Wheel weights, members findings
Last post Sun, Sep 14 2008 6:41 by Forum Technical. 0 replies.
Page 1 of 1 (1 items)
  • Sun, Sep 14 2008 6:41
    Locked Reply Contact
    Forum members wheel weights
    14 inch
    Original type 14" alloy with yoko tyre - 11kgs.
    The original 14" bare alloys are quoted as 12.3lb (5.6kg)
    Mazda steel wheel with Colway remould - 12kgs.
    14" Mazda 5 spoke dealer fit alloyswith new unused Eagle F1 GSD2 tyres: 13.7kg/30.2lb14"
    Panasports with Goodyear Eagle F1 GS-D2s, it was 29lbs, about 13.2 kg.
    14" BBS alloy just under 4kgs (8lbs).
    14" Minatour minilite replica with Colway 70 profile remould off MGB - 13kgs.
    CT Racing 5 Spoke Bridgestone 185/60/14
    14kg
    14 inch Racing Sparco (Crimson.inc). 5.6kgBBS
    14" alloys as fitted to original S-Special, with centre cap and valve: 11lb 3.5oz/5.09kg
    Watanabe 8 spoke Wt 12.5 Lb, 5.6Kilos [14”]
    15 inch
    15" alloy fitted as standard to '97 Mk1 with Avon tyres - 19kgs
    TSW Stealth with Goodyear Ventura 195/50/15........17kg
    Advan RG magnesium/alloy 7x15 with Toyo T1-R = 11.7kgs
    15" BBS bare alloys..12.0lb (5.4kg)
    15" Lorber Deep Dish Rims .5.5kg
    Original Classic alloy (15x7 ET35 as it turns out) and nearly new GSD3 at 19.5kg.
    15x7 Enkei RP-F1t 4.38kg = 9.65lbs.
    Toyo Toyo T1S 195/50/15 bare tyre 7kg
    15"
    Watanabe 8 spoke Wt 13.0 Lb, 6.0Kilo
    15x8 6UL = 12.4lb/5.6Kg
    15x9 6UL = 12.7lb/5.8Kg
    16 inch
    16x7 ADVAN RG with new 205/45/16 TOYO t1-R's came in at 12.8Kg total.
    16" Sport alloys 15.5lb (7.0kg)
    17 inch
    Wolfrace Ikon with Toyo T1s 205/40/17  18kg
