Changes to 6 speed transmission in NC Facelift.
Last post Tue, Jun 1 2010 10:26 by Roadster Robbie. 0 replies.
Page 1 of 1 (1 items)
  • Tue, Jun 1 2010 10:26
    Locked Reply Contact
    Taken from Mazda new model training manual
    • The 6-Speed MT is the P66M-D that has already been used for the predecessor.
      Compared to the previous P66M-D however, it has the following new features:
      - The cones of the 1st to 4th gear syncronizer rings are partially plated with carbon for
         higher durability and smoother shift feel.
      - The diameter of the 3rd and 4th synchronizer rings have been enlarged (6mm) for
         easier synchronization at high engine speeds.
