head gasket
Last post Wed, Sep 8 2010 19:39 by Phil H. 29 replies.
Pollyanna
- Northallerton, North Yorkshire
- Posts 3,156
Before spending big money, give the engine a good clean and wash using some GUNK. You brush it among-st all the dirt and oil then rinse it off with warm water, but don't forget to wrap up any electrics with polythene bags etc. When it is clean keep a close eye on it to try and diagnose where it is leaking, it could be something as simple as the cam cover seal needing to replaced.
If we new where you lived you may get an offer from someone near to you to come and help you out.
goodshipalbion
Fri, May 28 2010
- Darlington
- Posts 200
i would echo the above comment...cam cover gasket far more common problem in a 5 than headgasket failure...and much easier / cheaper to fix :)
2000 W MX5 California. iPod / USB / SD stereo, Audiobahn Component Speakers, 250w foot well Sub, Style bars, Strut Brace and lots of chrome bits....Proud to be a "Yellow Peril"
Tue, Apr 1 2008
- Ely, Cambs
- Posts 2,734
To answer your question about changing the gasket yourself, really depends on how limited your mechanical knowledge is and more so what tools and equipment you have access to. I'd advise you go and by a Veloce workshop manual and read through the procedure yourself then decide if it's a job you want to tackle. Allow yourself plemty of time to do it, better to spend 2 weekends doing it once than 2 weekends doing it twice.
Disclaimer Any work you do to your car is entirely your own responsibility. If in doubt, you should check technical advice with an independent , qualified person who has seen your car. The MX-5 Owners Club, its officers and forum contributors accept no responsibility for any damage caused to your person or property as a result of you following or not following the advice offered on this forum. roadsterrobbie.co.uk - mx5easternregion.co.uk - havemorefun.co.uk - merlotmotorsport.co.uk
Geoff Walton
- Posts 9,383
Living where you do, I would pop over and see Andrew at Autolink for an opinion. He is a very reputable guy and a first class MK5 tech.
Amy
Sat, Aug 21 2010
- Herts
- Posts 75
A quick note if you do decide that you need to go the head gasket route. Someone's already mentioned making sure that you have all the available tools, and to take your time. This really is very important - getting to the head gasket is fiddly, but generally as long as you're methodical and sensible and have a good guide to work from, it's perfectly manageable.
There are a couple of things that you really do need to have / have access to though - firstly and most importantly, a torque wrench. The head bolts have specific torque settings, and it is CRUCIAL that these are done correctly. Too tight and you'll risk warping / cracking the head, and too loose and all manner of poo can come your way in the guise of nasty engine problems (we had this on the other half's Capri - had to redo the head gaskets and found the head bolts were literally finger tight. We think that was probably the root cause of the car needing a lot of TLC...).
The other is getting your hands on some feeler gauges (much cheaper than a torque wrench!) as you'll need these for valve clearances.
Best of luck finding the problem.
Amy.
Very proud owner of a 1990 1.6 Eunos V-Spec import.
My other car - also a RWD BRG drop top, but British and 36 years older than my Eunos... - was crowned Classic Car of the Year 2010. Thanks to anyone who voted :)
niggle
Fri, May 29 2009
- Huddersfield, West Yorkshire
- Posts 2,651
Amy:The other is getting your hands on some feeler gauges (much cheaper than a torque wrench!) as you'll need these for valve clearances.
Not required on this engine as it has hydraulic lash adjusters.
Amy
Sat, Aug 21 2010
- Herts
- Posts 75
niggle:
Coo, very fancy...
(I'm used to working on rather older engines, my bad, apologies)
niggle
Fri, May 29 2009
- Posts 2,651
No apology necessary.
Depends on what you mean by "older". The first engine that I came across with hydraulic tappets was the GM Family II OHC engine introduced in Vauxhall/Opel FWD models in the late 70's. I suspect that hydraulic tappets had appeared elsewhere before then.
Amy
Sat, Aug 21 2010
- Herts
- Posts 75
niggle:
I'm most used to working on Mini engines (proper ones, not these modern things) which hadn't much changed since the original 60s design and 1950s engines as well (see my sig) and definitely need feeler gauges for both :) I'm hoping not to have to find out what I need to do to my 5 in order to get at the head gasket (at least, not for quite a few miles!)
