ABS Fault Code Reading NA(MK1) - NB (MK2)
Last post Sun, Jun 20 2010 23:22 by Forum Technical. 0 replies.
Page 1 of 1 (1 items)
  • Sun, Jun 20 2010 23:22
    Locked Reply Contact
    To check for DTC on the ABS system on MX-5 turn ignition switch to off, bridge the TBS and GND terminals in the DIAGNOSTIC socket under the bonnet, turn the igniton switch to on and count the groups of flashes on the ABS lamp. Long flashes count tens, short flashes count units. To clear DTC, allow all codes to be output (flash codes repeat) then with ignition switch still on, press and release the brake pedal 10 times at less than 1 second intervals.
    Diagnostic Trouble Codes are as follows
    05 - Brake Switch open circuit
    11 - Right Front Wheel Speed Sensor Open circuit or Short to power supply
    12 - Left Front Wheel Speed Sensor Open circuit or Short to power supply
    13 - Right Rear Wheel Speed Sensor Open circuit or Short to power supply
    14 - Left Rear Wheel Speed Sensor Open circuit or Short to power supply
    15 - Wheel Speed Sensor, Sensor Rotor
    22 - Front Right Solenoid Valve Signal (AV)
    23 - Front Right Solenoid Valve Signal (EV)
    24 - Front Left Solenoid Valve Signal (AV)
    25 - Front Left Solenoid Valve Signal (EV)
    26 - Rear Solenoid Valve Signal (AV)
    27 - Rear Solenoid Valve Signal (EV)
    41 - Right Front Wheel Speed Sensor Rotor Short to ground or Disagreement with other sensors is detected
    42 - Left Front Wheel Speed Sensor Rotor Short to ground or Disagreement with other sensors is detected
    43 - Right Rear Wheel Speed Sensor Rotor Short to ground or Disagreement with other sensors is detected
    44 - Left Rear Wheel Speed Sensor Rotor Short to ground or Disagreement with other sensors is detected
    51 - Valve Relay fault
    53 - Motor monitor fault
    61 - ABS Control Module fault
    63 - ABS Module Power Supply Malfunction
