 2002 1.6 Zetec Focus. 67000miles.
As a precaution, two weeks ago changed the cambelt and tensioner as part of a kit. Work done by Ford dealer.
Two weeks and twenty miles later I have a problem.
Started car, drove approx 1 mile. Stopped car. Started the car again and then it appeared to stall.
Tried to start and only get clicking.
Engine warning light comes on.
Lights horn etc all work.
Called the RAC. Patrolman initially diagnoses either flooding or cambelt. I don't mention it has been recently done so as not to change his fault finding.
He diagnoses a cambelt / tensioner failure as when the car is in gear and pushed, the camshaft does not move.
The cambelt was still in position and I could see it with the top cover removed .
The problem is that the Ford garage that did the work say the cambelt is intact and the tensioner is okay.
They are doing further diagnosis.
As the belt does not drive the water pump, can anyone suggest a reason why the car does would not start.
TIA
