Start up rattle on a 2.5 (Oil?)
Last post Sat, Sep 18 2010 17:27 by Phil S. 16 replies.
Phil S
Sun, Aug 2 2009
- A wheel turn from the Olympic Park
- Posts 253
I sometimes get a noisy rattle on my 1.8 2.5 for 1 to 2 seconds on start-up, particulary if the car has been parked on a slant (hill). I saw this:
http://www.mx5oc.co.uk/forum/forums/t/225.aspx
However mine is a 2003 model and I assume already has the mods. It's nice and smooth after the 2 seconds, I've changed the oil with a new Mazda filter but it still happens. Wondered whether the mod made any difference and whether it's a real problem. Anybosy else get this on a 2.5. Is there any further info on this anywhere?
2003 Mk2.5 Sunlight Silver S-Vt Sport 1.8 All stock - can't afford the extra Insurance premiums.
Phil
Phil S
Sun, Aug 2 2009
- Posts 253
Re: Start up rattle on a 2.5 (Oil?)
No response on this so I'll ask a relevent question:
When I changed my Oil I used Mobil S, Semi Synthetic, 10w-40. Would it improve the initial rattle if I used Fully Synthetic 0w-40 as I've read that this Oil gets round the engine quicker on start up.
Phil
Geoff Walton
- Posts 9,383
G'day Phil
No response usually means nobody has any ideas. I'm afraid I don't either. Maybe the oil level is down and you are suffering because of the slope. Check the oil level and see what happens after you park on a bit of level ground.
I don't think that changing oils would effect the problem
Phil S
Sun, Aug 2 2009
- Posts 253
Thanks Geoff.
I'm sure I've seen somewhere that others have had this rattle on 2.5s and it is associated with the VT gear even after the new parts were fitted from Mazda, but it's not really a issue, just annoying. I just can't find any other info other than the link above.
Wondered if others know any more and/or whether synthetic oil would help.
Phil
alan yates
Sat, Dec 13 2008
- thornton
- Posts 820
Hi Phil Just found your thread, I to have a Mk2.5 1.8 sport, and on start up it rattled for 2 sec's or so but I did change the oil to fully synthetic Castrol Magantec and used the OE oil filter cannot hear any ratlle at present, but I have to say I have changed the oil and filter at 6000 mile intervals Once start up I don't rev the engine just let it tick over for 5 seconds or so before I move off.
Cheers Alan
宮古市. 2010 3.5 mx5 1.8 Miyako Velocity Red Mica #39;I've got one.宮古市. 2003 Mk2.5 sport in splash green gone but not forgotten. Thornton Nr Blackpool Lancs. You have the right to remain silent. Anything you say will be misqouted, then used against you.
jonnyenglishpants
Sun, Jan 11 2009
- nelson
- Posts 11
jonnyenglishpants:
yes it is oil, how often do you change your oil, the rattle is caused by thin oil draing from your hydrolic tappets when the engine is at rest, ie thin oil or well used oil will drip back to your sump faster than a fast thing good oil will stay in the tappet cause its thick, so when you start the engine a good oil will stay in the tappet giving you a noise free start. dont use fully synthenic, mine runs on coma 10/ 40 and its fine, however if you leave the car standing for a week or so you will get a rattle for a second till the oil pump fires it round, old school cars. happy days
o and by the way castrol magnatec 10w-40 is over priced rubbish, thats not fit for lawn mowers belive me ive tried it, use Comma 10w-40 5 Litre Semi Synthetic Motor Engine Oil and change every 6000 miles. sorted. ps my car runs a turbo running at 200bhp.
jonny
Geoff Walton
- Posts 9,383
jonnyenglishpants: the rattle is caused by thin oil draing from your hydrolic tappets when the engine is at rest
On a Mk 2.5????????????????
Mazda-mender
- everywhere
- Posts 5,044
01mx5:it's just a heat shield  at the front before the cat.
The Disclaimer:-...This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects, the articles/answers/comments are provided for information purposes and they are not intended to substitute informed professional advice, I /or the Mx5 owners club can not personally be held responsible for any damage occurred from following this procedure or any injuries from it. Proceed at your own risk. http://www.mazda-mender.co.uk/
01mx5
Thu, Jan 8 2009
- Central Scotland
- Posts 2,872
Mazda-mender:
That's the one - and it's thin enough you can just re-shape/move it by hand.
If/when mine get's worse I'll sort it again - but so far it only happens when the date is a prime number and there's wind blowing north east at 24mph and at least 2 of the planets in our solar system are aligned... Or, when I think "good, not had that rattle for a while...must have sorted itself"
Ramsay Ashby - Website & Forum Administrator
Red 2003 MK2.5 Sport
Mazda-mender
- everywhere
- Posts 5,044
01mx5:
They are only tack welded on and with age and where it is ,it just becomes loose,a zorst bracket for your local car shop should fix it by just re- clamping it back down solid,but dont over tighten it and crush the zorst ,couple of Pounds and fixed for good.
This will happen on the Mk 1's also, as well as the Mk 2's
niggle
Fri, May 29 2009
- Huddersfield, West Yorkshire
- Posts 2,651
Mazda-mender:They are only tack welded on and with age and where it is ,it just becomes loose,a zorst bracket for your local car shop should fix it by just re- clamping it back down solid,but dont over tighten it and crush the zorst  ,couple of Pounds and fixed for good.
Good tip! Mine's held together with rusty baling wire at the moment. Maybe the kind of thing that plumbers use to fasten earth bonding straps to water pipes would work, or these?
Mazda-mender
- everywhere
- Posts 5,044
niggle:
I like the look of those snap straps,going to order some and see if they work,nice one nigel.
I'll send an e-mail again with some pic's,the file was to big,so was knocked back
alan yates
Sat, Dec 13 2008
- thornton
- Posts 820
I have been in the transport industry all my life and in most cases Castrol oil was used up to 800 bhp engines down to 1.1 ford engines and always has been a good product.
