The missus took her car, a 97 Honda CRV to the local garage this morning for the MOT.
It failed, and now she is thinking the car is as good as a write off. We are planning on selling the car as she needs a 7 seater, but now she thinks its not worth anything.
Im trying to convince her thats not the case! Ive been through the lsit with her and told her it sounds a lot worse than it is. The advisories are just that, and do not make the car fail.
The garage also seem to word the failiure sheet to sound a lot worse than it is too! Last year she took another car to the same garage, and ended up virtually giving it away becaue they did the same thing with it....
Here is the failiure details:
Offside front drivers seat insecure
Nearside front suspension arm excessive play in ball joint,
Offside front (track rod end) steering locking device missing.
Well, so, the seat needs tightening up somewhere (They have told her they wont know until they remove the seat, hence a nice labour charge before they start.
The ball joint... well, Im sure I can do that once they point out to me which one it is when I go round later.
The locking device missing... a glamourous way of saying the split pin is missing!
And here is the advisory list:
Nearside front (bottom) suspension arm rubber bush deteriorated,
Offside front (bottom) suspension arm rubber dush deteriorated,
Nearside rear tyre worm close to legal limit,
Nearside rear coil spring corroded,
Offside rear spring corroded,
Nearside rear radius arm rubber bush deteriorated,
Offside rear radius arm rubber bush deteriorated,
Nearside inner rear (sill) body has corrosion,
Offside inner rear (sill) body has corrosion,
Nearside rear vehicle structure has corrosion,
Offside rear vehicle structure has corrosion,
Offside front Anti-roll bar rubber bush deteriorated,
Brakes ONLY JUST passed,
All 4 tyres cracked and need replacing
To me there is nothing major there. I have been under the car recently when i replaced part of the exhaust, and there is surface rust on it. Not as bad as what was on my 5 before I had it undersealed.
Rusty springs??? Come on!
Bushes, yes, I can imagine they are, but there is no knocking or banging coming from the car when you drive it, in fact it drives fine. The brakes work well, better than mine.
Why oh why do garages have to scaremonger people like this? Or am I missing something?
Well, I have a busy weekend ahead, but just looking for comments from anyone about this.
Thanks in advance
Andy
