Usk. 13th March
Last post Thu, Mar 24 2011 21:30 by Dowot. 17 replies.
Page 1 of 2 (18 items) 1 2 Next >
  • Sun, Mar 13 2011 17:55
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Usk. 13th March
    Ermmmmmmmmmm wer'd every one go!
    Met up, chatted, we all set off.and thats the last I saw of 24 other 5's
    Still the run to Abergaveny, following one other 5, was nice if a little lonely.
    After Aber, I found myself on the Merthyr road and closer to home than Usk.
    Hope dinner was good.
    93 Eunos. 1800 Black with sparkles. South Wales (The car NOT S.Wales!)
  • Sun, Mar 13 2011 19:06 In reply to
    • lizhosken
      Sun, Oct 23 2011
    • Bristol
    • Posts 2,229
    Re: Usk. 13th March
     Remind me not to join in any magic tricks with you Dowot, I like to know where I am Wink
    Should make an interesting story finding out what happened, are you volunteering to lead any runs this side of the bridge? Wink
    J2 Ltd........now called Lola
    Member of the ‘Yellow Perils’
    Member Of 'The Old Gits Clan'
  • Sun, Mar 13 2011 19:25 In reply to
    • Posts 3,327
    Re: Usk. 13th March
    Dowot:
    Hiya mate, I know what you mean the lead cars took off like a Le Mans start and a lack of communication meant there was very little chance of staying on their tail........
    Me and several other cars got separated in Caerleon and ended up meeting the high-speed snake at the Gwent police headquarters roundabout, most of the cars had a short break in the Abergavenny car-park then without a whole lot of warning, the Le Mans guys fired up again and another high speed persuit started with just a few cars in the initial convoy and everyone else following some minutes back.
    The actual run was well planned and a good route on a few roads I had never used (and some that I still have never used)
    Lunch was fabulous @ the Kings Head in Usk, seems a large contingent had booked for lunch at the Usk Conservative Club and that this had seemed to cause some confusion with our bookings there and an un-certainty as to whether the Con Club would be able to accomodate everyone and a decision was made at Wednesdays` SWMX5OC meeting at the Grove in Porthcawl that we would have to book an aternative venue for the lunch because of this un-certainty over numbers they couls accomodate. Don`t know what the Con Club lunch was like compared to the Kings Head?
    Shame you got separated, you certainly were not aloneSad
    Dr. EunosGeek
    Mk 1 Eunos V Special 1.8 1994 with all the right things done to make it go and stop and go around corners better than most. see http://www.mx5oc.co.uk/forum/forums/t/42529.aspx
    Organiser of annual `Nurburgring on a Budget` trip for MX5/Eunos only. Also `Lightning McQueen` replica just for a giggle :) http://www.mx5oc.co.uk/forum/forums/t/37709.aspx
  • Mon, Mar 14 2011 13:57 In reply to
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Re: Usk. 13th March
    Caerleon? You went there? Where was that on the page of instructions?
    Looking at the map, seems I was lost from about the 0.3 mi point!
    Not sure who I was following, but they turned right onto the B4598 and took the direct route to Abergavenny.
    So nobody else saw the windmill?
    That valley road was great, be even better when they resurface it, theres a wonderful bridge over the river.
    Sorry I missed the admentment to eating venue, thought all the meal tickets had gone.
    Oh well heres to next time....gona fix a tracking device to that leading car though.
    Good day nevertheless.
  • Mon, Mar 14 2011 14:03 In reply to
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Re: Usk. 13th March
    lizhosken:
    Magic tricks...I'm good at making money dissapear!
    I knew all alone where I was. Behind the wheel of a 5. Stick Tongue Out (Does that make me a nut?)
    Path, garden, leading, up.....ring any bells.
    Not looking too good for the run to Silverstone on the 27th, must admit.
    Big Smile
  • Mon, Mar 14 2011 20:49 In reply to
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Re: Usk. 13th March
    Being the clever sort that I am, I can now post pictures, so here are some of the Usk cars.
    http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303007.jpg    line up of 5's
    http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303010.jpg
    http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303008.jpg
    http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303005.jpg
    http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303004.jpg
    http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303002.jpg
    http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303012.jpg
    Now if no pictures appear, then I retract my skills statement.
  • Mon, Mar 14 2011 20:52 In reply to
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Re: Usk. 13th March
    <a href="http://s1088.photobucket.com/albums/i325/Chris_Harris51/?action=view&amp;current=uskouting1303010.jpg" target="_blank"><img src="http://i1088.photobucket.com/albums/i325/Chris_Harris51/uskouting1303010.jpg" border="0" alt="Photobucket"></a>
  • Mon, Mar 14 2011 20:54 In reply to
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Re: Usk. 13th March
    Banging head on wall
     OK I have no idea, suppose I need to read the instructions, which may the reason I got lost and the wardrobe never got finished. Big Smile
  • Mon, Mar 14 2011 20:55 In reply to
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Re: Usk. 13th March
  • Mon, Mar 14 2011 20:56 In reply to
    • Posts 3,327
    Re: Usk. 13th March
     Hi Buddy, some of us saw the windmill and nice bridge but that was on the way back from Abergavenny, oh dear, seems you may have followed the google map backwards-they went that-a-way down to Caerleon, across to Cwmbran (some of us got lost there and went on M4 then back-up towards Aber then met them coming from the right at the cop-shop HQ in Cwmbran, THEN Abergavenny then back past the windmill and to the various eateries for lunch in Usk.
    Pierre was looking for you in Aber..
    Hope that sorts out the confusion? To be honest I nearly lost the leaders of the run and I do quite like to pop along a bit.....
    See you soon,
    Dr. EunosGeek
  • Mon, Mar 14 2011 22:57 In reply to
    • rex1943
      Tue, Sep 21 2010
    • Posts 44
    Re: Usk. 13th March
     Help,Eira & I are still on the Usk run, wacky races comes to mind, we are new to all this, but didn,t realise it was a race. Beautiful weather wonderful scenery, saw the windmill, and thought we really have gone the wrong way now and returned to Usk. The colour of the lead car [yellow] only saw it briefly when the maps were handed out, then saw it disappear out of the car park, and never saw it again!
    My wife even phoned Tina [Dr Eunos Wife] requesting the mobile number for Dr Eunos whom I once followed for a millisecond prior to getting lost!! He was in Abergavenny and we were back in Usk!! It reminded me of the film ET when he wanted to get back home. Had a good laugh, thinking of buying a motor bike for the next run when we get back from Usk.
    JF.
  • Tue, Mar 15 2011 11:10 In reply to
    • Dowot
      Sat, Dec 11 2010
    • Posts 111
    Re: Usk. 13th March
    JF,
    See you got one of those new fangled detached houses, looks good, low maintainence by the looks of it.
    You got that "new central heating", ie fire in the middle of the room? Big Smile
    Maybe the lead car should throw out scrap paper as they go, a la a paper chase?
    Wrong way, I wonder if that accounts for the solo MX I saw heading towards Aber as I left?
    Taff. Yes Pierre got hold of me, I did not have his mobile otherwise I would have asked where he went to.
    Note to self...in future read the instructions before starting the motor. Big Smile
  • Tue, Mar 15 2011 17:27 In reply to
    • rex1943
      Tue, Sep 21 2010
    • Posts 44
    Re: Usk. 13th March
     Still in Usk, reading the instructions, think we got it now, on to Abergavenny ................Big Smile
    JF.
  • Wed, Mar 16 2011 10:28 In reply to
    • VO5Jo
      Sat, Mar 27 2010
    • SWM - mid Wales twig
    • Posts 2,762
    Re: Usk. 13th March
    LOL! can't help laughing
    i was one of the threecars that started to follow you the wrong way from Usk but two of us have radios (popular amongst SWM OC) and decided to about-turn. We were able to say to Snurfy that it seemed wrong but he opted to take the other scenic route with you guys.
    If we'd been able to communicate with you and say "TURN AGAIN WHITTINGTON" we would have.
    We then had fun playing catch up and found ourselves behind a different three who'd explored the M4 at some point.
    All good fun Big Smile
    Rex - let us know when you make it home or we'll send out the dogs
    Waving not drowning to ALL MKs regardless of 1,2 or 3 ~ Un Mx-5s pour l'année ~ non seulement pour l'été!!
    mk3 1.8 o/p Eibached with Racing Beat backbox- K&N panel filter-WiM'd-Zunsport Grille - Uniroyal Rainsport 2s or Avon Ice Touring ST.
    & ~ affiliated.
    Membre de la Brigade Bleu et en liaison avec Les Noire. Old Git's Clan Yoof Team
    mx5life.com A socially engaging discussion forum all about the Mazda MX-5, Mazda Miata and Eunos Roadster
  • Thu, Mar 17 2011 18:20 In reply to
    • rex1943
      Tue, Sep 21 2010
    • Posts 44
    Re: Usk. 13th March
    VO5Jo
    Thanks for your concern, cried with laughter after reading all the comments. Don't worry now living in Usk, such is life. Had the map upside down, after our meal in Usk and the MX race felt very tired. we both went for a stroll to clear our heads,still confused then  met a nice man. After talking to us both he quickly came to the conclusion we needed help, why I will never know!!!! We are now living in  Usk "The Twilight Home For Confused Mx Drivers".
    However, the food and accommodation is excellent with regular injections and lots of TLC we should survive and hopefully make the next race.
    When I bought the Mx I never realised this would happen, no warning came with the car!!!!!!!!!!!!1
    Blessings to all, signing off.  Island
    JF.
